White milky substance on dipstick - Mercedes Benz SLK Forum
  • 1 Post By beerbelly
#1 Old 02-28-2014
Vehicle: 2002 SLK32 AMG Black 72k
I checked my oil today and I noticed a little blob of white milky substance at the top of the dipstick. Also down the length of the dipstick was little water droplets. Oil looks clean.
I only use the car in good weather now so I'm hardly using it at the moment. It isn't using hardly any coolant although it seems it be using a little more oil than usual but I am not 100% sure
I did run the car for 1500 miles with a broken thermostat
Any ideas? - is it the head gasket?
mjoshyuk is offline
#2 Old 02-28-2014
rhartson's Avatar
Vehicle: 2013 SLK 55
Other Toys: Tesla Model X
Quoted: 19 Post(s)
sounds like coolant leak…not good…head gasket quite likely an issue...
"You may all got to hell, and I will go to Texas" Davy Crockett
rhartson is offline
#3 Old 02-28-2014
Vehicle: 2000 SLK 230
Other Toys: 09 Kawisaki Concours 14
if the oil itself has not turned milky then you have caught it before any damage is done. you have trace amounts of water in the form of vapor in the crankcase. this would indicate head gasket is starting to give out. look at the inside of the oil fill cap, the highest point in the motor. should be seen there also.
don't drive it unless its to the shop!
gonzosc1 is offline
#4 Old 02-28-2014
The oil filler cap is clean no residue or water droplets
Should I get it investigated ASAP
mjoshyuk is offline
#5 Old 02-28-2014
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Absolutely!! I assume it is a 200? Then at least you only have to pull one head. Get it to a shop you trust with expertise in MBs if not specifically SLKs.. As soon as possible.
As said above.. the only trip it should take is to the shop.
FUN 4 2
Der Flieger is offline
#6 Old 02-28-2014
Vehicle: 2008 SLK350
Check the crankcase vent.
Wheeler is offline
#7 Old 03-01-2014
Quoted: 11 Post(s)
I wouldn't worry if its running fine and not overheating head gasket failure will 99% of the time pressurise the cooling system until it blows a hose or radiator .you say you only use the car occasionally I bet its just a little condensation that haven't had a chance to burn off take it out for a run at least a good 20 miles or so then dip it again if its then clean (which I think it will be) alls fine. if your reluctant to drive it call a mobile mechanic to do a sniff test on it will tell you if there's any combustion gasses in the coolant. I would be more concerned that your loosing a little coolant probably nothing more than a drip at one of the hose joints or it could be the waterpump gland if its that it will be dripping near your bottom pullys
ans likes this.
beerbelly is offline
#8 Old 03-01-2014
After cleaning dipstick I went on a 105mile round trip. I checked the oil and coolant last night and both looked ok. The only thing to say was that the dipstick had water droplets along length of stick.
The car since I have owned it always maintained a steady water temperature at 90deC except when I drove it for 1500 miles with a broken thermostat.
It doesn't blow white or blue smoke from exhaust
I think I may just get it checked out
mjoshyuk is offline
Designo Mystic White (a.k.a. Diamond White) Stinger SLK R171 General Discussion 15 05-14-2015 01:42 AM
Dipstick purchase needed vinnys westie AMGs 8 05-01-2011 07:47 AM
'08 SLK55 oil dipstick ? Service manual? jamesegreen Where to get R171 SLK Items 53 02-09-2011 04:57 AM
The dipstick question keeps me awake at night Berliner Heckflosse General Discussion 18 10-25-2010 02:27 PM
SLK55 dipstick problem solved jamesegreen Where to get R171 SLK Items 4 12-16-2008 11:27 AM
