Condensation to underside of boot lid - Mercedes Benz SLK Forum
#1 Old 04-22-2010
Vehicle: SLK 200K
Other Toys: VW Golf GTTDI, Road bikes various
Chats: 2
Has anyone experienced having condensation on the underside of their R170 boot (trunk) lid?
Is their normally a sound proofing muffler / insulator pad clipped under here as with the bonnet?
I am finding some minor corrosion marks beginning to start and don't want to see these get any worse.
Does anyone think its a case of spraying with Waxoyl or similar?
davep is offline
#2 Old 04-22-2010
Quoted: 6554 Post(s)
normally an insulator pad there
#3 Old 04-22-2010
Vehicle: 2001 Silver SLK230
Chats: 2
Would you mind posting a couple of pics?
As for the padding, I don't think the R170 has any for the trunk lid, or at least the ones I've seen.
GusSLK is offline
#4 Old 04-22-2010
sorry, thought i read hood
#5 Old 04-22-2010
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Hi Dave, check out the spare wheel well to see if it's like a swimming pool - it's not unusual for leaks into the boot area. If you find water in there, search the forum for blocked boot/trunk drains.
Woolly is offline
#6 Old 04-26-2010
Vehicle: SLK 200K
Chats: 2
Hi All
Thanks for your replies. Wheel well nice and dry.
davep is offline
#7 Old 04-26-2010
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
May have crack in rubber seal allowing moisture inside.
Just a guess on my part.
SLKman is offline
#8 Old 04-28-2010
Vehicle: 2000 SLK 320
Other Toys: Celica GT
I've got the same and a dry wheel well. I'ts actually starting to corrode so I'm getting out the fine wet n dry and the matt black spray....
JustinJoyit is offline
#9 Old 04-30-2010
I just had a good cleanup of all the boot/hardtop seals. There was green mould everywhere in the rubber channels so I made up some mild bleach mix with water and some dishwashing liquid. Cleaned it all out, did the drain holes, tried to get a flexible platic rod all the way through but I think theyre exiting into the skirt as per previous post here. Anyway they re draining. Rinsed and dried it all then looked at the inside boot lid, it seems what I thought was corrosion was the residue of the mould gone brown so again using the bleach/water/soap scrubbed it all off, rinsed and all is well...hopefully.
I think the UK winter here just got into it, there was snow which I assume shrunk the seals allowing water in- no garage.
#10 Old 05-02-2010
Vehicle: SLK230 1996
Other Toys: Mercedes 500SL 1989; Jensen Interceptor 1973; Jaguar XJ-S 1989; Mercedes CLK 320 2003
Check the seals-mine did the same, there was loads of condensation within the boot. This means water is getting in. I had to replace one seal (the long complex one that is nearest the rear window) and I removed the other and thoroughly cleaned it. Both rubber seals were then silicon sealed into place on the car. The boot/trunk is now dry as a bone.
Van
van883 is offline
Boot Lid handle broken Chriscena General Discussion 2 04-17-2010 11:24 PM
SLK ROOF (boot Lid twisting) R170 kev-1983 SLK R170 General Discussion 4 01-20-2010 02:08 PM
