Engine not cranking..! - Mercedes Benz SLK Forum
#1 Old 04-10-2010
Vehicle: 1999 model SLK 200 (136 HP)
Other Toys: Ural with sidecar
SLK 200 European 136 HP from 1998
Key on “1”: SRS light is turning on for three seconds and turning off...
Key on “2”: All lights on, not the SRS light...
Trying to turn on: Not a click... Fulll silence only the radiator fan is turning full speed...
What might be the problem and of course the solution..?
kole301 is offline
#2 Old 04-10-2010
DJC013's Avatar
Vehicle: 2001 SLK 320 Auto Linarite Blue / Black Leather
Other Toys: 2004 Scenic 1.9 dCi, 1999 Honda CBR600F-X
Hello, from what I have read on some SLK Forums (this one included) it sounds like the `K40` relay is your problem, do a search on here, should give you some useful info.
Hope this helps, regards Damian.
DJC013 is offline
#3 Old 04-10-2010
I would start with the battery, have it checked first and see if its still good, then check battery terminals make sure they are clean and tight.
#4 Old 04-11-2010
Battery is OK... The K40 relay seems OK and 15A fuses look normal...
Just two questions:
- The 40A fuse of the K40 relay... Is this shape is correct..? Or blown up..?
- Or the one circled in red on the K40 is it defective..?
If everything OK on this front what to look next..?
kole301 is offline
#5 Old 04-11-2010
Vehicle: 2006 SLK55
Make sure it's in PARK. There's a "starter lockout switch" but I'm not sure where it is on your model, which is how the car knows your car isn't in Park to start it.
Todd157k is offline
#6 Old 04-12-2010
Yesterday evening cleaned the K40 relay and the connections with electronic cleaning spray... Recentered the coil of the transponder... Tried the car with the spare key... Result: WROOOOM...
Tried to move the car this morning...
A big “thump" and the transmission went into “limp mode”...
Took the car to an independent MB service...
Left engine mounting bloc was defective... Changed both...
Back home: WROOOOM and WROOOOM...
Life is beuatiful and even better with SLK...
Work: two hours... Cost: 303,- US dollars parts included...
kole301 is offline
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 252 3 Weeks Ago 01:31 PM
AMGPL: AMG 5.5-litre V8 biturbo engine Cold Shot AMGs 14 03-21-2010 09:11 AM
