Leaky Windows in my '99 R170 - Mercedes Benz SLK Forum
  • 1 Post By Dull Witch
#1 Old 02-12-2010
DarkSithSLK's Avatar
Vehicle: '99 SLK 230, Brillant Silver over Salsa/Black
Other Toys: Acura CLS, Mildly Mod'd
Exclamation Leaky Windows in my '99 R170
It rained all day here in Houston.... when I got to my car, there was a small amount water on my driver's seat after I opened the door... there is a small amount of water at the thickened rubber area on the inside of the window... I noticed this while I was driving...
Any Fixes...???
Is this a major Concern...???
I had a '85 300 ZX with T-top's, but they leaked terribly!
Please help me out when you guys / y'all have a minute... sorry sooooo late!
Rick / Sith
DarkSithSLK is offline
#2 Old 02-12-2010
Any photos? What is condition of the rubber seal?
#3 Old 02-12-2010
The rubber is in pretty good condition... not torn or bent or pressed out of shape...
I really thought it was my imagination... this car has been stored outside for the last few years and my father in law made no mention of any leaks...
I will try to post some pics on saturday, as my friday has been crazy and its all good, but busy...
Thanks for a response etyu!
#4 Old 02-12-2010
Perhaps something to coat and soften the rubber seal. Here's what lkchris posted in another thread:
The Following 2 Users Say Thank You to etyu For This Useful Post:
#5 Old 02-13-2010
^ Thanks alot... my Acura could use some of that too!... my Wife looked at it and felt like the rubber had become alittle stiff, so this couldnt hurt at all!
... I will probably have to order it, but I will ask around a couple local places 1st... I will let you know what I find out and how it goes.... Rick/Sith
#6 Old 02-14-2010
JFR
JFR's Avatar
Vehicle: SLK 320 BVA red amber 2002 + SLK 55 AMG red thulite 2007
If the water comes from your window and the rubber is OK, you need a window adjustment, It's often the case on phase 1 doors.
anyway, be sure the water does not come from the roof rubber.
JFR is offline
The Following User Says Thank You to JFR For This Useful Post:
#7 Old 02-14-2010
rhusbands's Avatar
Vehicle: 2002 SLK 320 Sport
Originally Posted by JFR View Post
So, does anyone have any expertise with this adjustment or should the car be taken to a mechanic? My driver's side door could use some adjustment... it does not currently leak during normal weather, but I do get water through it when water is sprayed against it from a hose (no leakage at all on the passenger side.
-Ronnie
rhusbands is offline
#8 Old 02-15-2010
JFR, What roof rubber are you referring to... are you talking about the front edge rubber on the roof that attaches to the windshield frame?
#9 Old 02-15-2010
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
I think he is referring to the rubber in between where the top front edge of the retractable top meets the roof just above the visors. There is a rubber strip that reaches across side to side.
You may want to take it to a touchless laser car wash like the one at the Shamrock station just north of Cypresswood on Aldine westfield. Then you can watch to see where the water comes in without worry of spinning brushes scratching your paint.
SLKman
SLKman is offline
#10 Old 02-17-2010
JFR
JFR's Avatar
SLKman
exactly
JFR is offline
#11 Old 02-17-2010
JFR
JFR's Avatar
-Ronnie
first your window has to reach the top level and cover the rubber.
second, it has to apply regularly on the rubber.
there is a known problem with phase 1 before year 2000 SLK.
the window gets gently out of the bottom rail.
you have to undo the door and adjust and check the window.
if you are OK with DIY it's quite easy, if not like allways , find a mechanic . . .
JFR is offline
#12 Old 02-17-2010
Thanks alot to all of you who have sent comments...
I already took the door panel off once to adjust the door handle , so I am good with fixing it... is there a DIY link I can use anywhere?
#13 Old 02-17-2010
BTW... the roof rubber looks fine... appears to be isolated to just this one spot... on closer inspection, there are small cracks just before and just after the area of the leak... I saw it yesterday when I let the roof up and back...
#14 Old 01-23-2016
Vehicle: 2002 SLK32
Other Toys: 280SL Pagoda, RR Evoque, Smart Fortwo
Just to resurrect this thread...
I was on the highway yesterday in a fair amount of rain doing 70mph (or so). Suddenly, I noticed that my right arm was being dripped on occasionally. It was coming from the thicker rubber at the apex of the top/front curve in the driver side window I've not been out to double check in detail but I also think that's about the point of the roof/screen seal. It was occasional and I think it was because the speed I was doing was pushing water back upwards to that point rather than coming in from the top.
Has anyone else had this?
Dull Witch is offline
#15 Old 01-23-2016
Vehicle: 2000 SLK 320
Quoted: 54 Post(s)
I sometimes get a drip or 2 on the passenger seat after I have washed the car, the soap or detergents reduce the surface tension of the water and it runs between the rubber seal easier, happens on my Lexus as well just make sure the seals are dried off after washing, never had it rain in when driving.
Regards Stuart.
t140v is online now
#16 Old 01-23-2016
Quoted: 6539 Post(s)
not when we gummi!
https://www.slkworld.com/226839-post1.html
#17 Old 01-23-2016
Vehicle: 2002 SLK32
I must have Gummi'd wrong then, as Gummi I did!
#18 Old 01-25-2016
cockneyrick's Avatar
Vehicle: SLK 230 03MY
Quoted: 34 Post(s)
I have had a 99 & now 03 plate SLK230 cars & both have done this on the LH side of cars. Doesn't seem to affect the RH side???
I can sometimes adjust angle of glass to stop it, but sooner or later it starts again.
1: Under cover above door latch on the end of door is a M10 nut, use extension bar & loosen, then push top of glass toward car (door open) & re-tighten. Be careful removing extension as i have dropped my socket inside door!
2: Under bottom of door is a rubber grommet, remove & a M10 nut is there. Loosen & move the bottom of glass rail toward car & re-tighten.
Both of these can help, but not always. Costs nothing so worth a go
cockneyrick is offline
Keeping rear side windows or quarter windows down with roof up OutEast SLK R170 General Discussion 21 07-23-2016 11:21 PM
Demon R170.... RacerCub68 SLK R170 General Discussion 1 07-09-2007 05:01 PM
