r170 rear speakers - Mercedes Benz SLK Forum
  • 1 Post By mavrick77
#1 Old 12-30-2009
Vehicle: 2001 slk 230
r170 rear speakers
hi i have a 2001 230 can i fit rear speakers? are there holes in back board.
harv is offline
#2 Old 01-11-2010
Vehicle: 2002 SLK32
Other Toys: Kawasaki ninja zx14
Send a message via Yahoo to silverpassion
Yes there are.
silverpassion is offline
#3 Old 01-11-2010
Vehicle: 2000 SLK 230
How to fit standard speakers in the holes here
notanumber is offline
#4 Old 01-12-2010
rear speakers
thanks for the replies it seems like a lot of work to fit them. i will have to rethink what iam going to do.
harv is offline
#5 Old 01-13-2010
Las VegasCop's Avatar
Vehicle: 2001 SLK 230 Auto
There's not that much work man. I put subs in mine and it was simple!
Las VegasCop is offline
#6 Old 01-13-2010
rear speakers
only had car 2 weeks the wife will kill me if i start ripping it apart. i think i will wait a bit longer.
harv is offline
#7 Old 10-29-2010
Vehicle: R170 230K
Does any one know what size speakers will fit in the hole ?
Im guessing, that bose put a non standard size in, but if i adapt it i can fit 6.5" ?
beanie is offline
#8 Old 10-30-2010
The holes were designed for rear facing speakers ,you need to adapt the mounting area as in the link I previously posted to fit standard speakers .
6.5" speakers will fit
Below is a picture of a factory rear speaker.
The Following User Says Thank You to notanumber For This Useful Post:
#9 Old 10-30-2010
mavrick77's Avatar
Vehicle: 1999 SLK 230 Kompressor
I have CDT speakers in my car....they make 6.5" shallow mount speakers....BEST SPEAKERS I HAVE EVER OWNED.. alot of competition guys use this. I used 6.5" subwoofer/woofer in rear...and 6.5" Mid/HIGH in the front..and then used Clarion tweets (I like clarion tweeters) in the front doors... I Then tied it all together with a punch Amp...
Rear speakers are ran at 2 ohms @ 180 watts per channel
front speakers are ran at 4 0hms but ran parralel with tweets so probably dropped ohms to 3... so would roughly put 140 per channel (at that ohm)... so when buying speakers pay attention to your ohms
Then everything is ran thru High def pioneer radio, with flash drive.
sounds much better then stock... make sure you also use your crossovers...the amp will have a High / low crossover for your fronts and rears (lows cross for rear, high cross for front)... then since your tweets are tied into your fronts, use another crossover in your parrallel run AFTER your front speakers going to your tweets to run them at a higher frequency....
hope this helped some.
richebenedetto likes this.
mavrick77 is offline
#10 Old 02-19-2013
Vehicle: SLK 230 Kompressor 2002
I'll bump this. I'm thinking about doing this. But it looks like A LOT of work!
Are you sure it was simple? Do i really need to do all the things on the guide that was posted?
And is it possible to fit 10" subwoofers in the holes? With some modification? Regards Tim
TimPonken is offline
#11 Old 12-12-2013
Vehicle: 2002 SLK
Send a message via AIM to easystbob
10 inch subs in back of 2002 SLK?
Is there a easy to do this. I'm willing to cut into metal. Is there room - depth wise? Do you access it from trunk?
easystbob is offline
#12 Old 12-12-2013
Quoted: 6573 Post(s)
easystbob,
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’! If Iphone pics, you need to rename any additional pics as Iphone names its pics all the same,image.jpg.
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car) free. https://www.slkworld.com/vehicle-data-card/
#13 Old 12-12-2013
JiminFL's Avatar
Geez, ou guys are looking for something easy and then you want to put in 10" woofers and cut out sheet metal. As soon as you get away from stock, it's going to get incredibly difficult to get it right. I have the stock speakers in my car and they are balanced and sound great, even with the top down and the volume up.
JiminFL is offline
#14 Old 12-13-2013
leapyfish's Avatar
Between the wall behind the seats & back wall of the trunk is the gas tank, be careful of what you cut or cut into!
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#15 Old 03-04-2014
Other Toys: Guitar & Drums
I just installed a Jensen 7 inch pop up screen head unit and a Jensen 65 watt amp (in the trunk) in my 01 SLK320. I also installed rear speakers in the provided mounts. Had to "adjust" the speaker mounting screw holes but that's it. I'm changing them now though cause I want woofer, subwoofer only. I did manage to blow the fronts...whoops! Bose speakers didn't handle it.
Cheers!
richebenedetto is offline
Recommendations for upgrading R170 front door speakers? atebit General Modifications R170 5 08-27-2016 12:24 AM
Rear Speakers wingman SLK R171 General Discussion 1 05-26-2009 05:10 PM
noise from rear speakers arosamond SLK R171 General Discussion 19 01-02-2009 01:06 AM
Radio balance fwd to rear speakers SLKman SLK R170 General Discussion 12 09-28-2006 06:00 PM
Those rear center console speakers bclark SLK R171 General Discussion 43 08-15-2006 09:17 PM
