1998 slk230 revival - Mercedes Benz SLK Forum
  • 2 Post By SLC-SLK
#1 Old 02-17-2014
Vehicle: 1998 SLK 230
Other Toys: 1952 PORCHE CAB 1991 300SL 1997 C230 2002 C240
1998 slk230 revival
P { margin-bottom: 0.08in; } Thanks you for the warm welcome to your forum I thought I should do a small update on the project 1998 SLK230.. I bought this car In December from a used car dealer that said it was a bank repo but he assured me that nothing was wrong with it and I assured him that he was a lying SOS! I opened the front hood and could see that most all of the Vacuum lines were missing! I could tell the codes had just been erased but he insisted it didn’t throw any! HA! I made him what I thought was a very low offer and he said I should get lost! Two weeks later he called and said to come get the car and I told him that offer was only good on that day! I said I would consider taking it for now $300 less than before and he called me something nasty and said come and get it. I Had it towed home and a week later took it in for 4 new tires The old ones were bald as you can get! It turns out the car had (3) 8 inch wheels and (1) 7 inch wheel so I had them mount the three of the tires and would come back after I found a 7 inch wheel. So now I have the car up on jack stands to drain every conceivable fluid this car has in it because I can tell the previous owner(s) did not or could not afford to do any maintenance and I was right. The engine, Transmission and rear end fluid looked like burnt tar!
Here is a list of the initial parts list I have ordered to start the Revival... 7in. front wheel, 4 Rotors Callipers and brake pads.. New Turn Signal Arm assembly. Engine oil and Filter, transmission oil and filter. Rear end oil. Super Charger Oil, Steering fluid. Fuel Filter,,,2 Serpentine Belts, 2 Belt Tensioner with rollers, 1 Idler wheel, New Water Pump.. New K40 relay box.. Blaupunkt Stereo.. Spark Plugs, Y32 Vacuum switch, After Taking most of the ordered part off the car I found that many of the Factory Bolts were missing That secure the 2 Tensioners and the Air Con Comp only had one bolt holding it on so went to the dealer for the Missing and correct Bolts.. All of these Parts should arrive this next week and I will try and give a Update after the car is back together. Just remembered I ordered all radiator hoses and Engine Breather Hose It was hard as a rock. Also some Idiot had put Cheap GREEN Corrosive Coolant in the car.
Woolly and jbanks15 like this.
SLC-SLK is offline
#2 Old 02-17-2014
Vehicle: 2000 SLK 230
Quoted: 34 Post(s)
sounds like you have quite a project ahead of you, i cant wait to hear and see more of the story, good luck.
SirClass is offline
The Following User Says Thank You to SirClass For This Useful Post:
#3 Old 02-17-2014
rhartson's Avatar
Vehicle: 2013 SLK 55
Other Toys: Tesla Model X
Quoted: 19 Post(s)
you are a brave man…good luck!!
"You may all got to hell, and I will go to Texas" Davy Crockett
rhartson is offline
The Following User Says Thank You to rhartson For This Useful Post:
#4 Old 02-18-2014
Quoted: 11 Post(s)
pictures!! we need pictures!! its not true without pictures!!!!
beerbelly is offline
#5 Old 02-18-2014
Helix's Avatar
Vehicle: 2008 SLK350 AMG germanite grey
Other Toys: GLC43 AMG
Quoted: 8 Post(s)
Great adventure - love it. Make a PORSCHE out of your PORCHE... Sounds better :-)
Walter
Helix is offline
The Following User Says Thank You to Helix For This Useful Post:
#6 Old 02-18-2014
I will do that I few parts arrived today Water Pump, K40 Relay and Turn signal arm
SLC-SLK is offline
#7 Old 02-19-2014
Vehicle: '01 200K
Other Toys: BMW 3 series F31 - FIAT 500 convertible
Quoted: 25 Post(s)
Looks like you'll be busy for a while. Do not hesitate to post pictures of your work but also of your other toys !
BCoolidge is offline
The Following User Says Thank You to BCoolidge For This Useful Post:
#8 Old 02-20-2014
EPerk's Avatar
Vehicle: 1999 SLK 230 Kompresser
Other Toys: 2000 Nissan Altima GLE
Geezz and I thought mine was in bad shape when I bought it.... good luck bud.
EPerk is offline
The Following User Says Thank You to EPerk For This Useful Post:
1998 SLK230 Operators & Service Manuals W1KSZ SLK R170 class DIY 10 06-04-2015 02:47 AM
Selling my 1998 SLK230 (R170) venturejordi SLK Cars For Sale 0 08-26-2013 03:21 PM
Help, 1998 SLK230 Kompressor missfire codes Wheels52 SLK R170 General Discussion 6 04-17-2013 03:46 AM
My new purchase a 1998 SLK230 angelbob New Members Introduce Yourself Here 24 03-18-2013 12:55 PM
Selling my 1998 slk230 OEM headlights / OEM bumper park light / OEM side marker light (turn signals) afr00t SLK Parts For Sale 1 04-17-2012 03:23 PM
