Turn signal /indicator problem - Mercedes Benz SLK Forum
#1 Old 01-27-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Brain picking time again , guys & gals .
I'm trying to sort out a problem for a member on the national forum I'm on and need some advice from the r170 experts please .
The problem is the following :
When the indicator/turn signal is used , indifferent of which side , both sides indicators come on ( same as the hazard/emergency lights ) .
Any ideas would be appreciated !
curro101 is offline
#2 Old 01-27-2014
Quoted: 6544 Post(s)
bad bulb?....
#3 Old 01-27-2014
Not sure if there is a relay but it almost sounds like his multi function switch is going bad.
#4 Old 01-27-2014
curro101's Avatar
Quoted: 528 Post(s)
Shouldn't be a bulb as they all work , just not how they should !
What do you mean by the multi function switch ?
curro101 is offline
#5 Old 01-27-2014
on some model cars, when a bulb is bad, the signal will blink faster so I was just throwing that out for what it was worth. Apparently it was worth bubkis!
#6 Old 01-27-2014
curro101's Avatar
Quoted: 528 Post(s)
Any and all input is always greatly appreciated !!
curro101 is offline
#7 Old 01-27-2014
Is there a relay switch in the R170 that may be common to the indicator stalk/lever and the "hazards" switch? Just thinking that the indicator lever switch may be either be faulty or a faulty relay is sending the signal to all sides irregardless of the indicator control lever position.
#8 Old 01-27-2014
A multi function switch is also called turn signal level. I woild do a search and see if there is a relay.
#9 Old 01-27-2014
curro101's Avatar
Quoted: 528 Post(s)
Oh , ok , you mean the indicator stalk , could be ..
I believe the indicator relay for the pre facelift r170's ( just found out it's a 98 ) is built into the ECU , N10-3 module ?
curro101 is offline
#10 Old 01-27-2014
Vehicle: slk 200 kompressor 2001/2
Other Toys: Hi Fi /Photography
Could be a bad earth on one light unit and is going to ground through the other indicator bulbs
4johng is offline
The Following User Says Thank You to 4johng For This Useful Post:
#11 Old 01-27-2014
curro101's Avatar
Quoted: 528 Post(s)
What's exactly the connection between the PSE pump and the indicators ?
I asked the owner if he'd checked it for corrosion and he NOW tells me , that he's just bought the car , never tried the indicators before and has no PSE pump what so ever !!!
Very probable culprit , right ?
curro101 is offline
#12 Old 01-28-2014
leapyfish's Avatar
Does he even know where the PSE is?
http://www.benzworld.org/forums/r170...fit-check.html
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#13 Old 01-28-2014
curro101's Avatar
Quoted: 528 Post(s)
Not until I told him !!
curro101 is offline
#14 Old 01-29-2014
techcareuk's Avatar
Vehicle: 1999 SLK 230K Designo with AMG option pack
Other Toys: S500L / Volvo V40 2.0T / Lunar Lexon EB caravan / Viking 26 Center Cockpit Cabin Cruiser
only thing i'm aware of that will activate both sides is a problem with the hazzard switch!
techcareuk is offline
Turn Signal issue Saphykitten SLK R170 General Discussion 12 05-06-2015 12:55 AM
Right Turn Signal Problem onenobx New Members Introduce Yourself Here 12 07-25-2013 12:00 PM
3357A Turn Signal Bulbs Versus PY21W? mb911 General Modifications R171 2 11-15-2012 12:38 PM
Turn signal in mirror, right - Malfunction gdb069 SLK R171 General Discussion 8 03-05-2012 01:21 PM
