PSE Pump - Mercedes Benz SLK Forum
  • 1 Post By LoveMeSomeSLK
#1 Old 03-14-2014
Vehicle: Mercedes SLK 200 Kompressor
Other Toys: E46 330di
PSE Pump
Hi All
I need to source a PSE pump for my 2001 SLK 200 Kompressor and the part number its fitted with is 1708000848 and i can't get one of these in the UK. I have seen on eBay of a 210 800 02 84 which fits a 210 or a CLK now visibly these look exactly the same so has anyone got any insight on this part and do they know if they are inter changeable.
RichPC is offline
#2 Old 03-14-2014
Vehicle: 2001 SLK 320 ^-speed
Other Toys: 1981 Honda CX500D, 73 El Camino, Model A based Rat rod
I would bet the only real difference might be at mounting configuration. If the plug and pull y look right and the mounting depths look close you could probably get it in with a simple bracket mod. May even get lucky and it fits right in. Depends how brave you are really. Might want to hold out for the exact part number. Look on eBay for someone parting out a whole car and contact them. Might not have posted it yet.
kdashby is offline
#3 Old 03-18-2014
So a 2108001348 arrived last night and it fits perfectly and the hazards don't flash (which they did on the damaged on) put it doesn't work the central locking (it only keeps the drivers door open). Does anyone know if there is a fuse as well as this pump that may have blown or any other idea's why the 210 PSE Pump is not fully working
Many Thanks
RichPC is offline
#4 Old 03-19-2014
Vehicle: 1999 SLK230
From what I've seen and others have experienced, I don't think mix-and-matching PSE's work. Every instance I've read about this, certain things simply don't work. Yes, the size/connectors may match and be very similar, but the parts are simply incompatible. If I'm wrong, someone please correct me.
Do you still have the damaged PSE? It may not be beyond repair. Mine was in awful condition (ridiculous corrosion, and even a broken connector pin) and I was still able to sit down, clean the thing, and make my own pin for it, solder it on, etc. It's been working great for months.
VRG_._ likes this.
LoveMeSomeSLK is offline
The Following User Says Thank You to LoveMeSomeSLK For This Useful Post:
#5 Old 03-21-2014
Vehicle: 1998 slk 230
Other Toys: 1994 lexus ls 400/1990 mercedes 230e
There is info about this on Benzworld..'Greenfire' posted that you need to swap
an IC, MC68HC705X32 FROM THE 210 TO the 170 pump.
Don't think it's easy, but worked for him
royt is offline
The Following User Says Thank You to royt For This Useful Post:
Central Locking System (PSE Pump) jznation SLK R170 General Discussion 4 03-20-2014 01:47 PM
Replaced PSE Pump, Horn Chrips when Ignition in Position 2 MZeraldo SLK R170 General Discussion 2 10-30-2013 03:26 AM
PSE pump MGMGrand SLK R170 General Discussion 2 05-26-2013 07:11 PM
Working R170 PSE Door Actuator Pump BSK SLK Parts For Sale 10 10-18-2011 10:18 PM
