central locking system on 2002 320 - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By leapyfish
  • 1 Post By Robert320
#1 Old 01-27-2014
Vehicle: 2002 320 sport automatic
Other Toys: 54 speedeter,66 mustang conv
Need a little help. my central locking system stop working today. I checked fuse 26 and it is good and has voltage on it. The symptoms are as follows:
push the lock/unlock button on dash no action no noise
push unlock on the remote. lights flash once but no door locks do not move or make any noise
push lock on remote and lights flash 3 time but no door locks do not move or make any no noise
I would be grateful for any help.
some questions I have.
Are there any other fuse besides the one under the hood?
Where is the vacuum located?
Can a bad switch on the dash cause the remote function to stop working?
Are they any relays in the system? if so where are they located.
Are there any other components I need to look for?
I dont think there is anything wrong with the actuators in the door or trunks as they all went out at the same time.
Thanks for any help in advance.
Robert320 is offline
#2 Old 01-27-2014
Quoted: 6551 Post(s)
The links in Leapyfish's sig block will show you the other fuse locations as does your owner's manual
https://www.slkworld.com/1126985-post17.html
#3 Old 01-28-2014
leapyfish's Avatar
The "vacuum" is called the "PSE" here'e a link to find & have a look at the "PSE" http://www.benzworld.org/forums/r170...fit-check.html
JaysonM likes this.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#4 Old 01-29-2014
central locking
Thanks for all the help. I will work on this this weekend
#5 Old 01-30-2014
Central Locks Problem
Thanks for all the help. I think I found the problem (see pictures). While checking 4 of the pin, two in each connector were corroded off. and guess where the pins were. Yes they were stuck in the female side of the connectors. It took some work to extract them. I will be ordering a new PSE today. Thanks again for the help
JaysonM likes this.
The Following User Says Thank You to Robert320 For This Useful Post:
#6 Old 02-05-2014
Locks fixed
To complete this thread. After removing all the corroded broken pins from inside the female side of the connectors and replacing the PSE all is working great. I will never know why Mercedes used two small 18 pin connectors to connect 6 wires in on connector and 10 in the other. A replacement PSE was obtained from ebay for $250. The until looks and operates as new. There was no corrosion on any of the connectors or inside.
Thanks too all who help
JaysonM likes this.
Central Locking System Problem After New Battery EOLJR General Discussion 15 08-11-2015 07:02 AM
Strange Central Locking Problem Apesbrain SLK R170 General Discussion 8 11-19-2014 07:22 AM
Central locking system drg New Members Introduce Yourself Here 15 12-30-2013 09:44 AM
central locking system desp8838 SLK R170 General Discussion 1 07-29-2012 10:11 PM
