Bose Amp??? - Mercedes Benz SLK Forum
#1 Old 02-27-2010
Vehicle: 230K
Other Toys: Bang and Olufsen
Chats: 7
Bose Amp???
Hello
I am collecting my r170 next week and after much reading i have a question.
Did all R170's have the bose amp and speaker system.
My old MR2 had this and i am aware of the RCA output rather than Speakers etc.
how can i tell if mine has the bose system??
Seanie_230 is offline
#2 Old 02-27-2010
aka John
Chats: 1143
Quoted: 30 Post(s)
Not all cars have the optional Bose sound system - pm me your VIN and I'll pull your datacard for you.
If you have Bose, you have D2B fiber going from the head to the amp.
UK-C200 is offline
#3 Old 02-27-2010
Quoted: 6554 Post(s)
And finally, if you find something useful on your visit here today, please consider donating to offset development and operating costs. Even $5 is welcome! Thanks!
#4 Old 02-28-2010
Vehicle: 230K
Chats: 7
Hi there cannot send PM as have to have had 15 posts or more and im not there yet
thanks for your offer to pull the car record for me to find out if it has the bose system installed.
the number is wdb1704472f122460
i dont get the car until wed/thursday so i cannot look myslef until then and i want to order my wiring loom ready.
looking forward to your reply
thanks
#5 Old 03-01-2010
Vehicle: 1998 SLK230 (R170)
I have a '98 SLK it has the Bose Option (according to the datacard) and the Bose 'subs' behind the seats. It *does not* have any additional wiring beyond the standard ISO plugs. In fact there are only connections in the speaker plug for front speakers.
I just replaced the standard "Audio 10" unit with a Becker Traffic Pro (out of a Freelander actually) and it all works perfectly. Much to my surprise TBH. I have yet to investigate if there is an amp for the back speakers but if there is it must take a tap off the front speaker connections which is a bit rough!
Anyway, in your case (according to the VIN) yours doesn't have the Bose system. Just "533 front and rear speakers - without radio (с 01.03.1994)" (for comparison, mine says "810 loudspeaker, sound package sound package (bose) (с 01.12.1986)"). If you are talking about adding an aftermarket radio it will almost certainly be a straight plug in without any adaptors required.
thepurpleblob is offline
#6 Old 03-01-2010
Vehicle: 230K
Chats: 7
ok thanks for looking for me
so assuming that i dont have the Bose speaker system (CR
i can just put my head unit in, do i need to double check the thing i have been reading about making sure that the blue wire (radio signal amp)
is connected to the connection of my head unit???
#7 Old 03-02-2010
I must admit I didn't check and it works. I don't know the details but it might just be a reaction to VW/Audi's habit of putting a 12V feed in the position where the antenna switch on lead should be (risky for your radio). If you want to be belt and braces, make sure you have permanent 12V, switched 12V where they should be and nothing (or a very low voltage) where the antenna connection should be - this is on the Merc plug.
You don't say what replacement head unit it is but most are pretty consistent. You sometimes have the option to swap around or combine the switched/permanent feed. You won't do any damage if you get that wrong and it'll be almost immediately obvious (won't hold memory when you turn off the ig.)
#8 Old 03-02-2010
aka John
Chats: 1143
Quoted: 30 Post(s)
Boy, older datacards are bare! ;-)
UK-C200 is offline
#9 Old 08-14-2014
wsfahmed's Avatar
Vehicle: 2005 SLK 55 AMG
Other Toys: Toyota FJ Cruiser and VW Golf
Quoted: 17 Post(s)
My car has the Bose speakers and the 810 option on the data card so where is the Bose amplifier actually located and what are the specs of the unit in terms of power output etc.
wsfahmed is offline
#10 Old 08-14-2014
Talking
Wdfahmen, FIY the post is 4 years olds.
But let me answer one of your questions - the stock BOSE amp is located in the passenger footrest area. Carefully lift up the carpet, and you'll see white rectangular piece of styrofoam. Remove it and there is your BOSE amp =D
As far as specs go I think it's still a mystery buried deep behind Mercedes-Benz factory walls.
bose amp problem Bullstub SLK R170 General Discussion 4 06-01-2010 04:09 PM
Bose option in a R170 type-r SLK R170 General Discussion 8 02-05-2010 08:18 PM
SLK 170, FS: Stock premium bose system mavrick77 SLK Parts For Sale 0 01-25-2010 11:51 AM
SLK custom sub woofer and amp -1- General Modifications R171 10 06-11-2008 04:16 PM
Radio Amp dead (Bose) - Help? Midnight Son Where to get R170 SLK Items 1 03-09-2008 11:53 AM
