Drive shaft center bearing help. - Mercedes Benz SLK Forum
  • 1 Post By Todd157k
#1 Old 04-18-2010
gringott's Avatar
Vehicle: 1998 SLK230 R170 Stock
Other Toys: 350Z TT
I have recently had a 'thumping' sound under the car in the center, usually in second gear, upon accelerating. This just started. I did a search and came up with flex joint. I got under the car, the flex joint appears to be fine. However, on the other end of the drive shaft, just in front of the u-joint, there is a bearing that is bolted to the body, that the drive shaft enters. The technical name is 'Driveshaft support bearing'. It appears that the rubber that supports the bearing is badly deteriorated, and I can detect some play in the shaft. I have ordered the assembly from Autohaus. My question would be:
Is there a DIY for this?
If not, has someone done this, and if so, are there any 'gotchas' I need to be aware of?
I do see that I will have to drop the exhaust system to get to it, anyone know the part numbers for the nuts and bolts and gaskets that hold the exhaust together? I noted that the rear trianglular joint has badly rusted nuts and bolts, and in front there is a u-bolt also badly rusted.
Any help is appreciated. Thanks
BTW, it's a 1998 SLK230 R170 bone stock.
gringott is offline
#2 Old 04-18-2010
Vehicle: 2006 SLK55
DIY.. ya, not that bad IF you have the tools and area to do it. The pitfall is that rusty bolts crap. Start soaking all of them with penetrating lubricant a day or two before you do the job. I'd replace both flex disks, u-joints and the bearing while you're there. You'll have it all in your lap anyway.
Todd157k is offline
The Following User Says Thank You to Todd157k For This Useful Post:
#3 Old 04-19-2010
gringott's Avatar
Other Toys: 350Z TT
Great info Todd157k, thank you. I was looking for a picture. Some questions come up right away, first:
Only 1 Flex Disc kit for my VIN is listed, called Flex Disc Kit;Rear Part number 2104100815. It states 'One Kit per car' Does it use the same kit for the front and rear flex disc? Or are both in there? The picture shows one.
They also list this part:
Driveshaft Bushing; Front/Rear; Centering/Guide Bushing Part Number 1244100732 basically the picture shows a metal tube bushing - where does this go and do I need one?
Nobody lists the U-joint that I can find.
Thanks for any help you can provide.
gringott is offline
#4 Old 04-19-2010
Vehicle: 2006 SLK55
Take a look here:
http://www.partsgeek.com/ymm/1998/mercedes/slk230.html
or
http://www.europartsamerica.com
I don't see the front flex listed however it's obvious there is a difference (otherwise they wouldn't specify "rear")
both places seem to have the support bearing setup. I'll try and check WIS tonight for any part numbers.
Todd157k is offline
#5 Old 04-19-2010
gringott's Avatar
Other Toys: 350Z TT
I ordered the support bearing assy Saturday, it's on it's way.
gringott is offline
#6 Old 04-19-2010
Vehicle: 2006 SLK55
Well, I couldn't find any part numbers (this program is about the most difficult thing ever written) however I printed you a few pages of info that might help.
deadhead likes this.
Todd157k is offline
#7 Old 04-20-2010
gringott's Avatar
Other Toys: 350Z TT
Thanks Todd157k, that should be a big help.
gringott is offline
#8 Old 04-20-2010
Post some DIY pictures of your job please.
#9 Old 04-21-2010
gringott's Avatar
Other Toys: 350Z TT
I will do that. Still researching parts. I did find that the u-joint is 'staked', the reason seems to be Mercedes wants you to replace with a rebuilt or new I guess driveshaft. I am still trying to find out why the front flex disc isn't listed on part sites. One driveshaft rebuilder specified that the complete driveshaft they offer does not include front or rear flexdisc. I also found there appears to be a difference between 1998 and 1999 driveshafts, anyway, they are listed individually.
gringott is offline
#10 Old 04-21-2010
Vehicle: 2006 SLK55
Todd157k is offline
#11 Old 04-22-2010
gringott's Avatar
Other Toys: 350Z TT
Todd157k - You are amazing. Thanks.
gringott is offline
#12 Old 04-22-2010
Vehicle: 2006 SLK55
Todd157k is offline
#13 Old 10-02-2010
gringott's Avatar
Other Toys: 350Z TT
Just got the job done. Noise is gone. It was the center bearing, but replaced front and rear flex joints, used rebuilt driveshaft. Smooth. On a lift, you just drop the exhaust and go to work. Think it took about 3.5 hours. Thanks for all the help.
gringott is offline
#14 Old 05-14-2013
Vehicle: 1998 SLK 230 Kompressor
Other Toys: Motorcyles
This information was very helpful in replacing my propeller suport bearing thank you. from deadhead.
deadhead is offline
#15 Old 02-12-2018
wesleythung's Avatar
Vehicle: Silver 1998 SLK200
Other Toys: bicycle, Public Transport
is there a difference in torque spec for the bolts of the flexdiscs between the 230 Kompressor and the 200
wesleythung is offline
#16 Old 02-12-2018
Quoted: 2262 Post(s)
Let's see if the knowledge squad can help:
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
Avel Du is online now
February 20, 2010 Northern California SLK Enthusiasts Meet & Drive Motzkoman U.S. California 5 02-19-2010 01:20 AM
November 21, 2009 Northern California SLK Enthusiasts Meet & Drive Motzkoman U.S. California 1 11-07-2009 02:07 AM
10/17/09 Northern CA SLK Meet & Drive Motzkoman U.S. California 0 10-10-2009 01:33 AM
September 19, 2009 Northern California SLK Enthusiasts Meet & Drive Motzkoman U.S. California 3 09-16-2009 11:27 PM
SLK Drive In Night this Saturday 8/22! YellowSLK U.S. West Region 0 08-18-2009 01:19 PM
