Help needed!! - Mercedes Benz SLK Forum
#1 Old 02-05-2010
Vehicle: SLK 350 2005
Help needed!!
I bought SLK 230K ´97 a few weeks ago. Earlyer owner had Changed the cd-player. He said that Due to this, the Lamp failure light is contiously on when headlights switched on. It also had blacked out the Right side midlle console lights. All light bulps are ok and appropriate.
I took the cd-player off and there was a black DIN(ISO) connector with two small brown wires connect to it. Now with new player I dont have a idea where to connect that...? Is this the reason for it?
Plase Advice What to do
- Kaaleppi
Kaaleppi is offline
#2 Old 02-05-2010
aka John
Chats: 1143
Quoted: 30 Post(s)
Hmm, does not sound correct to me. I know a lot of people who have fitted aftermarket radios to the R170 (and I did in a W203 C class - about the same electronically) and not had any problems with bulb failures or anything else.
Can you take some photos of the connectors in your car? In theory the guy should have used an ISO adapter and left the stock wiring harness intact.
UK-C200 is offline
#3 Old 02-05-2010
Quoted: 6573 Post(s)
And finally, if you find something useful on your visit here today, please consider donating to offset development and operating costs. Even $5 is welcome! Thanks!
#4 Old 02-06-2010
Las VegasCop's Avatar
Vehicle: 2001 SLK 230 Auto
I believe the light failure indicator only pertains to the outside lighting like headlights parking and turn signals. Would be kinda dumb to have the interior lights hooked up too cause obviously you can see them without the idiot light telling you so. So I agree, there has to be a different issue.
Las VegasCop is offline
#5 Old 02-07-2010
techcareuk's Avatar
Vehicle: 1999 SLK 230K Designo with AMG option pack
Other Toys: S500L / Volvo V40 2.0T / Lunar Lexon EB caravan / Viking 26 Center Cockpit Cabin Cruiser
Hi Kaaleppi
as LasVegas states the bulb failure only relates to headlights and front and rear side lights, check if the failure lamp actually comes on with side lights only on or only when switched to headlights? if its when sidelights are on check the side lights (and maybe reg plate lamps but not sure) if the P.O has changed the front side lamps for LED type this will often cause a bulb fail sig! (LED's that dont produce a bulb fail sig are available, try ebay)
Mark
techcareuk is offline
#6 Old 02-10-2010
The Bulb Failure light turns on a few second later when I switch headlights on. It doesen´t react on side lights or other lights. Engine must be running as well. If engine is turned off, but headlights are on, failure light does not light up.
any new ideas??
Kaaleppi is offline
#7 Old 02-10-2010
Oh.. and bulbs are normal H7 55W and always has been.
- Kaaleppi
Kaaleppi is offline
The Following User Says Thank You to Kaaleppi For This Useful Post:
#8 Old 02-10-2010
Vehicle: 2000 SLK 230
any new ideas??
Shouldn't the bulb warning light come on with the rest of of the warning lights & go off after you start the engine ?
It does on my car .
notanumber is offline
#9 Old 02-10-2010
Yes it does, but after 2-3 seconds when other lights turns off, it turns on again.
Also all headlight connectors are in good shape...
- Kaaleppi
Kaaleppi is offline
#10 Old 02-11-2010
techcareuk's Avatar
it sounds like its definitely related to the headlights, you have confirmed the bulbs are standard so my next suggestion that uprated higher wattage bulbs may be causing this does not apply, although i'm unsure that if damage may be caused to the bulb failure circuitry if were installed at earlier date? perhaps another member could confirm this?
in any case i'd say you definitely should be looking at the headlights to be causing this
HELP - Kleemann alloy needed! Dr Tom New Members Introduce Yourself Here 7 01-31-2010 02:50 AM
HELP - Klemmann alloy needed! Dr Tom AMGs 1 01-30-2010 03:15 PM
Some Help Needed stuarm SLK R170 General Discussion 7 06-27-2009 02:27 AM
Interior parts needed Rymdragon SLK R170 General Discussion 2 02-08-2008 06:47 AM
