Engine/Supercharger noises - Mercedes Benz SLK Forum
  • 1 Post By JaysonM
  • 1 Post By mad_max
#1 Old 02-16-2014
Vehicle: 2002 SLK230
Okay last question for a while. Keep having this noise that can sometimes be intermittent. Sometimes in traffic it will disappear for a few seconds and as soon as I hit the gas again it'll come back. Inspecting under the hood it seems like it's coming from the front case of the supercharger, so I'm thinking bearings?
For your convenience, I've uploaded a video. Sorry it's sideways, I give up on technology
https://www.youtube.com/watch?v=I1MfHgBM2rA
You can hear it, sounds like a grinding noise. Anyone have something similar?
mad_max is offline
#2 Old 02-16-2014
Quoted: 6545 Post(s)
that sounds like one of your vbelt pulleys.
#3 Old 02-16-2014
xavair's Avatar
Vehicle: 2002 slk32 ////AMG
Other Toys: 3000gt
Looks like it's leaking oil from the supercharger?, I would check the oil level in the supercharger add as needed/change, clean everything/ pressure wash it, might be getting oil on the belts, which I would go ahead and change and check your pulleys (spin them) with the belts off and check for noise and or ruff spinning, idler pulleys can be lubed with wd-40. -Rick
xavair is offline
#4 Old 02-17-2014
raymond.harper's Avatar
Vehicle: SLK 230 2001
Quoted: 21 Post(s)
If you look at the wheeler dealers video where they "repair " an SLK he uses a long stethoscope to listen where the noise is coming from but you can use a long piece of wood or screwdriver if you carefully put it against your ear
raymond.harper is offline
#5 Old 02-18-2014
Sorry guys haven't been able to get out to look at this stuff yet. I'm going to get on it tomorrow and let you know what I find!
mad_max is offline
#6 Old 02-19-2014
Vehicle: 2000 SLK 230
Other Toys: 09 Kawisaki Concours 14
sounds like belt pulley for sure. supercharger is more of a rattle sound then a squeak. while your at it clean off the mag cam adjuster too. seal it up if its leaking!!! looks like it may be.
gonzosc1 is offline
#7 Old 02-20-2014
Doesn't sound like a supercharger to me.
But you Camshaft Sensor needs to be replaced and new sealing compound needs to be applied! Yours is leaking badly... It may cause some serious damage according to MB bulletin. The sensor is about $50 and sealing compound is around $10. 30 min job including removal and cleaning of the area.
#8 Old 02-20-2014
Jayson can you show me which sensor you're looking at? Repair manual says the cam sensor is on the top of supercharger case, just want to make sure. You are right though, something is leaking, and the noise isn't the supercharger. I checked the power steering fluid and it needed to be topped up, but didn't stop the noise. Which I still can't pinpoint, it's somewhere near the engine head by the power steering pump, but even with the stethoscope I wasn't getting it. And both belts are pretty new, maybe a year old? Belt dressing didn't do a thing. I need to go at it again.
mad_max is offline
#9 Old 02-20-2014
Can't help with the noise =(
But here's the picture of the Camshaft Solenoid:
It's that big round sensor on the right.
And here's info about part and a good PDF DIY:
https://www.slkworld.com/slk-r170-gen...tml#post357432
gletson likes this.
#10 Old 02-23-2014
Thanks Jayson. I'm getting the parts together for that, and it looks like the noise at idle is a common symptom of the sensor leaking. I'll update when I do that and see if it works.
JaysonM likes this.
mad_max is offline
help! noises! video link provided. bought an slk230 now i got noises notShai General Discussion 12 10-30-2010 04:25 PM
Noises, noises, 350 noises. nakulan7 General Discussion 9 04-25-2010 01:26 PM
Disturbing noises coming from the car(top) when you fall down a hole on the road Merso General Discussion 10 08-16-2009 10:07 AM
Roof noises Corkscrew SLK R171 General Discussion 17 05-19-2008 10:57 PM
