Radio and other issues - Mercedes Benz SLK Forum
#1 Old 01-18-2010
Vehicle: 2001 SLK 320 Sport
Other Toys: bikes, aircraft
The Alpine radio installation in my 01 320S turned out to be quite easy. You use a VW harness and just figure out the wiring changes. Works though the existing amp and speakers just fine. I put the USB lead and the Ipod plug in the glove box. While I was doing it I also installed the in line fm modulator for the satellite radio which worked great. I like the portable satellite receiver. Don't want to buy 4 subscriptions. I put the satellite antenna under the dash as finding a place on the external vehicle is brutal. The trunk bonnet is out because of its articulation and the rest of the car doesn't seem to have a decent flat surface.
I live 200 miles from the closest dealer and the local radio shops wanted nothing to do with the installation. The first install I was careful but now that I know how to do it its a 45 min. job. So those of you out there that want to crawl out of the 20th century for your audio don't be afraid. You are loosing your CD changer in the trunk but I wasn't using the thing anyway.
Nothing is damaged and its a 10 minute job to remove the new radio and put your old factory unit back in.
John Braun is offline
#2 Old 01-18-2010
-1-
Don - Founding Member #4
-1-'s Avatar
Good job. A up-to-date aftermarket stereo system is a good investment. Curious about your satellite reception with the antenna UNDER the dash. Doesn't take much to lose the signal. If it works, great. I normally mount mine on the dash or rear deck with good results.
-1- is offline
#3 Old 01-19-2010
I haven't had any problem with it so far. Actually the radio works okay with just the built in antenna. Just a little static now and then. Works in the house also without the antenna headphones. Its a Stiletto 2 from Sirius.
Thank you.
#4 Old 01-20-2010
Las VegasCop's Avatar
Vehicle: 2001 SLK 230 Auto
Actually I had both Sat and GPS antennas under the middle of the dash. What I found is that the GPS works perfectly but I was losing sat radio in certain spots. I moved the sat antenna to the originally mounted place in the middle of the drunk. Had to fibricate it a little but now no problems! NONE....love the system now. The CD changer is obsolete! Who cares about CD's if you have an iPod nowdays....
Ski
Las VegasCop is offline
#5 Old 01-20-2010
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
Good to hear it is that easy. I have been concidering a new radio too.
What radio model did you put in?
Where did you get the harness and do you have a pert number?
Do you have pics of it?
SLKman
SLKman is offline
#6 Old 01-21-2010
#7 Old 01-21-2010
I used the CDA -105 Alpine. It uses a standard vw wire harness but you have to be sure and check what wire is what as the wiring schematic I got off the SLK site was not the same as mine. No big deal just checked each wire and moved the pin in the connector. You will need a antenna adapter. The wiring harness is 95 volks and up. I did not take any pictures.
