R 170 audio and amplifier connections - Mercedes Benz SLK Forum
#1 Old 03-23-2010
Vehicle: SLK 320 R170
Question R 170 audio and amplifier connections
Hi can anyone help, I've read through quite a few different threads and can't seem to find the answer to my question. We have a year 2000 SLK 320 R170 which we brought recently. The head unit was an Aldi special (Aldi is a British supermarket for international readers) as I believe the original unit either stayed with a previous owner or was liberated by some toe rag during the cars life. Anyhow, located in the passenger footwell is what I believe to be an amplifier, besides others this has four connections to the "B" connector on the head unit. They are:-
Head Unit "B" to Amplifier
6 to 3
5 to 5
4 to 4
3 to 6
From the amplifier connector there is also cabling to speakers
23 & 15 to front left speakers
25 & 17 to front right speakers
20 & 12 to rear left speaker
19 and 11 to rear right speaker.
The rear speakers are Bose and I believe there is no D2 B cabling in the car.
Having done some research I have discovered that connections 1 & 2 and 7 & 8 of the "B" coupler are outputs from the head unit for rear speaker drivers.
Is it that I am missing the cabling from these "B" connections to the amplifier, and if so what are the corresponding connections on the Amplifier. ??????
Many Thanks..
"Sorry, whole point of this thread is that the rear speakers do not work".
trev is offline
#2 Old 03-23-2010
paultalb's Avatar
Vehicle: '04 SLK32 //AMG Needswings upgrades -- 4Sale
Other Toys: F150, A3 quattro, XC70 Polestar, MB Sprinter
Chats: 7
Check this Thread
Look at my thread, do you have the connectors or did it get cut out, I can give you the color/use for most. I had a couple of extras that I don't know what they should have connected to.
paultalb is offline
#3 Old 03-23-2010
Hi.
yes I did read through your thread and it confirmed my thoughts on the head unit connectors 1 & 2 and 7 & 8 being rear speaker drivers. Am I right in thinking these should be wired to the amp, and if so what are the connections on the amp. It may be that the wiring has been cut in the loom somewhere, as stated the original head unit has been removed.
trev is offline
#4 Old 03-23-2010
Quoted: 6551 Post(s)
trev,
Please update your location in your profile as it helps the members answer any questions you might have based on locale and model.
usercp, edit your details, location.
And finally, if you find something useful on your visit here today, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! Thanks!
#5 Old 03-23-2010
paultalb's Avatar
Chats: 7
Originally Posted by trev View Post
Hi.
Bummer.. If you have the Bose those need to be connected to the Pre-Amp from your deck. There is only left and right, not front and back going to the amp, unless they bypassed it and the leads go directly to the speakers. you could check the resistance, if they go directly to the speaker it would be 4 or 8 ohms.
If you want original OEM I'm going to sell my old head unit, and 6-disk changer.
paultalb is offline
#6 Old 03-24-2010
Hi Paul, thanks for the info so far. The unit I am refering to as the amplifier is located on a plate in the passenger footwell. This has four wires direct to the head unit as described in my first entry. From this Amplifier ????? there is wiring to the two front speakers and the two rear speakers, I have traced / continuity tested these wires. On your thread it does show wiring from the head unit "B" coupler 1 & 2 and 7 & 8 and refers to them as the rear speaker outputs, but in the photograph it only shows four wires, the four wires which are present in my car. I can understand not needing these connections if not driving rear speakers. I have read in other threads about there being a D2B connection, is this what is possibly missing, if not, and pardon my ignorance here, if terminals 1 & 2 and 7 & 8 are not connected between the head unit and the amplifier how does the fader front / rear work on the head unit.
trev is offline
#7 Old 03-24-2010
paultalb's Avatar
Chats: 7
My head unit only had right and left, no front and rear control.
Smaller wires on block B are the only speaker connections.
I only connected A4, A7 and A8 to my deck. And soldered on RCA connections to B3 B4, B5 B6 that went to my pre-amp out on the deck.
A01 ??
A02 ?? Phone mute
A03 ??
A04 Burnt Orange\Green - Battery (circuit 30) +12V constant on, fuse F21 25A
A05 Blue\white - FM AM WEATHERBAND amplifier and Bose premium sound system power
A06 ??
A07 Pink/green - Power (circuit 15) +12V switched, ignition, fuse F10 10A
A08 Brown Ground
I couldn't find exactly what the other connects are in the R170.
paultalb is offline
The Following User Says Thank You to paultalb For This Useful Post:
#8 Old 03-25-2010
Hi Paul.
The more I look at this the more I am coming to the conclusion that all the wiring is there and that there is a fault with the Amp. I think my next move is to get the amp checked out.
Thanks once again for the help.
trev is offline
#9 Old 03-25-2010
paultalb's Avatar
Chats: 7
Hi Paul.
If my amp was bad, I'd just bypass and use the deck's amp, the Bose doesn't have enough power. Make sure A5 is connected, it turns on the Bose amp. without that you will get nothing. I think you can manually switch it on by giving that lead 12v +.
With the Bose amp you really wouldn't need a head unit, just wire up a switched 12v to the Amp switch and connect an iPod to the speaker leads.
paultalb is offline
Facelift Audio 20 amplifier output? fleep SLK R171 General Discussion 2 10-31-2009 07:11 PM
