Power seat problem - Mercedes Benz SLK Forum
  • 1 Post By brewedforu
  • 1 Post By Rob7412
#1 Old 05-07-2010
Vehicle: Yellow 2002 SLK 320
Other Toys: lot's of instruments and trains
Power seat problem
Hi all,
I just picked up my 2002 yellow SLK 320 yesterday and it appears that I missed testing one thing. The driver seat will not tilt down in the front.
All other motions (and the other seat) work fine. It also appears that up works although it's all the way up now. You can hear the motor click when you push the switch up in the front but the switch won't move down. It seems like a mechanical problem with the switch.
It's not a big deal as the seat is comfortable where it is but, I'd like to have a look at it. Any advice? I expect I'll need to remove the seat to get at the switch.
Thanks,
Steve
steveb48 is offline
#2 Old 08-21-2010
Vehicle: 2005 SL500
Power Seat Problem
I have the same basic problem with the passenger seat in my 2001 SLK 320. When I bought the car I pointed out that the passenger seat would move fore and aft and the backrest would recline but the seat height adjustment would not work (it is in the down position). The dealership told me it was a burned out motor (they reached this conclusion by claiming they put a motor from another car in mine and it worked fine). Well I bought the proper sockets to remove the seat and installed the new motor assembly but I have the same problem. I too believe it is a switch problem, but now I find you can't just buy a replacement switch and that you have to buy the entire seat bottom, part #17082026107C45 or 17082026109B51 which runs between $400 to $550 depending on where you get the part. I'm just not sure I want to invest the funds to be able to raise the seat higher!
brewedforu is offline
#3 Old 08-28-2010
Vehicle: 2005 SL500
I fixed my problem! Visually checked the relay in the dash and it seemed OK so proceeded to remove the seat again, unpluged all the electricals and took off the side panel where the switches are located. Opened the switch compartment and sprayed electrical contact cleaner and lube on all the switch springs. Closed the compartment and sprayed the male and female electrical connectors before reassembly. Checked out the power seat functions before remounting the seat....and it worked perfectly! Saved about $450 and hope it is a lasting fix to my problem.
Der Flieger likes this.
The Following User Says Thank You to brewedforu For This Useful Post:
#4 Old 09-01-2010
Vehicle: SLK230 2002 Silver/Marlin
I have had a similar problem and solved by cleaning the switches. I should have taken pictures and if this ever happens again I will. Here's what I did.
Pull the seat, unlug all the wiring. Uncscrew and pull off the seat side panel to get access to the switches. Remove the screws holding the switch block to the side panel and separate. I then unscrewed the main connection bracket so I could remove the harness from the seat area and work on it on my bench.
On the front side of the switch block the 4 swiches are covered by grey covers, 1 for the recliner and 1 for the other three. My problem was with the fron seat riser so I pulled off the cover covering the three switches. This exposes the switch mechanisms. I then removed the toggle for the non working switch by prying aside the clips securing the toggle and lifting it out. Careful here as yours might have loose springs though in mine they were all captive. You can now access the switch contacts. Note how they are fitted. Lift out the moving part of the contacts so you can see the contact area. In mine they were black and oily and also rather pitted. I cleaned them and added just a fraction more bend in the contact arms, not too much or they will not move correctly and you could end up with a short. Reassembled everything works just fine. You need to be careful putting it all back together to make sure the big switch levers mate up correctly with the switches, try them to make sure you can feel the switch action before putting it all back together.
You can check the switch action with a multimeter. If I recall correctly the two switch commons go to the motor then when operated in one direction it switches + volts to one common whilst leaving the other common connected to - Switching in the other direction puts + on the other switch common leaving the first common at - When at rest both commons are connected to -.
Provided you are careful the switches can be cleaned and rebuilt Mine have worked for months now and seem fine. It would seem that perhaps the mottor current is a little more than the switches were designed for and this is or the motor back emf is what is causing the pitting of the contacts.
YMMV, I rpovide this info as is and without warranty of any kind. Hope you find it useful.
Regards
Martin
martinbangkok is offline
#5 Old 03-17-2011
No fore-aft movement
My fore-aft switch seems to have failed, with seat in forwards position. The motor became hot so I've now removed the fuse.
I can move the seat up/down, and change the seat angle; but not forwards/backwards.
Can I remove the switch with the seat in place?
Or how can I remove the seat (whole seat, or just the lower part)?
Thx for any help.
Anthony (2002 SLK 230)
anthony dot cutler at btinternet dot com
MG-Ant is offline
#6 Old 03-18-2011
Workshop Manual
Has anyone purchased this workshop manual: http://www.emanualonline.com/Cars/Me...op-Manual.html
If anyone can recommend purchasing (based on info on how to remove seat, switches, motor etc), I'd be happy to purchase.
Any help on this or previous thread appreciated.
thanks
Anthony
MG-Ant is offline
#7 Old 03-19-2011
Removal of seat squab
Hi
Does anyone have any ideas on removal of seat squab with the seat in situ?
Thx
Anthony
MG-Ant is offline
#8 Old 10-12-2012
Vehicle: SLK 230 - Year 2000 - Facelift Model - Silver
Hi Anthony
I know these questions where asked a long time ago but did you get the answers you wanted ??
I also have a problem with the seat switch on my year 2000 SLK 230
I pulled the plastic cover off the seat switch and I can see the three separate switches that do the work. The centre of the three moves the seat backwards and forwards but it seems to get stuck and needs to be lifted slightly in order to move it back and forth. So I suppose the switch needs to be replaced.
Is it possible to get a new switch
and can it be replaced without removing the entire seat ??
Regards
Healey
Healey is offline
#9 Old 10-12-2012
MrG
Vehicle: Black '02 SLK320
Originally Posted by Healey View Post
Hi Anthony
Regards
Healey
I went through the same thing awhile back. Check out the last post in this thread. Pretty easy fix. Everything is still working great.
MrG is offline
The Following User Says Thank You to MrG For This Useful Post:
#10 Old 10-13-2012
Hi MrG
Thanks for the information
I will give this a try in a few weeks time
I am recovering from an operation at the moment so I can only do the planning, rather than the actual work.
Soon I will have a working seat though !
Thanks again
Healey
Healey is offline
#11 Old 10-17-2012
Hi MrG
I just have another quick question if you don't mind.
I have a feeling that there may be some additional damage to the switch which I may not be able to fix with the method you described.
Assuming that is the case, would it be possible to exchange the drivers side switch with the one on the passenger side ???
Are the switches "handed" ?? Would it work ??
The idea being that the passenger side is not so important.
Thanks in advance
Healey
Healey is offline
#12 Old 10-17-2012
MrG
I'm guessing the switch boxes are 'handed' but I haven't been into the passenger side to confirm. I'd bet you could swap out the individual switches inside the boxes though. That's an interesting idea.
MrG is offline
#13 Old 10-18-2012
Hi
Yes - Thats what I thought
Good idea of yours on changing the individual switches !
At least that gives me a "Plan B" if all else fails.
Will see in a few weeks time
Healey
Healey is offline
#14 Old 03-14-2013
Vehicle: 2003 SLK 320 (VIN: WDBKK65FX3F280089)
Other Toys: 72 Corvette Conv. (purchased in 72) & Cadillac STS
Question Intermittent Power Seat Problem
Just wondered if anyone has ever experienced a problem with the power to both seats going out intermittently. This makes troubleshooting a good bit more difficult. I'm going to assume that because the power seat motors draw a rather significant amount of current, the circuit would be protected by a circuit breaker, rather than a fuse - so my first step would probably be to check the contacts of the circuit breaker - If I can locate it.
At 5'2", my wife drives with the seat positioned nearly all the way forward. When there is no power to the seats, I can't even get into the car.
Rob7412 is offline
#15 Old 03-14-2013
Here you go! Check out this thread. If it's intermittent then it's most likely the relay! I had the same issues as you do now =)
https://www.slkworld.com/slk-r170-cla...relay-fix.html
#16 Old 03-14-2013
Thanks - that should help ! - I'll let you know for sure. Really appreciate the quick reply.
That is especially suspect as I recently replaced the break light switch - in nearly the same area as the relay in your photos.
Rob
JaysonM likes this.
Rob7412 is offline
#17 Old 03-14-2013
Rob
Definitely keep us updated! Glad I was to help!
#18 Old 03-18-2013
Jayson, I sent a reply - along with many thanks - to your original post : https://www.slkworld.com/slk-r170-cla...relay-fix.html
Guess I need to spend more time on this site to become more familiar with the mechanics of searching and posting threads.
Thanks again, Rob
Rob7412 is offline
Seat adjustment problem dVb SLK R171 General Discussion 22 01-11-2011 08:30 PM
Heated Seat Problem Aggie 08 General Discussion 16 10-31-2009 02:00 PM
power seat conversion shredster2002 General Modifications R171 3 08-26-2008 11:04 AM
Heated Seat Problem ugly_bloke SLK R171 General Discussion 4 06-17-2008 04:22 AM
Seat problem Vin SLK R171 General Discussion 27 09-05-2006 06:15 PM
