Code reader? - Mercedes Benz SLK Forum
#1 Old 02-04-2010
stevej's Avatar
Vehicle: Mercedes SLK 200
Other Toys: I want a boat !
Code reader?
Anyone know a uk based placed to get a decent code reader for my r170 year 2002 ?
stevej is offline
#2 Old 02-18-2010
Try Ebay, that's your best bet.
#3 Old 02-18-2010
stevej's Avatar
What would be the best one to go for ?
I would really just like to diagnose problems when the light appears on the dash...
stevej is offline
#4 Old 02-18-2010
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
Auto Zone has them from $59 up to $200.
I was looking at them yesterday. I did not catch the brand names. They keep them behing the counter.
FYI--- SLK230 code reader plug is under dash just behind the hood release. Take off plastic cover to access the plug.
SLKman is offline
#5 Old 02-18-2010
designo?'s Avatar
Vehicle: '01 SLK 320 Bahama Blue
Other Toys: Phaeton '04, ML500 '02, SLK320 '01, 525ia '89, 944 '85.5, 928 '80, 928 '80
I'm afraid generic OBD code readers are next to useless for our cars. Don't waste your money. I would suggest getting a dedicated reader from like carsoft with a multiplexer. It is more expensive but will surely pay for itself. More info can be found here:
http://www.benzworld.org/forums/r170...oft-7-4-a.html
designo? is offline
#6 Old 02-18-2010
Vehicle: 2009 Slk 200k sport pack
Other Toys: Mercedes 190E RS
if you have plans to come to belgium this summer I can give you a adres on a sore that sels these reader I got one it cost me 260€ but he has cheaper ones to.
don't know howe the price per value is.
I'l post the link.
http://www.diagnoseapparatuur.nl/sca...obd1-obd2-eobd
it's all in dutch, but google translate will fix that
Dimi190E is offline
#7 Old 10-13-2010
V6SLK's Avatar
Vehicle: 2003 SLK 320 Magma Red
Other Toys: Honda Valkyrie motorcycle
Has anyone tried the Equus 3130 live data OBDII code reader on the R170? I am considering buying one but not sure if it will read the codes or record live data...
V6SLK is offline
#8 Old 10-18-2010
Vehicle: SLK 230 Silver
Other Toys: ZZR600,Trooper, Honda
So you were trying to tell us that the code reader depends on the brand and price? the higher the price the more functions and codes it gives? or it depends on the user's technical capabilities? I was also eyeing on buying one scantool code reader..thanks for the inputs?
shombol is offline
#9 Old 10-18-2010
V6SLK's Avatar
From what I've learned so far, the price of an OBDII (or OBDI) code reader is dependant upon the features you want such as live data recording, back lighting, freeze framing, on board most likely problems associated to the diagnostic code (rated hightest to lowest) that was read, and ABS problem codes. Some have a book with code definitions per vehicle. Others have CDs or you just go online to the mfrs. website to decifer the codes. Some use serial ports to upload to a PC to use in a report or graphic display, others use USB connectors. Some also allow downloading newest firmware when updates are available. I myself am confused about statements indicating a standard OBDII code reader is useless on our Mercedes cars considering the world standard is OBDII or CAN. If they are useless then Mercs standard would not be OBDII it would be proprietary. Is that what I am hearing out there? Or is there minimum info available about the codes that ARE read? Pls someone enlighten us....
V6SLK is offline
The Following User Says Thank You to V6SLK For This Useful Post:
#10 Old 10-18-2010
Vehicle: 2003 SLK 230. Speer pulley kit. Depo euro headlights with led. Led taillights
Have you checked out this video?
http://www.amazon.com/Equus-3130-Diagnostic-Playback-Capability/dp/B000KID31K
Mantist is offline
#11 Old 10-18-2010
V6SLK's Avatar
yes...that is a good intro to how the readers work. Recommend it to anyone thinking of one. My concern is the propriety of the Merc codes though and if the 3130 would have any trouble reading them and/or decifering what the trouble may be.
V6SLK is offline
#12 Old 10-19-2010
So far I have only been reading missed fire codes. There may be better units around that cost more but the 3130 is good enough in terms of price and features. However it does not read ABS and transmission codes.
Mantist is offline
#13 Old 10-19-2010
V6SLK's Avatar
Thanks...are you able to see/read live data from your SLK or just that code?
V6SLK is offline
#14 Old 10-19-2010
Live data, custom live data, record live data, trigger on DTC, etc. all there on the display. I connect the unit everytime I drive and I can set it to trigger on dtc or just read live data.
Mantist is offline
#15 Old 10-20-2010
V6SLK's Avatar
Great...Is there enough info about the SLK DTCs either with Equus on the CD, online, or other sources? Thanks Mantist.
V6SLK is offline
#16 Old 10-20-2010
All the code defintions are very basic. It is on the cd and on line.
Mantist is offline
#17 Old 10-20-2010
Vehicle: 2006 SLK280 (Mars Red)
Other Toys: 1999 Harley Fatboy (FLSTF)
Chats: 3
Thanks for the information on the 3130...looks like a great tool.
Not bad for under $150.00
Enjoy,
Dave
FLSTF is offline
#18 Old 10-24-2010
Other Toys: Boats
I have a Actron CP9180 AutoScanner and I can read codes and some live data from the system. There are generic things like coolant temperature that can be read, but things like transmission fluid temperature can not be read by this generic scanner.
The codes are in the Chrysler Crossfire manual if you have access to one.
ClemsonB is offline
Problem with my spare remote kpalmer SLK R171 General Discussion 11 03-15-2010 08:06 AM
Where can i buy a code reader ? stevej SLK R170 General Discussion 1 01-26-2010 04:44 AM
AMG crest on Gear lever, part no code please alroumi SLK R171 General Discussion 28 01-12-2010 09:00 PM
