OBD for early R170 on the cheap - Mercedes Benz SLK Forum
 11Likes
#1 Old 03-20-2014
PaulXLE's Avatar
Vehicle: SLK 230 Kompressor R170 auto 1997 in Imperial Red
Other Toys: Mostly computers, lots of them, opening a museum one day, maybe.
Quoted: 8 Post(s)
Thumbs up OBD for early R170 on the cheap
I just thought I'd share my experience of getting the On Board Diagnostics working for my early R170, all for next to nothing!
on older R170s the socket is under the bonnet, as pictured:
from eBay I purchased a "MERCEDES 38 PIN OBD to ODB2 16 PIN CAR FAULT CODE DIAGNOSTIC ADAPTER CABLE" or "38 Pin to 16 Pin OBD2 Female Adapter Connector Diagnostic Cable for Mercedes" - or something like that, descriptions vary, but there's one pictured above.
then I bought an Autel MaxiScan MS300 CAN OBDII scan tool, though I actually bought this for a modern car, it appears to work in conjunction with the 38 pin adapter above.
then I bought a "ELM327 OBDII V1.5 CAN-BUS USB Auto Code Reader Diagnostic Interface Scanner" - again several titles are used, which comes with a little CD (which can be a problem, I only had one PC that would accept it). Loading the software on an old Windows 7 netbook was pain free, and you end up with a vaguely amateurish open-source program which displays the data. (I would NOT recommend updating this to a newer version from t'internet, this did not work for me) - oh and the program is sadly incomplete, it has menu items that don't work. Though... you do get the source code too, so if you're software savvy you might be able to DIY!
so, the MS300 gives you a small amount of info, really just the codes and maybe the ability to switch off a check light.
the ELM327 in conjunction with a laptop gives you much more info, and can be used with the engine running to get 'real time' data.
Total cost:
38 pin adapter : 5.69
ELM327 : 7.50
Maxiscan MS300 : 9.99
the only slight worry I have... is that neither actually gave me any codes! Yes, I know, I should be happy... and there's nothing wrong with the car that I know of... but I guess until I see a meaningful code come up I won't know for sure if it's working or not.
Happy to share experiences about this with anyone.
PaulXLE is offline
The Following 3 Users Say Thank You to PaulXLE For This Useful Post:
#2 Old 03-20-2014
nz170's Avatar
Vehicle: 1999 230 SLK
Other Toys: 1980 Daimler (Jaguar) Sovereign 4.2, 1962 Morgan (NZ) launch, folding eBike
then I bought an Autel MaxiScan MS300 CAN OBDII scan tool,.
I did also but cannot get it to power up when plugged into the car. The scan tool powers on when 12 v. is applied to the appropriate pins. The supplier sent a replacement adapter cable, but it still won't power up.
nz170 is offline
#3 Old 03-21-2014
PaulXLE's Avatar
Quoted: 8 Post(s)
Cool
Well, all I can suggest is that it was a bit of a fiddle to get the 38 pin plug to seat properly in the car's socket.
I'm wondering if you're not pushing it in hard enough, though care is needed, it is all a little fragile.
PaulXLE is offline
#4 Old 03-21-2014
nz170's Avatar
Seems to seat well, and it's keyed to go on only one way. Still nothing despite a good amount of fiddling. Will have an auto electrician give it a look. BTW, the dealership got readings on their equipment when I checked out the purchase a few months ago, so the in-car system is OK.
nz170 is offline
#5 Old 03-25-2014
PaulXLE's Avatar
Quoted: 8 Post(s)
I don't know what to suggest, unfortunately...
however, heads up for UK members!
The April 2014 edition of "Car Mechanics" has a good article on early SLK electronic diagnostics, on a 230, wiring diagrams, all sorts of interesting info.
Avel Du and A001 like this.
PaulXLE is offline
The Following User Says Thank You to PaulXLE For This Useful Post:
#6 Old 03-26-2014
ajberrow's Avatar
Vehicle: 2001 R170 230K
I have a similar ELM327 ODB2 device.
I was advised not to use the supplied software because "it's bug-ridden and may be a vector for malware". It may be a good idea to uninstall the supplied software and then run virus and malware scans, to be on the safe side.
If you have an Android device, install the Torque Pro application for about 5 from the Play Store.
If you have an iOS device, install the EOBD-Facile application for free from the App Store. There's an in-app purchase option for an improved version, costing about 11.
Both will connect to the ELM327 device via Bluetooth and are be able to pull and clear codes for you. Both also allow you to see real-time data (revs, temps etc).
I'm told that the proper MB Star software is more accurate, but I've never seen a price for it, nor a web site where it can be downloaded. If anyone knows the details, please post them.
EDIT
Also, make sure you unplug the device when not using the car. Some folks on the forum have found that it can flatten the battery within 2-3 days.
ajberrow is offline
The Following 2 Users Say Thank You to ajberrow For This Useful Post:
#7 Old 03-26-2014
Vehicle: 2000 SLK 230
Other Toys: 09 Kawisaki Concours 14
they don't have the OBD-2 port on your cars over there???
gonzosc1 is offline
#8 Old 03-27-2014
PaulXLE's Avatar
Quoted: 8 Post(s)
not on early ones... I don't know when the newer port was fitted, in the foot-well, but I imagine it's post face-lift models?
PaulXLE is offline
#9 Old 03-27-2014
Quoted: 1138 Post(s)
These cheap obd readers are very cheap and basic .
And may or not work you pays your money and well hit or miss.
Id pay a bit more to get something much more reliable to get codes / re set etc
Delucas is offline
The Following User Says Thank You to Delucas For This Useful Post:
#10 Old 03-27-2014
someone correct me if I'm wrong. I think after 95-96 all cars here had to have the ODB-2 port.. may just be a US thing but I don't know..
gonzosc1 is offline
#11 Old 03-28-2014
nz170's Avatar
Would you scan the article and post it for we non-UK members? Thanks. It's not available on the magazine's website.
nz170 is offline
#12 Old 03-29-2014
Joakim Muth's Avatar
Vehicle: -97 SLK230 OMG Divine Edition
Other Toys: 28' wooden Sailboat
In the US all cars manufactured after 95/9 have to have OBD-2 port, in EU it is from 2001 they have to have EOBD ports.
gonzosc1 likes this.
Joakim Muth is offline
#13 Old 03-31-2014
PaulXLE's Avatar
Quoted: 8 Post(s)
Cool
Well... the article is in the current issue, and I think there might be a copyright problem with posting it on the forum!?
nz170, I will PM you later about this...
PaulXLE is offline
#14 Old 09-13-2014
Vehicle: 1999 SLK 230 Silver 120,000 Miles
Other Toys: 1995 Triumph Thunderbird 900 Triple 18,000 miles Black
38 pin to OBD2
Nice post. I am trying the same kind of setup, unfortunately I can't establish a link. I purchased a 38 pin to OBD2 from Amazon, along with my Actron scanner which was $100 plus so not a bad one. I have attached a few photos any ideas as to why I can't link?
slik98 is offline
#15 Old 09-15-2014
PaulXLE's Avatar
Quoted: 8 Post(s)
Originally Posted by slik98 View Post
Sorry, no. Well, apart from the fact that the ignition needs to be on for it to work I guess, that's all I know. And as I mentioned before, I did have a bit of bother seating the big round plug properly, I guess you've given it a good old wiggle?
PaulXLE is offline
#16 Old 07-06-2015
Vehicle: 2002 slk 230
Quoted: 21 Post(s)
con
Hi I too bought an adapter from flea bay, and it wouldn't work just a red light on the odb device, I took the adapter apart and there was only 3 wires in it, what a load of rubbish
allenhh is offline
#17 Old 07-06-2015
Question
Has anyone tried one that would talk (Bluetooth) to their phone? (If so, did that seem very useful?)
lilred320SLK is offline
#18 Old 10-12-2015
3 wires is all that is needed: ground, +12 V and data.
janil is offline
#19 Old 10-16-2015
Quoted: 21 Post(s)
janil I stand corrected, but it begs the question, what do all the other 30 odd pins do?
allenhh is offline
#20 Old 10-17-2015
Connector design is from era before OBD-bus. There is room for dedicated connection to each separate control module in the car. I think more sophisticated diagnostic systems, like Star, use those pins to access features in some modules of R170, which are not available through OBD.
janil is offline
Tags
38 pin, elm327, ms300, obdii, odb
R170 interior, supercharger, diff, hubs, doors, calipers for sale in merseyside kwthomas064 SLK Parts For Sale 5 02-21-2014 07:42 AM
Silver SLK R170 for sale sussex cheap! nimbusgb United Kingdom Region 0 01-31-2014 03:34 AM
Does Basset Slooper counts 4 a R170 Problem Berliner Heckflosse SLK R170 General Discussion 3 03-16-2012 12:22 AM
