How to dissasembly the third brake light? - Mercedes Benz SLK Forum
#1 Old 05-13-2010
Vehicle: Proudly owner of a second hand silver grey R170 SLK200
Other Toys: SAAB 900S (1996)
Hi all,
I am new in the forum (I had presented myself in other message) and I am a very happy new owner of an 11 years old R170 SLK200.
As some of you have experienced, my third brake light is not working. I think it is a common fault due to some corrosion to the electric contacts (none of the strip lights is working), so I want to clean the contacts.
I would appreciate a lot if you can explain to me in detail how to dissasembly the light. I think I have to take it off from the inside of the trunk. I have found a plastic cover in the trunk, secured by 3 round points. I suppose they are fixed by pressure but I fear I can break something if I apply too much pressure. Any indication of the procedure for dissasembly and bringing the light to life will be very welcomed. I have searched the forum but with no result.
Thanks a lot!
OscarBCN is offline
#2 Old 05-13-2010
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Check out THIS post - although it's for an R171, the fastenings are similar.
Woolly is offline
#3 Old 05-13-2010
-1-
Don - Founding Member #4
-1-'s Avatar
The R171 third brake light has easy access. The R170 should be just as easy. Referencing the post Woolly provided, are the plastic fasteners the same? If so, they're two piece. Use a small flat tip screwdriver to pry up and pull out the center piece, and then the same with the remaining piece.
-1- is offline
#4 Old 05-13-2010
Thanks for the answers. I think the fasteners are not the same. In the R170 they are circular and with a plastic ring surrounding them. Perhaps I have to take out the plastic ring first, I don't know. If some one can enlight me...
Thanks!
OscarBCN is offline
#5 Old 05-13-2010
You have to pry the inner plug out first then pry the outer ring next.
#6 Old 05-14-2010
Thanks!
Perhaps post a photo of the retaining plug, then someone may be able to tell.
Tags
third brake light
John's 3rd Brake Light Adapter UK-C200 General Modifications R171 554 2 Days Ago 09:59 AM
NoRegret4Life's KLEYMAN Flashing 3rd Brake Light Module SLKman SLK R170 General Discussion 54 11-13-2016 06:58 PM
3rd Brake Light calibrand General Discussion 6 06-30-2009 04:16 PM
Brake Light Flasher noregret4life General Modifications R171 221 02-10-2009 07:38 AM
AMG smoked rear light clusters / 3rd brake light. jfb1977 Where to get R171 SLK Items 2 07-24-2008 11:40 AM
