Need some help guys - Mercedes Benz SLK Forum
#1 Old 04-15-2010
Need some help guys
I have a problem keeping a charge in my battery. A little history; over the winter i took the battery out of the car and placed it on a trickle charger all winter. This past month i took the car out of storage for the season, ran the car at idle for an hour then took it for a short ride. One hour later the battery was dead, i took the car to a local parts store and had the charging system tested, all was good. I had the store charge the battery, went home and it was dead. i checked all cables and all looks good. Either the battery is dead (2 years old) and the test was done wrong or there is somthing draining the battery fast. Any ideas??
#2 Old 04-16-2010
Vehicle: Black 2002 SLK AMG
Other Toys: Red 1965 Mustang convertible 4bbl V-8, 4spd
Chats: 4
Is the battery case cracked anywhere? Can you check the water levels in the cells? If so are they low?
If you fully charge it on your trickle charger while disconnected from your car, and then let it sit off the charger overnight (and not connected to your car either), then reconnect it to the car and check to see if it is dead then or not. That should isolate whether your car is draining it fast or if the battery won't hold the charge.
Santamonica SLK32 is offline
#3 Old 04-16-2010
Wasn't there a post on how to find out if some on-board device is drawing too much from the battery?
IIRC (really fuzzy memory), it was something simple: a DC light bulb placed between the negative post of battery to the negative ground/chassis. Or use an amp meter. If there is an usual power draw, then pull fuse one at a time to isolate the device that's drawing too much power. I cannot recall the milli-amp allowed when all devices are asleep. (Please correct me or post a link to that post, when found)
#4 Old 04-16-2010
No cracks in the case and the water level is good. I will try charging the battery and let it sit overnight. When they checked the battery they set the machine for 1200 cold cranking amps, that sounds wrong 1200 should be for a deep cycle battery.
#5 Old 04-16-2010
Here's a thought, what if i jump the car then pull the battery terminals while its running? if it stays running then i know the alt. is working, if it dies then the alt is bad. Do you think that is a valid test?
#6 Old 04-16-2010
-1-
Don - Founding Member #4
-1-'s Avatar
Wouldn't recommend this.
-1- is offline
#7 Old 04-16-2010
Yup, maybe not i don't want to cook anything.
#8 Old 04-16-2010
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If the alternator is working fine, then disconnecting the battery whilst the engine is running will almost certainly ensure the alternator will not work
Get hold of a cheapy multimeter. Set the range to 20VDC. put the probes across the battery - when the engine is off, it should read about 12.7V - slightly less than that means your battery is flat, a lot less means your battery is toast. Turn the engine on and re-measure the voltage - it should be around 14.5V - this means the alternator is working, get someone to rev the engine whilst you are measuring. If it stays about the same, it means the voltage regulator is working.
To check current draw whilst the car is turned off, do it in two stages because cheapy multimeters cannot handle high current.
Firstly, with the key out, disconnect the POSITIVE terminal (+ or red) and connect a 12v bulb(not an LED bulb) between the +ve terminal of the battery and the+ve lead (that you have just disconnected). If it glows brightly, and everything is turned off, then something is seriously wrong, and you'll need to see your dealer. If the bulb doesn't glow, set your multimeter on 'current' or amps and take a reading and report back.
Woolly is offline
#9 Old 04-16-2010
Woolly, thanks for the help i will work on it this weekend and report back.
Can You Guys Help Me GtoBenz General Discussion 12 01-25-2010 12:45 PM
Hey guys, let's do a SGV-OC meet and drive? (SoCal) cyberdrakon MB Events 75 06-08-2009 03:13 AM
you guys have any recommendations on a forum regarding training noisy dogs? cyberdrakon Off Topic 11 03-28-2008 09:49 AM
The coolest guys in the world-vid Vin Off Topic 4 08-17-2006 12:23 PM
