connecting long term trickle charger - Mercedes Benz SLK Forum
  • 1 Post By Woolly
  • 1 Post By PeterWeb
#1 Old 02-02-2010
steev999's Avatar
Vehicle: 1998 slk 230 kompressor
hi all,
been reading that it is okay to leave the battery on a trickle charge over winter, is this okay?
also, i believe that there are points on the car to connect the charger to, other than the battery itself, is this correct please, and if so where?
dont want to do any damage!!
thanks
steev999 is offline
#2 Old 02-02-2010
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Hi Steve, as long as you use a charger that is designed to be connected permanently, you shouldn't have a problem - I leave my SLK and bikes connected all winter, and never had a problem yet.
Not sure on the R170, but on the R171 there is a +ve connector under a red flap near the front RHS strut (on the other side on LHD cars).
Woolly is offline
#3 Old 02-02-2010
Corkscrew would leave the battery trickle charger for 6 months when he is overseas with no problems. You would want to use a "smart" battery charger that can go from regular charge to trickle charge to maintenance mode as needed. Some brands include CTek and Battery Tender.
#4 Old 02-02-2010
Ynot's Avatar
Quoted: 23 Post(s)
I have mine connected 2 to 3 months at a time, been doing that for 4 years now, no problems.
997 TPC turbo C4S
981 Boxster S
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR. (Gone but not forgotten)
Ynot is offline
#5 Old 02-02-2010
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by etyu View Post
. . . Some brands include CTek and Battery Tender.
Or in the UK OPTIMATE or even THIS little Halfords one - I have 4 of these, and on the SLK and BM bike, I leave them connected and powered up from November till when the salt goes, without any problem whatsoever.
Chrissy Landar likes this.
Woolly is offline
#6 Old 02-03-2010
steev999's Avatar
thanks for the replies folks, i will be connecting it this weekend!!!
steev999 is offline
#7 Old 02-03-2010
Vehicle: 2003 slk32 amg black
or you can be like me, i hook my trickle charger to the garage light with one of those light socket to plug adapter. this way my battery gets a little charge every time i use the garage door opener.
pi_4x4 is offline
#8 Old 04-19-2016
PeterWeb's Avatar
Vehicle: SLK230 2001
My car is berthed outside so I chose the solar option - thanks for all those who have provided information on the various issues.
I've created a permanent connection point to my battery with a fused, capped 12V female plug which exits the engine cavity out in the direction of the windscreen. Normally it is tucked and lightly cable-tied out of the weather alongside the black fin that runs across the car below both windscreen wipers (visible when you open the bonnet). The plug has just enough cable length to be accessible from above when removed from its cable tie and pointed directly up the windscreen.
When I go away for a week or more, I use a 10W solar panel (10W Solar Cell solar panel 10Watt 12 Volt Garden Fountain pond Battery Charger +Diode-in Solar Panel from Computer & Office on Aliexpress.com | Alibaba Group) connected in line with a solar charge regulator (http://www.aliexpress.com/item/3A-6V-12V-PWM-Solar-Panel-Light-Controller-Battery-Charge-Regulator-Intelligent/32643474438.html). There's enough length in the panel cables to run it through a small hole in my car cover, and strategic strips of velcro keep the panel in place whatever the wind does.
Total cost of this entire setup was about $US35 delivered - mainly the panel - and about an hour's work.
slkDennis likes this.
PeterWeb is offline
#9 Old 04-20-2016
Chrissy Landar's Avatar
Vehicle: Mercedes SLK 350 R171. 2010.
Other Toys: Honda 16" lawnmower.
Quoted: 77 Post(s)
battery care
Another vote for the Optimate, we have the same set up as Wolley, As soon as the salt season starts our Honda VFR and SLK are connected up to the Optimate and we have never had any trouble with the batteries over the winter months.
Chrissy Landar is offline
Battery Trickle Charger pre-wiring install etyu General Modifications R171 80 3 Days Ago 01:56 PM
trickle charger question - winter storage boomie SLK R171 General Discussion 5 12-09-2009 09:48 PM
will BMW 12V trickle charger work in SLK55 mintzert SLK R171 General Discussion 3 11-18-2009 01:11 AM
Trickle charger + car cover? iPPi SLK R171 General Discussion 12 12-12-2008 04:05 PM
small issue after Battery drain vegeta SLK R171 General Discussion 11 09-27-2007 12:37 AM
