Clunk under Passenger R170 - Mercedes Benz SLK Forum
#1 Old 03-03-2014
Vehicle: Stock 2003 Firemist SLK230
Other Toys: Alpine Silver Lexus Gs300, Pewter Corvette C5 Targa top
Hello SLK owners,
As you may recall I purchased an '03 Firemist SLK230 for my girlfriend some months ago...
I had the tumbler and steering lock problem... Fixed $$$
Then I replaced a leaking Cam shaft mag adj.... Fixed $$$
I heard a clunk when ever I went in and out of the drive way...
Shop said lower ball joints were bad...Fixed$$$
They also said my motor mounts were leaking....Fixed$$$
I was hoping these two items would solve the problem, and well it didnt solve the loud and annoying clunk!
Please help....? I am sick I spending $1,000 on labor and parts with this car.
I am starting to lose faith in Mercedes, at the moment
Really considering selling it
ANY and ALL help will be greatly appreciated
1994steeda is offline
#2 Old 03-03-2014
JiminFL's Avatar
Could it be the exhaust hitting the floor? That's about all that is under there that would cause a thunk.
JiminFL is offline
The Following User Says Thank You to JiminFL For This Useful Post:
#3 Old 03-03-2014
leapyfish's Avatar
Where does the clunk sound like it's coming from?
Is it the front or back.
BTW,
A 11 year old car with an unknown maintenance history my have problems.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#4 Old 03-04-2014
Thanks for the replies,
It is not the exhaust bracket that is bolted near the transmission, as in the case of most. I double checked that.
The noise is coming from the front passenger's side, up front by the wheel, thus the ball joint replacement.
Any suspension components that are know for wear I should address.
Thanks,
1994steeda
#5 Old 03-04-2014
Originally Posted by 1994steeda View Post
Hello SLK owners,
I think all of us have these problems when we hit 100k miles on R170 =) I did all of that =) Couple weeks ago I replaced my lower ball joints and lower control arm bushings.
When does your clank appear?
For example when I reverse with the wheels turned I hear a clunk and was trying to figure out what it was... When I took it for alignment, my friend carefully looked at the car and told me that my aftermarket Akebono ceramic brake pads were making that noise. There's a gap making them slip when wheels are turned. However it's not a big deal and I can live with it until next brake pad change =) I will get OEM next time. Btw, Akebono are not cheap.
Do you have aftermarket brakes? Then it might be your problem...
Other suggestions would be upper ball joints, or the whole steering drag link. After 100k miles the steering drag link usually needs to be replaced. Mine had a play (back and forth if you rock it with your hand) It should NOT have any play! This resulted into a clunk from a passenger side when I was hitting small bumps Check if it has any play and if it does, replace the whole thing (I'd advise replacing upper ball joints too since it's about time). Also you steering damper might be also reaching it's life limit. Check your lower control arm bushings. And also check front sway bar bushings.
#6 Old 03-04-2014
When I back out of the drive way I hear the clunk, when I am making a u-turn I hear it. Seems to be related to turning.
I purchased power stop drilled rotors for it and going to install them this weekend. I will check the pads.
In reality it doesn't bother me, it's more embarrassing than anything.
Thanks guys for all your input, I deeply appreciate the comments.
#7 Old 03-05-2014
Maybe previous owner installed aftermarket brakes. If it clunks only with the wheels turned and doesn't reappear again until you back up then pads might be the culprit. But also check sway bar bushings. Although my friend mechanic told me these usually go a long way. And check the steering drag link.
#8 Old 03-06-2014
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Don't forget the reservoir for your washers in in the passenger front fender.
I hope it's that easy.
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
The Following User Says Thank You to tcrankwa For This Useful Post:
#9 Old 03-06-2014
The clunk it very loud and solid, sounds like metal to metal.
The brakes do not play a role in whether you hear the noise or not.
I believe it is a suspension issue, but I cannot isolate the location of the noise as I can't recreate how the suspension moves when it's on jack stands.
Thanks again ya'll
#10 Old 03-06-2014
Quoted: 6551 Post(s)
front springs been suggested?
#11 Old 03-06-2014
What would I look for in terms of the front springs? Or should I just replace them?
#12 Old 03-06-2014
probably broken springs.
#13 Old 03-07-2014
Can some please post a link to where I may purchase the set of factory replacement springs?
I want to avoid the dealer and aftermarket lowering springs.
Thanks again
#14 Old 03-07-2014
You should check your springs in case that is not the problem.
Springs can be ordered from many online sites
http://mercedespartscenter.com/index...5720&year=2009
#15 Old 03-07-2014
spring part numbers
#16 Old 03-07-2014
here is more info on red/white spring
don't ask me what it means
#17 Old 03-08-2014
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Thanks again
Throwing parts at a problem can get VERY expensive very quickly. You need to know that the springs are the problem before you go ahead and replace them. Surely there must be a a reputable shop in your area to actually find the problem if you can't find it yourself.
Len
1999 E300D 215,000 miles
sokoloff is offline
#18 Old 03-09-2014
Update...
I replaced my rotors and with that an opportunity arose for me to check the listed items above. To my conclusion, the coil springs are fairly new and have been replaced some short time ago (they are nice and shinny black).
The sliding brake pads, opens up a question... Is there any brake hardware that sit inbetween the pads and the bracket they sit on?
Other than that, no other items looked like a probable cause.
At this point, my girlfriend will have to deal with it until I send it off to the shop. I just hate the fact that I have dropped $2k on the car and they have not "heard" the loud clunk. In any of those times I was at the shop...
I will update the post once there are new findings, thanks.
#19 Old 03-09-2014
New problem...
At 80mph the cars rpm would drop while running! I pulled over to check and the RPM went up and down!
Needless to say, after 4 months of ownership and $3k of repairs totaling up since the first day I bought it...
R170 interior, supercharger, diff, hubs, doors, calipers for sale in merseyside kwthomas064 SLK Parts For Sale 5 02-21-2014 07:42 AM
Slk R170 passenger side mirror Quoc2006 SLK Parts Wanted 8 06-09-2013 10:27 AM
R170 SLK Black Halo Projector Headlight (Passenger Side) xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxwsln SLK Parts For Sale 1 09-13-2012 10:50 AM
Help. Temp disable passenger SRS on 98 R170 Lostinparadise General Discussion 4 11-23-2009 01:29 PM
