Fault codes - Mercedes Benz SLK Forum
#1 Old 03-07-2014
Vehicle: 1999 Slk230K
Other Toys: 1967 230SL Pagoda
Fault codes
Hi I have a 1999 R170 that shows up two fault codes, P0170 Fuel trim bank 1 and P0303 cylinder three misfire. I swapped no. 3 plug with no. 1 but still got the same result. The strange thing is the car runs and idles quite smoothly with no sign of a misfire. Can anyone suggest where to look next and what the P0170 code means?
Bobo26 is offline
#2 Old 03-07-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
You might want to try cleaning your MAF and check the vacuum hoses for leaks ..
curro101 is offline
#3 Old 03-08-2014
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
You swapped the plug or you swapped the coil pack? The coil pack is what you want to swap.
See http://www.obd-codes.com/p0170
Len
1999 E300D 215,000 miles
sokoloff is offline
#4 Old 03-09-2014
Thanks for the info. I cleaned the MAF last week before I ran any checks. The car is fine on light throttle but if I drive it hard it runs very lumpy on idle. Maybe I need to replace the MAF? This morning I swapped the coil packs over and the P0303 code cleared (misfire on 3) But shouldn't I have seen a fault on another cylinder? and also checked for vacuum leaks, all ok.
Bobo26 is offline
#5 Old 03-09-2014
curro101's Avatar
Quoted: 528 Post(s)
You might want to change the MAF , cleaning doesn't always work , I've even heard of new , non OEM ones , not fixing the problem !
curro101 is offline
#6 Old 03-09-2014
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
I'd wait a bit to see if the P0303 code reappears. Certainly wouldn't replace anything until it does. As for the P0170 that often is a MAF issue. If you do decide to replace it, please read some posts about using a real Bosch MAF vs. some of the aftermarket junk that's out there.
Len
sokoloff is offline
R171 SLK200K running lean....got fault codes..advice please! loanheadhouse SLK R171 General Discussion 7 10-12-2014 09:57 PM
Help with fault codes please synaptoman SLK R171 General Discussion 1 01-06-2014 11:53 AM
Fault Codes On a Used SLK 230 I'm looking at jimithing60089 SLK R170 General Discussion 16 09-02-2013 12:58 PM
SLK intermittently wont crank over - electrical fault finding ?? andyhhh SLK R170 General Discussion 11 09-29-2009 04:41 PM
