Where is trunk light? - Mercedes Benz SLK Forum
  • 1 Post By Woolly
#1 Old 02-18-2014
Vehicle: 2001 SLK230 Kompressor (Red)
fuse for interior lights blown! Where is trunk light?
Sorry about kind of getting off topic here but I'm about to give up and take my 230 into the dealer for this electrical issue... My 2001 R170 is having an issue with the interior lights. Every time I turn them on the right bulb illuminates just long enough to blow the fuse... the trunk light, door locks and alarm are associated with the same fuse and they all function properly and do not blow the fuse. And the trunk light is my last step before giving up and taking her in to avoid the hastle of checking miles of wires... I cannot find the trunk light and I am not sure if I even have one... so I was wondering if someone could please help me locate it / diagnose the problem
bhansen2012 is offline
#2 Old 02-18-2014
Quoted: 11 Post(s)
sounds like your on the right track the live feed to the light could be shorting directly to earth blowing the fuse if the trunk light is not illuminating the live wire might have come loose and be touching an earth . sorry I don't remember where it is in the trunk but im sure someone will answer soon
beerbelly is offline
#3 Old 02-18-2014
That's what I was thinking... either that or something to do with the left dome light... because when I turn on the dome lights... the right one eliminated for a moment, but the left doesn't... I just don't want to take apart the interior if I don't have to... thanks for the reply!
#4 Old 02-18-2014
Elmo Wright's Avatar
Vehicle: 2003 SLK230
Other Toys: Ford Taurus, Suzuki Ozark 250
Trunk light location
Hello bhansen, the trunk light is on the left side of trunk just in front of you left leg. I have trouble with my trunk light staying on. I have removed the bulb for now but haven't given up hope yet. Good luck in your search.
Elmo Wright is offline
#5 Old 02-18-2014
Trunk light
Sorry my photo didn't upload
#6 Old 02-18-2014
Quoted: 6572 Post(s)
https://www.slkworld.com/slk-r170-cla...ight-bulb.html
#7 Old 02-19-2014
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by Elmo Wright View Post
Hello bhansen, the trunk light is on the left side of trunk just in front of you left leg. .. .. ..
You must have long legs if they end up in the trunk?????
bhansen2012 likes this.
Woolly is offline
#8 Old 02-19-2014
Problem Solved! found the wire connectors where the trunk light was supposed to be but the housing was not attached... luckily i have a friend is parting out his '99 and i took the housing from his... but this still didnt solve the problem so i went back to my initial issue, the dome light. I took down the assembly and found my problem. plastic assembly that holds the right bulb in was broken, keeping it from being seated properly, warping the leads allowing the positive to arc to the negative. so lights are working again! Thanks all for the help!
The Following User Says Thank You to bhansen2012 For This Useful Post:
Trunk light switch location? kaarrff SLK R170 General Discussion 9 08-07-2018 05:58 PM
Changing/replacing trunk light bulb JaysonM SLK R170 class DIY 16 01-17-2016 03:48 PM
Trunk light switch sokoloff SLK R170 General Discussion 13 02-15-2014 01:43 AM
Dome light will not turn off / trunk latch related? new2slk SLK R170 General Discussion 9 01-11-2010 08:08 AM
