Slk roof not opening completely! - Mercedes Benz SLK Forum
 10Likes
  • 1 Post By curro101
  • 1 Post By jonnyboy82
  • 1 Post By jbanks15
  • 5 Post By jonnyboy82
#1 Old 02-28-2014
Vehicle: 1999 Mercedes SLK 230 Kompressor
Just tried my roof and the open sequence gets to lowering the side windows front and rear and the trunk lid unlocks and opens then nothing. All I can hear is the motor?
Im new to this and ive read so many different threads about this but is there a procedure to start through or a process of elimination?
Any help would be great.
Many Thanks Jon
jonnyboy82 is offline
#2 Old 02-28-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Sounds like a problem with the micro switches ..
Have a look through the links from Leapyfish , they should give you a good place to start looking !
https://www.slkworld.com//members/leapyfish.html
curro101 is offline
#3 Old 02-28-2014
What are all these diagnosis codes relating to or what do I do to fix it?
#4 Old 02-28-2014
curro101's Avatar
Quoted: 528 Post(s)
If you look through this :
http://www.benzworld.org/forums/atta...eshooting-.pdf
It'll tell you where to start looking for your synptoms .
And this will tell you the location of the switches ..
https://www.slkworld.com/r170/topswitches.htm
curro101 is offline
#5 Old 02-28-2014
curro101's Avatar
Quoted: 528 Post(s)
You might want to start by checking you have enough hydrolic fluid in the pump and also checking the actuators in the front of the roof aren't leaking and that they are working/releasing ??
https://www.slkworld.com/r170/hliner.htm
curro101 is offline
#6 Old 03-01-2014
Just went outside to investiagte a bit more, started car and gave the button a push and it worked! What a result im so chuffed. Finally some good has come out of buying this car as immediately I had to spend on a front ABS sensor and I also had an auto electrician trying to find a knackered wire so I could MOT the car.
Finally got the car MOT'd yesterday so one last problem to fix is the heater. The fan does not come on although I can feel the hot air through the vents?
#7 Old 03-01-2014
curro101's Avatar
Quoted: 528 Post(s)
Make sure you treat all the rubbers with Gummi Pfledge and grease all the roof articulations , it sounds as they mey have been a bit siezed / stuck ..
jonnyboy82 likes this.
curro101 is offline
#8 Old 03-01-2014
Yes that is next. Saving that for Sunday!
curro101 likes this.
#9 Old 03-03-2014
Fixed the heater too this weekend so all in all been a very good weekend for me. Roof works and so does the heater now! All I need is some good weather to get the roof down!
#10 Old 03-03-2014
Quoted: 6544 Post(s)
Patience is a virtue! It will all be good!
#11 Old 03-06-2014
Vehicle: 05 SLK55
Other Toys: M3 Softail Deluxe EK Holden Ute
Good news, I wish mine would do the same and simply fix itself up.
Cheers, mark
AMG 055 is offline
#12 Old 03-08-2014
Not so good news just tried to open it again on this glorious day and it got stuck again ffs! It got as far as lowering all windows then the boot flipping open. After you can hear the motor spinning but that's it. I tried it a few times and even tried to apply a bit of pressure but still no!
#13 Old 03-09-2014
starfighter's Avatar
Vehicle: Y2K slk 230
Quoted: 8 Post(s)
Mine did just the same......
Was diagnosed as one of three switches.
I did notice that "sometimes" if I tugged up on the trunk lid after it was open as far as it would, The roof would move.
So we replaced the "trunk open" switch and FIXED !!!
starfighter is offline
#14 Old 03-09-2014
starfighter,
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. https://www.slkworld.com/new-members-...yourself-here/
#15 Old 03-09-2014
Well it opened and closed @ the start of the day then come this evening it got stuck again.
I had the car scanned by a Neighbour and these are the codes diagnosed: B1268, B1275, B1279.
I have not yet had a chance to look these up but will do this evening.
The Neighbour who scanned it is an auto electrician and he managed to open it by releasing it manually with the allen key. He suspects it's the catches above the windscreen as these are not releasing?
#16 Old 03-17-2014
Thought id update this thread as I have now cured the problem.
I manually released the roof using the allen key, removed the 3 screws to drop the headlining down and the piston that turns upon opening that detaches the roof from the top of the windscreen had seized either due to lack of use or not being maintained. So I sprayed wd40 on it and turned it a few times to work the grease in and thats it job done! Before when I tried to open via the allen key it was really stiff and now I know why. Now it works effortlessly!
jbanks15, curro101, LewSLK and 2 others like this.
#17 Old 03-17-2014
JiminFL's Avatar
Congratulations!! Was it actually the piston or was it the mechanism that was binding?
JiminFL is offline
#18 Old 03-17-2014
It was the piston. The part that turns with the allen key as it was very stiff.
JiminFL likes this.
#19 Old 03-18-2014
So after figuring out the roof I had a new low today. Got in the car this morning as normal drove to the gym, done my workout come back to the car and it doesn't start. No cranking at all. All lights are on dash, everything else works but nothing. I tried about 20 times to crank and still nothing. So called the AA to recover me then after 10 mins of waiting I tried and it started. WTF this car is jinxed!
So I have been doing some research and im gathering this is something to do with the dreaded K40 relay?
#20 Old 03-18-2014
curro101's Avatar
Quoted: 528 Post(s)
Could be , check the solder joints .
curro101 is offline
Roof not opening swordfish147 SLK R170 General Discussion 8 07-13-2013 10:27 AM
2000 slk 320 R170 roof alignment problem djahugen SLK R170 General Discussion 5 12-05-2012 08:34 AM
Looked at SLK Today; Roof issue, what do you think? Firm SLK R170 General Discussion 28 06-06-2011 02:38 PM
SLK WAVE: In Response to the Roof Ballet Challenge! YellowSLK SLK Videos 7 12-12-2009 10:51 AM
