Spark plugs after 115K miles - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By ksfoster
  • 1 Post By ksfoster
#1 Old 03-24-2014
ksfoster's Avatar
Vehicle: 2002 SLK230
My Check Engine Light came on so I took my car in to find out what it was. While it was in the shop the mechanic informed me that my car still had the original spark plugs from 2002 - 115K miles!
Needless to say, I changed them.
JaysonM and Iron Sight like this.
ksfoster is offline
#2 Old 03-24-2014
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 95 Post(s)
Got the money's worth out of those! They still don't look as bad as I've seen in some cars!
fastdawg1 is offline
#3 Old 03-24-2014
Mine looked the same when I pulled the off at around 112k =)
It makes it worth every penny =D
#4 Old 03-24-2014
Iron Sight's Avatar
Vehicle: 2012 SLK 350
Quoted: 15 Post(s)
Would be interested to know what the electrode gap is after that much use?
Pic looks like around 1/8" (.125)
Thanks for the photo.
Iron Sight is offline
#5 Old 03-25-2014
Vehicle: 2005 SLK350 MT
Quoted: 19 Post(s)
Pic looks like around 1/8" (.125).
Neither the center electrode nor ground electrode look very worn so gap should be as new at .040 or 1 mm. I cannot see why these plugs would cause a CEL so perhaps OP could comment. Sure change them but were they the cause of the CEL?
Gordon
gdb069 is offline
#6 Old 03-25-2014
ksfoster's Avatar
Gordon
Sorry about that, I should have been clearer. The CEL turned out to be due to a faulty relay switch in my brake pedal. While the car was in the shop they did a thorough inspection and that's how I found out that I needed to change the plugs.
The funny thing is that a few weeks ago I took my car into my local Autozone and had them use their generic code reader to tell my why the CEL was on. The guy pulled P0140 as the error code, which is something related to emissions - either an O2 sensor or a malfunctioning MAF sensor. After doing a little research I estimated that it would end up costing between $300.00 to $600.00 to repair, so I budgeted $600.00, took it to the shop yesterday and crossed my fingers. The guys called me an hour and a half later to tell me that the CEL was due to a faulty relay switch that sends the signal from the brake pedal to the computer. He then told me that my rear brake rotors and pads needed to be replaced (which I knew, I was just procrastinating on doing the brake job because brake dust is nasty and I hate doing it) and that I was still running the original spark plugs.
Now, I do all the maintenance on my cars because I don't like paying someone else to do something I can do myself. He said it would be $200.00 to change out the brake pedal sensor and $350.00 for the brakes. I did some quick math in my head and realized that was a pretty good price for the brake job (did I mention that I had been putting off doing the brakes because brake dust is nasty?) and I really didn't want to mess with the brake pedal relay. So far so good.
Then he tells me he can change out my plugs for $192.00. I almost laughed out loud into the phone. After regaining my composure I politely declined, told him to fix the brake pedal relay and do the rear brakes. I then spent $30.00 on a new set of spark plugs and when I got my car home yesterday afternoon I changed them in about 20 minutes,
All in all I think it turned out to be a good day. I was planning on spending $600.00 to have the MAF sensor replaced and I ended up spending $590.00 to get a rear brake job, replace a faulty brake pedal relay switch and change my spark plugs.
Long story short (too late) don't believe anything you get from a generic $20.00 code reader. If your CEL comes on take it to someone who has a code reader calibrated for a Mercedes.
Oh, and change your damn spark plugs!
El_Murcielago likes this.
ksfoster is offline
#7 Old 03-25-2014
ksfoster's Avatar
I just checked all four plugs - still .040.
ksfoster is offline
#8 Old 03-25-2014
Quoted: 19 Post(s)
Originally Posted by ksfoster View Post
Sorry about that, I should have been clearer. The CEL turned out to be due to a faulty relay switch in my brake pedal. While the car was in the shop they did a thorough inspection and that's how I found out that I needed to change the plugs....
Sounds like a very good shop. Full brakes by MB here was quoted at $1800.
Re: brake release switch or travel sensor were you getting a BAS/ESP light ?
Gordon
gdb069 is offline
#9 Old 03-25-2014
ksfoster's Avatar
Gordon
Its one of two shops in town that specializes in European sports cars. They had great reviews on Google and I'm going to add another one.
It wasn't the BAS/ESP light, it was the check engine light. Who would've thought?
Another interesting tidbit - the mechanic asked me if I had noticed any loss of power or performance. I told him that I drive pretty conservatively and don't really take advantage of the supercharger much, but that I have noticed lately that the car no longer downshifts at the touch of the accelerator like it used to. Now to get it to downshift I have to floor it. He explained to me that this car adapts you your driving style and learns how you drive over time. That's why its not downshifting as quickly as it used to. He offered to clear it out so that it would drive like it did when I bought it but after thinking about it I decided to leave it as it is. After all, if I really need the power its still there, I just have to put the pedal to the floor.
I was pretty impressed that a 12 year old car has that technology.
ksfoster is offline
How to change SLK230 Spark Plugs SLKman Performance MODS for the R170 17 08-09-2012 05:15 PM
Lasers for Spark Plugs Swagman General Discussion 4 04-26-2011 09:34 PM
