Wet headlights not so easy to fix - Mercedes Benz SLK Forum
 5Likes
  • 3 Post By raymond.harper
  • 1 Post By raymond.harper
#1 Old 01-24-2014
raymond.harper's Avatar
Vehicle: SLK 230 2001
Quoted: 21 Post(s)
It has been wet here lately but my headlights on my recently acquires SLK seemed to be raining on the inside.
so it was time to tackle the problem. Read the sticky and thought it was straightforward. Got the headlight unit loose but it would not come away from the car due to a purple pipe which was still holding it in.
In the end I had to cut it off to get the light out as I wanted to dry out the unit. The pipe was part of the headlight adjustment not essential by any means but it proved a major problem. Problem came when I tried to reattach the purple pipe. No matter what I tried I could not reconnect it to the unit. I tried using heat and brute force but it was a losing battle . Instead I got some silicone piping from Ebay ( where else ) the same colour / color with an internal diameter of 3mms which works well . Put the whole thing back together and pleased to say my headlights are dry once more
Durkatlon, simplyslk and JaysonM like this.
raymond.harper is offline
The Following User Says Thank You to raymond.harper For This Useful Post:
#2 Old 01-24-2014
Great you could find a replacement hose! See this gray connector the purple pipe connects to? These are usually used for vacuum lines like door vacuum locks, air flap actuator, etc. This gray connector usually pops off with the help of a flat head screwdriver. Don't try to disconnect the hose itself from the connector. That seems impossible. However this hose is sold by a meter. I don't remember the exact part # but if you want I can look it up for you.
Now, a general question - again, why does your headlight have this vacuum line?
#3 Old 01-24-2014
Quoted: 21 Post(s)
Unfortunately I did try to remove the vacuum line without success so I just cut it .The vacuum line is to adjust the position of the headlight. Cars in the UK have a switch to adjust the headlight position which is why the sticky did not have this information.
JaysonM likes this.
#4 Old 01-24-2014
This is useful information to know. I didn't know UK cars have the adjustment function. I know these connectors might be tricky and hard to remove. From my experience: just be careful if you have to mess with them next time.
#5 Old 01-24-2014
Quoted: 21 Post(s)
UK switch
you can see the height adjuster
US switch
I think all UK cars have these adjusters it's supposed to be used if you are carrying a heavy load in the trunk/ boot so you can adjust the headlights
JaysonM likes this.
#6 Old 01-24-2014
That's nice! I actually had it on my old VW Golf. I was like: why does it have headlight level adjustment but not power steering wheel or hydraulic clutch?! =) Thank you for sharing! I also saw that some of R170's come with side-view folding mirrors. Was looking for motors and switches but couldn't find any. Never seen it on US models.
#7 Old 01-24-2014
Quoted: 21 Post(s)
folding mirrors very popular in Japan but this one in The Netherlands
Prestigio RR 300 Dash Cam + Tetrax Fix Magnetic Mount randombloke Off Topic 2 09-03-2013 08:13 AM
Wet Floor Passenger-side LRC SLK R170 General Discussion 6 04-28-2013 03:43 PM
Creaking roof - very easy fix Fast_Eddie_72 SLK R170 class DIY 16 03-26-2013 06:55 PM
How to Restore Your Weathered Headlights mklinger SLK R171 Class DIY 6 08-21-2012 04:46 PM
Is there an easy fix for iPod/iPhone integration with Audio 20? musikalwayz SLK R171 General Discussion 4 07-14-2012 07:19 PM
