engine dies while driving - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By curro101
  • 1 Post By jonbonesjones
  • 1 Post By legendary620
#1 Old 02-11-2014
Vehicle: red 99slk230
Other Toys: Houseboat fishingzboat
I have a 1999 slk230 and every once in a while, usually after driving for 30 minutes, the car will die, even if I am driving and not arriiving at a stop etc.
All the dash lights come on. The yellow low fuel also is on even if I have a 1/2 tank of gas. The engine turns over, in fact it is like it sticks turning the engine over if I take my hand off the key. I wait aprox. 30 minutes and it starts like nothing happened. I have read about the crankshaft position sensor and someone said it sounded like the fuel pump gets hot and after it cools off it starts pumping again. Great performance except when it wont start? I just joined so I hope this is posted at the right place. Also any help on the location of the cps would be greatly appreciated. Thank you in advance for any help provided.
Garrett F Jackson is offline
#2 Old 02-11-2014
Quoted: 6558 Post(s)
moving off of homepage news to the r170 general discussion section
#3 Old 02-11-2014
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. https://www.slkworld.com/new-members-...yourself-here/
#4 Old 02-11-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Do a search for K-40 relay as a place to start ...
Garrett F Jackson likes this.
curro101 is offline
#5 Old 02-11-2014
Quoted: 914 Post(s)
By any chance is the engine cooling fan running on high during the "no start"?
efair is offline
#6 Old 02-11-2014
Originally Posted by Garrett F Jackson View Post
. . . after driving for 30 minutes, the car will die, even if I am driving and not arriiving at a stop etc. . . . .
Other than the last part, it sounds exactly like a crank position sensor over heating failure . . . I had one! Of course I have a different engine, so it might not be as applicable. The question about the last part is only, does the sensor get hot enough to quit. Doesn't really matter if you are driving or idling. It only happens after a longer period if it's cooler. (And not at all if it's cold enough and you keep the air moving past the sensor.)
I don't remember if a code shows up for that, but I think it does. Listening to the mechanics, it sounded like it showed as an over-temp before it died.
I think you'll need to get the codes pulled from the car. Getting stranded like that can be a real pain!
lilred320SLK is offline
#7 Old 02-12-2014
Vehicle: 1999 SLK 230
Pull the K40 and check the solder joints. I had the exact same problem and even had the exact same thought about the fuel system getting to hot. I fixed it with re-soldering my K40 and haven't had one problem since.
jonbonesjones is offline
#8 Old 02-13-2014
I think I will replace K40 and Crankshaft position sensor
#9 Old 02-16-2014
Replacing the K40 might be expensive. Pull it and look at the solder joints, it is an easy fix if you know what you are doing and if not a hobby shop or a friend can do the repair. The cost should be less than $5 if you have to buy solder and FREE if you don't. I would do this first as it is super easy and will save you cost and time of having to replace the crank sensor, if the K40 is the culprit.
curro101 likes this.
#10 Old 02-16-2014
curro101's Avatar
Quoted: 528 Post(s)
There's always time to buy a new one if re-soldering it doesn't work !
jonbonesjones likes this.
curro101 is offline
#11 Old 02-23-2014
Vehicle: 1999 SLK 230 automatic
Other Toys: Old Honda's CB 350/CB 750
Mine did same thing and MAF was filthy. Cleaned it and ran like a top.
legendary620 is offline
2005 SLK R171 M272 Engine Oil Consumption [For All Owners] rubenh SLK R171 General Discussion 51 07-09-2015 02:51 PM
Attack on Willow Springs Raceway (FREE driving clinic, lunch, and raffle prizes) Juggarnaut U.S. California 10 04-11-2014 12:40 AM
The 1st Driving Lesson and the Mods 4 the Fiat are gone gone gone Berliner Heckflosse Off Topic 3 06-07-2012 04:48 PM
