Windscreen misting - fails to clear R170 - Mercedes Benz SLK Forum
#1 Old 11-09-2009
Vehicle: SLK 200K
Other Toys: VW Golf GTTDI, Road bikes various
Chats: 2
Question Windscreen misting - fails to clear R170
Hi. Its November, its gone frosty & damp and I've got a misted winscreen (drivers side only) that refuses to demist.
Has anyone got any ideas please?
davep is offline
#2 Old 11-09-2009
Vehicle: Black/Black 2008 350 SLK
Other Toys: 2004 320E
Hi DaveP,
It doesn't get too cold out here, but I use Autoglym Glass and the occasional fog I do get clears pretty quickly. You might also consider RainX Anti-Fog. What do you use now to clean the insides of your windows?
tommy04 is offline
The Following User Says Thank You to tommy04 For This Useful Post:
#3 Old 11-09-2009
Founding member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 25 Post(s)
The other thing to look out for is that you don't have a water leak that is causing more moisture. Check floor boards and the like. Check that the quarter window is properly aligned with the main window.
mtiede is offline
The Following User Says Thank You to mtiede For This Useful Post:
#4 Old 11-11-2009
Vehicle: 2001 SLK 320
Under the hood over the tranny is a rubber tube. This tube drains away water that collects when you run your air conditioner.. If the drain is plugged water will show up on your window.
Chris A is offline
The Following User Says Thank You to Chris A For This Useful Post:
#5 Old 11-11-2009
Vehicle: SLK 200K
Chats: 2
Hi tommy04,
Thanks for your reply. I must admit I was thinking of something more involved like there was a demister hose that had become disconnected.
I'll tackle the problem your way first, and try with some rainex.
Best regards
Dave
davep is offline
#6 Old 11-11-2009
Vehicle: SLK 200K
Chats: 2
Hi Chris
I had a car this happened on once - a Porsche 924S, the scuttle tray used to block up with leaves and when turning my demister fan on, I was blowing water vapour onto my windscreen!
I must check this as soon as I get chance during daylight hours.
Thanks again
Dave
davep is offline
#7 Old 11-11-2009
Originally Posted by davep View Post
Hi tommy04,
Best regards
Dave
, simple, that's me! Have you put your hand up there to see if air is pumping out of the vents? Could rule out the demister hose theory...and at first glance, I thought demister was a random German word
Good luck!
tommy04 is offline
#8 Old 12-11-2009
Vehicle: SLK R170, AMG styleline
Davep,
You could have a leak, check gap on the roof. It should be 7 to 9 mm wide.
Another guess would be pollen filter. I had many cars with windscreen misting issues, that are easily solved after pollen filter is replaced.
All the best,
Cvele
cvelee is offline
#9 Old 12-17-2009
Buxieda's Avatar
Vehicle: 2001 SLK230 Kompressor W/Sport Pkg
Other Toys: 04 Durango,
Chats: 3
I thought Wind screen was that screen you put on the back on the Roll Bars.
but after reading all the post I realise you are referring to the Windshield.
Buxieda is offline
The Following User Says Thank You to Buxieda For This Useful Post:
#10 Old 12-20-2009
Vehicle: SLK 200K
Chats: 2
Different continent, different name.
Happy hollidays
davep is offline
The Following User Says Thank You to davep For This Useful Post:
#11 Old 12-20-2009
Buxieda's Avatar
Chats: 3
Happy hollidays
Live and Learn!
Thanks Happy holidays right back at ya!
Buxieda is offline
#12 Old 01-06-2010
Other Toys: Multiple MGs
Send a message via Skype™ to MikeBcos
I just fixed the same problem on our 01 SLK. It was clogged vents and drains round the air intakes at the bottom of the windscreen. I blew all those out with compressed air, blew out a load of crud from under the battery tray and changed the cabin filter. The misting went away immediately.
MikeBcos is offline
#13 Old 01-08-2010
Vehicle: SLK 200K
Chats: 2
Thanks for the useful reply Mike.
I'll be having a good look at those points you mentioned as soon as the ice and snow has cleared. We don't enjoy driving the slk on the icy roads at the moment, as the steering wheel seems to have a mind of its own!
Have not had much experience with rear wheeldrive cars (especially an automatic which wants to creep all the time against the brakes - scary ).
Take extra care.
Dave
davep is offline
