How to remove rain sensor housing/rear view mirror? - Mercedes Benz SLK Forum
#1 Old 11-22-2009
Vehicle: 2017 Yellow 718 Boxster
Other Toys: 2018 Tesla Model 3, 2018 Toyota Tacoma
I'm trying to route an mic wire across the big housing cover on the windshield for the rain-sensing wipers (and also where the rearview mirror sits).
The housing cover appears to be two tightly fitted to allow me to get the mic wire behind it. Is there any easy way to remove this cover so I can tuck the wires up under, then replace the cover over top?
atebit is offline
#2 Old 11-22-2009
Chats: 4
Quoted: 31 Post(s)
I could put mine apart just because it fell off... it has two very strong metal clamps that secure the big mirror base housing to the bit that sticks in the windshield. I just stuck a flat screwdriver between both and they popped open. You can't, though, cause the winshield is there! :-/
You can just try pulling but you risk unsticking your rear view mirror and then there'll be TWO SLK owners driving around without one! :-P
Bleen is offline
#3 Old 11-22-2009
Hmm...yea, I think I'll skip that. Still, seems like there ought to be a way to get under there for servicing purposes without permanently damaging the mount.
atebit is offline
#4 Old 11-22-2009
Quoted: 6554 Post(s)
there is as windshield replacement techs do it all the time
#5 Old 11-22-2009
Vehicle: 2006 SLK 350 Designo (sold)
Other Toys: 2007 GL320CDI
lkchris is offline
#6 Old 11-22-2009
Chats: 4
Quoted: 31 Post(s)
Here's some pictures of my mirror.
There's a sensor? that goes in the blank square section in the base, it's dangling from my overhead light cluster right now.
Hope these help...
Bleen is offline
The Following User Says Thank You to Bleen For This Useful Post:
#7 Old 11-23-2009
Vehicle: SLK280
i had to do this too when I was routing my gps antenna across the top. As per my other post "The housing that covers the light sensor(in front of the OCP) can be removed by pushing it forward towards the windscreen and pulling down at same time. Takes a bit of grunt."
See my thread for a picture of it off(https://www.slkworld.com/diy-section/...e-audio20.html), but unfortunately no step by step picture on how to actually get it off, as it was just mainly push forward and pull down at same time.
ghostdunks is offline
The Following User Says Thank You to ghostdunks For This Useful Post:
#8 Old 11-23-2009
Thanks, Ghost. Before I give it a shot, I assume that re-assembly is just the opposite (slide the cover up while pushing in a bit towards the windshield?
atebit is offline
#9 Old 11-24-2009
Vehicle: SLK280
yeah, re-assembly is a doddle compared to getting it off. Similar to what you said, I just pushed mine back on. Once you get it off, you can see where the clamps and whatnot are. I was just worried the first time I did it because obviously I didn't want to be pulling or pushing it in a direction that was just going to break it, and I had to use a fair bit of force to actually pull it off.
Now that i've done it a few times, I'm a lot more comfortable with actually
just pulling it right off.
Good luck!
#10 Old 11-25-2009
Chats: 4
Quoted: 31 Post(s)
Be careful when you take the mirror off the bracket NOT to remove the rain + light sensor unit!
I've been told today that if that happens you're almost certain to damage the unit ($70ish online!). If you just take the mirror off you shouldn't have any problems though.
Bleen is offline
#11 Old 05-02-2015
Vehicle: 2009 350 Palladium silver/black
Quoted: 11 Post(s)
I know this is an old thread but a current problem and the solution not adequately explained. To get the cover off, I saw that the "leg" or "stump" to which the mirror is connected is actually part of the main moulding. So I got a 25mm chisel with the thick plastic cover still on the end, placed it against the stump pointing forward and down and applied extreme pressure.it comes off with a hell of a bang but undamaged and just hangs there on the wire. To get it on, put the roof down, stand up, engage the clips, put both hands round it and pull like hell.
neil66 is offline
The Following User Says Thank You to neil66 For This Useful Post:
#12 Old 05-02-2015
Thanks! We do encourage members, when they can, to update/resolve an old thread.
We discourage posting in an old dated thread, becuase the original poster or additonal poster might be long gone, never to return, and the new poster is waiting for an answer, that will never come.
As an fyi for new members:
https://www.slkworld.com/new-members-...d-how-fix.html
Rear view mirror fell off Bleen SLK R171 General Discussion 16 01-13-2010 06:42 PM
I have a new auto dimming rear view mirror for sale for SLK R171's on ebay if anyone aquascape SLK Parts For Sale 1 09-23-2009 05:42 PM
side view mirror d3athr0w SLK R171 General Discussion 7 05-17-2009 12:04 AM
rear view mirror mazeka SLK R171 General Discussion 3 08-15-2008 04:37 PM
