SLK 230 Auto Transmission - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By peter kewowo
  • 2 Post By legendary620
#1 Old 12-12-2009
I would appreciate some guidance from someone. I have just bought an SLK 230 automatic first registered in 2000 and it has done 77,000 miles.
Everything is Ok with one exception.
When pulling away from stationary, sometimes there is no increase in revs for about two to three seconds and then the revs rise and the gearbox then behaves totally satisfactorily.
I have had the gearbox oil and filter changed because there was a suggestion that the gearbox filter might have been blocked. My view is that the gearbox is OK and the problem lies in the accelerator system.
Unfortunately I have not yet been able to acquire a workshop manual and I wondered if anyone could suggest what may be causing this intermittent problem
cchristianson is offline
#2 Old 12-12-2009
Quoted: 6554 Post(s)
And finally, if you find something useful on your visit here today, please consider donating for hosting and licensing fees to the site. Even $5 is welcome! Thanks!
#3 Old 12-19-2009
Vehicle: 96 SLK 230K
Other Toys: Samurai
Chats: 39
Hi, and welcome :hutab:
Is it the same with ASR turned off?
Gabus is offline
#4 Old 12-19-2009
JFR
JFR's Avatar
Vehicle: SLK 320 BVA red amber 2002 + SLK 55 AMG red thulite 2007
Hi ,
you should have a look to the MAF ( air flow controller )
Have you a green air filter ?
JFR is offline
#5 Old 12-27-2009
Las VegasCop's Avatar
Vehicle: 2001 SLK 230 Auto
Your throttle is fly by wire....controlled by the computer. I heard that you have to reset something to get that response again. I never had that problem first hand, just remembered reading about it couple months ago. That could be your issue?
Ski
Las VegasCop is offline
#6 Old 12-28-2009
leapyfish's Avatar
Is this a cold start up, then put the car in gear and drive away, or do you let the engine warm up.
the slk engine needs to warm up a little or it will resist shifting into higher gears.
here's a few other things to look at
Tech info http://www.buellwinkle.com/r170/default.htm
MB parts http://www.detali.ru/cat/oem_mb0.asp?TP=1
MB USA owners manuals http://www.mbusa.com/mercedes/#/servPrtsOwnersManuals/
VIN decoder http://old.mbclub.ru/mb/vin/?lng=eng
SLK info http://www.buellwinkle.com/r170/default.htm
SLK roof troubleshooting http://www.benzworld.org/forums/r170...ml#post3582000
Squeaking roof http://www.benzworld.org/forums/r170...-1-krytox.html
****etins http://www.billsden.org/mercedes/slk/docs/
leapyfish is offline
#7 Old 04-14-2014
my 2000 elk 230 compressor is overheating badly & it produces sound, what could be the problem the dealers I took it to they are telling me I need to get a new gearbox. What is your advice could it be the gearbox?
Cheesecakecolin likes this.
peter kewowo is offline
#8 Old 04-14-2014
Vehicle: 1999 SLK 230 automatic
Other Toys: Old Honda's CB 350/CB 750
Please start your own thread instead of posting on someone elses.
jbanks15 and kevvy like this.
legendary620 is offline
#9 Old 04-14-2014
I have the same issue with my start off acceleration. I was told by members on here that it's a common issue and I should look into buying a performance enhancer called "Sprint Booster" or a "Power Converter". Looks to be about 400 bucks but people are really happy with them.
I also tried the tranny reset and had problem persisted but the shifting did get quicker once she got rolling.
#10 Old 04-15-2014
Quoted: 11 Post(s)
its not set in winter mode is it
beerbelly is offline
#11 Old 04-15-2014
original thread is also over 4 years old!!!
#12 Old 04-16-2014
Hahahahahaha.
1997 slk 230 intermittent limp mode peteslk SLK R170 General Discussion 2 11-04-2011 06:56 PM
WTB SLK 230 or 320 MANUAL roman2k SLK Cars For Sale 1 12-10-2009 07:18 PM
Newbie 2000 slk 230 captainmark New Members Introduce Yourself Here 17 11-03-2009 04:03 PM
