Door glass not sitting in seal? - Mercedes Benz SLK Forum
#1 Old 03-02-2014
cockneyrick's Avatar
Vehicle: SLK 230 03MY
Quoted: 34 Post(s)
Question Door glass not sitting in seal?
If you look closely, when i shut the LH side door the glass does not sit properly.
If i close the door using the top RH corner to push it shut, then it works fine.
But passengers wont know to do that every time they get in & out of car?
Is this something simple to cure?
cockneyrick is offline
#2 Old 03-03-2014
El_Toro_33809's Avatar
Quoted: 87 Post(s)
If it seems to be going up too far, it could be that the stop has fallen off if the glass. If it is just misaligned, that could be adjusted. In either case, you need to remove the door panel/card and investigate. Good luck.
El_Toro_33809 is offline
#3 Old 03-04-2014
Quoted: 11 Post(s)
think the angle of the glass can be adjusted via a nut under the door without removing the door card
beerbelly is offline
#4 Old 03-04-2014
JiminFL's Avatar
There is an adjustment that can be made to the angle of the glass. It's inside the door at the bottom. The bottom of the front track must be moved outward to fix your problem. Simple fix, but be prepared to re-glue all the clips that attach the door card to the frame of the door. A simple job becomes more difficult as these cars age.
JiminFL is offline
#5 Old 03-04-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
If you lower the window you should be able to access the adjustment screw on the bottom edge of the door , there should be a rubber grommet on the bottom edge of the door !, without removing the door card !
curro101 is offline
#6 Old 03-05-2014
Quoted: 34 Post(s)
Thanks, will have a look later when work is finished :-(
#7 Old 03-05-2014
Quoted: 11 Post(s)
this is true everytime you take the door card off at least two of the clips need re gluing back on
#8 Old 03-09-2014
Quoted: 34 Post(s)
Well that was a bust, it worked once on opening & closing door. But repeated use then it went back to before.
Also noticed that when raising the glass, at the end of upward travel it jumped in by a few mm. Assumed this was to make it seat, but the drivers door doesn't do it & works fine?
Adjuster underneath is fully to the outer edge on drivers, & passenger is in middle after my adjustment. It does sit fine if u lower & raise glass, but just not on closing the door?
#9 Old 03-10-2014
JiminFL's Avatar
Could it be the window is going up too high and catching the outer lip of the rubber, rather than slipping just under it? I have found that the door glass adjustment is very sensitive to make it rain tight and at the same time wind tight.
JiminFL is offline
#10 Old 03-12-2014
Quoted: 34 Post(s)
When door is shut it works fine, but if its up & u shut the door it just doesn't go in far enough. Its like its looks & is being pushed out when u shut the door?
05 SLK55 AMG rear main seal failure kseiter SLK R171 General Discussion 39 12-18-2018 04:19 PM
Replacing vertical rubber seal between windows Tonyrec SLK R171 General Discussion 5 09-22-2013 10:51 AM
R170 supercharger oil seal replacement cossiroger SLK R170 General Discussion 6 11-08-2010 04:20 PM
Supercharger snout oil seal cossiroger SLK R170 General Discussion 0 09-23-2010 08:52 AM
Rubber seal LarsB SLK R170 General Discussion 6 07-31-2010 10:09 AM
