more scan codes,,help - Mercedes Benz SLK Forum
  • 1 Post By Livefreeordie
  • 1 Post By jbanks15
#1 Old 02-22-2014
Vehicle: 2000 SLK 230
Other Toys: 09 Kawisaki Concours 14
alright. about a week ago I got P0410 and the car started to misfire and run bad, I changed out the shut off valve today and erased the codes. started the car up and it is still misfiring, now showing codes P0300 random misfire, and P0302 cylinder 2 misfire.
the P0410 code is not showing up now so I guess the shut off valve took care of that. would the check valve have anything to do with that and not show a code? I got it on order!
I pulled the K40 and everything looks good. sprayed it down with electronics cleaner and reinstalled. still misfiring.
what to look at next???
gonzosc1 is offline
#2 Old 02-22-2014
I had misfire codes when ever i would get into the throttle, my car would go into limp mode shortly after. It took me some time to figure out that the problem was the CPS. I replaced the part last year with no further codes. I woudl do a search on the cps before you start replacing parts.
#3 Old 02-22-2014
thanks. looking a vids now on youtube. getting some ideas on where to start. its seems misfires cover a lot of areas. fuel filter, fuel pressure, coil packs and wires, vaccum lines. this is gonna hurt,,,,LOL
gonzosc1 is offline
#4 Old 02-22-2014
That is correct it may be any one of those parts, the most common cause is cps, fuel filter. You can always swap the coil packs around and see if the misfire moves to a different cycl. That will tell you if its a coil pack or not.
gonzosc1 likes this.
#5 Old 02-23-2014
great I'll try that tomorrow,,,Thanks
gonzosc1 is offline
#6 Old 02-23-2014
OK just did the coil swap and yes the misfire has moved. went from #2 cylinder to #4 cylinder! should I replace both as they are most likely to be original from 2000?
also which cylinder is whick? from front to back how are they numbered?
also went hunting some more for vac leaks and found the MAP sensor vac line was totally ruined and split off the bottom of the sensor, that should fix the code for that I hope. looks like I will need to go through all the vac lines!
I think a wiring harness will be in the future. I can't touch most of the connectors without the tabs breaking off, its very very brittle under the hood.
gonzosc1 is offline
#7 Old 02-23-2014
Quoted: 6547 Post(s)
this might help. explains how they are numbered at least. There is another thread recently that tells you which cylinder is which
https://www.slkworld.com/slk-r170-cla...v8-motors.html
#8 Old 02-23-2014
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
I'd only replace the coil pack that's bad. #1 is in the front.
Len
1999 E300D 215,000 miles
sokoloff is offline
Scam alert! Free Android Tablet Computer jbanks15 Off Topic 0 10-02-2013 06:38 PM
Used car buying app SNAFU SCAN SLKman Off Topic 2 05-05-2013 01:30 AM
What's a good OBDII scan tool that works with SLK 55 in USA wavyphotons SLK R171 General Discussion 0 01-31-2012 10:46 PM
Scan for Error codes c-w203 SLK R170 General Discussion 1 08-11-2010 08:33 AM
Scan Gauge mistered Performance MODS for the R170 5 11-30-2009 10:45 PM
