Differential Service? - Mercedes Benz SLK Forum
#1 Old 03-07-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
I think it was Designo who posted a DIY on changing differntial fluid. I'll be darned if I can find it now. It was a great post. Anybody help me find it?
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#2 Old 03-07-2010
Vehicle: Black 2002 SLK AMG
Other Toys: Red 1965 Mustang convertible 4bbl V-8, 4spd
Chats: 4
Differential fluid change instructions for the SLK 320 in the link. A nice PDF with guiding photos and written details is included.
http://www.benzworld.org/forums/r170...-exchange.html
Santamonica SLK32 is offline
The Following 2 Users Say Thank You to Santamonica SLK32 For This Useful Post:
#3 Old 03-07-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Thanks! I knew I could count on the forum!
Margie and Terry
tcrankwa is offline
#4 Old 03-08-2010
320 dreamer's Avatar
Chats: 5
i use 75/90 mobil 1 synthetic
320 dreamer is offline
#5 Old 03-09-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Yup. Me too.
I just couldn't remember the hex size. 14mm. Not something I have lying around.
Margie and Terry
tcrankwa is offline
#6 Old 03-14-2010
Chats: 5
harbor freight has the square head set for about 14$
#7 Old 03-15-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Hmm. Mines a 14mm hex. Had to order the set from Amazon.com.
Margie and Terry
tcrankwa is offline
#8 Old 03-15-2010
Chats: 5
hex, square the harbor frieght set has both!!
#9 Old 03-15-2010
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
If you can find one of these from the ponton days, they really are nice.
Len
Mercedes-Benz Ponton Tool Kits © www.mbzponton.org
Original style 14 mm hex (Allen) wrench:
The original Mercedes-Benz Ponton 14 mm hex (Allen) wrench (120 581 06 65) is used for the following drain plugs:
  • differential (both drain and filler plugs)
  • gas tank
  • oil pan
  • transmission (both drain and filler plugs)
sokoloff is offline
#10 Old 03-15-2010
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Len
  • gas tank
  • oil pan
Now THOSE are cool!
Margie and Terry
tcrankwa is offline
#11 Old 10-02-2011
Killahkal88's Avatar
Vehicle: 2001 slk320
Send a message via AIM to Killahkal88
Would using Castrol C Hypoid 80w-90 be okay for use on the diff? It is also GL-5 rated gear oil however I don't think it is synthetic.
Killahkal88 is offline
#12 Old 10-03-2011
Firm's Avatar
Very Helpful....I need to do this, thanks!
Firm is offline
#13 Old 10-10-2011
Firm's Avatar
Just did this today. Whole process took about an hour. I had to raise the back of the car a little because I couldn't get enough clearance to swing the rachet to break the plugs free.
Like the pdf author says; Make sure you use a hammer to make sure you've got the hex bit well seated into the plug. They seem pretty easy to strip
I had to order a 14mm hex...cost me $15, and a lot of screwing around, but at least I have it now.
I used a 75W90 full synthetic gear oil.
I didn't have a fluid pump...So I stuck a piece of rubber fuel line on the end of the bottle (similar bottle to the one pictured above) and fastened it there with a hose clamp. Worked like a charm, there is a good space just in front of the diff you can use to position the bottle.
Firm is offline
Service B due has now changed to Service D oscy SLK R171 General Discussion 7 06-25-2015 06:15 AM
can SLK's go from A service to C service?? True Romance SLK R171 General Discussion 13 12-16-2009 10:54 AM
Next Service Interval..after first? Goggomobil SLK R171 General Discussion 10 04-28-2009 06:42 PM
HELP! Its Service Time JoesSLK55 AMGs 0 10-05-2007 04:10 PM
Understanding FSS jbanks15 SLK R171 General Discussion 6 08-21-2006 11:08 AM
