headlight washer question - Mercedes Benz SLK Forum
#1 Old 01-25-2014
Vehicle: 2000 SLK 230
Other Toys: 09 Kawisaki Concours 14
just adding to my spring time fix it list for my new car I got 2 months ago.
how are the little doors opened for the headlight washer spray?
the washer it self works but the little doors won't open. when I hit the switch washer fluid just comes grushing out from around the doors running all over the bumper inside and outside!
gonzosc1 is offline
#2 Old 01-25-2014
Quoted: 6546 Post(s)
there is a thread about that issue. don't remember if r170 or r171.
#3 Old 01-25-2014
ok thanks jbanks
gonzosc1 is offline
#4 Old 01-25-2014
best i can do:
https://www.slkworld.com/slk-r170-gen...her-cover.html
#5 Old 01-25-2014
ok, did a few searches and does not appear to be a lot about this for the 170. but from what I see here there does not appear to be a motor for this. maybe just springs and stuff. maybe my washer doors/covers are just stuck from non use?? maybe... like I said. the washers are working, just not opening. after more reading it also seems that this may not be worth the time to worry about!!!
just depends how anal I want to be about it ,,, but for now I have bigger fish to fry with this car then the headlight washer. got a roof that does not work and engine work to do so this will go on the back burner... thanks jbanks
gonzosc1 is offline
#6 Old 01-25-2014
Quoted: 11 Post(s)
iv seen these stuck after a bumper repaint try and just gently pull them out you wont do any harm they should pull out with a little pressure
beerbelly is offline
#7 Old 01-25-2014
ok, I'll try tomorrow
gonzosc1 is offline
#8 Old 01-28-2014
leapyfish's Avatar
The headlight washers are pushed by water pressure https://www.slkworld.com/r170/lighting.htm
the leak you describe sounds like 1 or both are cracked.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#9 Old 02-01-2014
ok I was able to look at it today. I pull the cover open, what does the sprayer look like?? I just see what looks to be a nozzle but I'm not sure. it just has a open round end on it that looks to be pointing straight out and not at the headlights.
gonzosc1 is offline
#10 Old 02-01-2014
In the R171 the nozzles sort of rotate or twist as the water pressure builds and then finally sprays the headlamps when under full pressure. May be best to have someone work on the headlamp washer while you're up front to see if it functions properly but be ready to get wet.
#11 Old 02-02-2014
thanks etyu
gonzosc1 is offline
#12 Old 02-03-2014
techcareuk's Avatar
Vehicle: 1999 SLK 230K Designo with AMG option pack
Other Toys: S500L / Volvo V40 2.0T / Lunar Lexon EB caravan / Viking 26 Center Cockpit Cabin Cruiser
check the nozzles are actually there!!
if they are the same as my S-Class I've lost 2 nozzles in cold weather, they tend to shoot out of the tube at cold temps instead of being retained as they should, the nozzles clip into the tubes so if when you open the covers you just see empty tubes you have lost the nozzles!
techcareuk is offline
headlight washer fuse r&kslk230 SLK R170 General Discussion 3 02-22-2017 09:02 AM
Headlight washer cover Blessed Again SLK R170 General Discussion 3 02-10-2015 02:37 PM
video of headlight washer? 150.kwh SLK R170 General Discussion 5 04-08-2011 06:27 AM
Repair of Headlight washer Danvslk SLK R170 General Discussion 4 09-30-2010 08:56 AM
VIN headlight question steveb48 SLK R170 General Discussion 6 04-14-2010 12:30 PM
