charging issue on slk320? new battery and alternator - Mercedes Benz SLK Forum
#1 Old 01-19-2014
Hi I have a 2001 slk320 and I've been having issues out of the battery light/ charging system. I first used my mulitimeter and found the car had 12.6 volts at the battery not running so that's perfect voltage for a battery... and then while running it was only putting out 11.5-11.6 volts. So I figured it was the alternator so I took the alternator off and took it to work to test it (I work at Napa). It tested good 10 times! I did it that many times because I was kinda confused at why it was showing to be good off the car. So I put it back on and took the battery to advance since that's where it came from its a group 41 battery I know it takes a group 48 but I wouldn't think that would matter because the battery has been in there since April 2011 but the battery tested bad so I had them swap it under warranty and I reinstalled the new one
The next day I was driving it to work and the alternator died lights started going dim/out and gauges started dying also. I took the alternator off and took it back to work and it tested bad. I figured maybe the regulator was playing games or something and it finally completely went out. I replaced it with a new one from Napa and it worked fine for one day. Last night it on my way home the lights went dim and battery light came back on so I went ahead and found a parking lot before I got stranded on the side of the road. I waited maybe 5 minutes and tryed to start it, sure enough battery light never came back on all the way home.
I went out today to see what the car decided it wanted to do today and sure enough battery light on 12.3 volts not running at the battery and 11.5 volts when running.
Anyways I know it was a long story but I've heard there is a battery cut off relay or something like that, that can go bad any help would be much appreciated.
central09er is offline
#2 Old 01-19-2014
Quoted: 6573 Post(s)
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already.
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’! If Iphone pics, you need to rename any additional pics as Iphone names its pics all the same,image.jpg.
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car) free. https://www.slkworld.com/vehicle-data-card/
#3 Old 04-12-2015
Well....what was it?
I have the EXACT same thing happening to my 2001 SLK320....lights on and acting like a bad battery/alternator. What was the problem with yours? Please elaborate. Thanks for your post.
homeboy981 is offline
#4 Old 04-12-2015
homeboy,
original poster has not been back since the date of his post Last Activity: 01-19-2014
Please update your location and vehicle (year?: 1996-2015, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
#5 Old 04-12-2015
Vehicle: SLK 200K 2003
I would look at the 12v supply to the Alternator (this magnetises it). Remove the leads to Alternator and check the 12v supply with the ignition on - do not run engine with lead unplugged.
93041 is offline
#6 Old 04-12-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
Well you have a new battery, so it probably isn't it. I suspect the alternator is shot. Take it to a shop that specializes in automotive electrical repair. They will take it apart and check all of its components and replace any bad parts.
To test the alternator, get the battery voltage up first. You could do this with a trickle charger. Then knock the battery voltage down with a series of starts. You could also turn on all the accessories and lights for an hour or so. Make sure the voltage has dropped using a volt meter. Now run the car for a 20 minutes of so. Does the battery come back up? If the alternator is doing its job, it should come back very quickly. Also make sure the belt has the proper tension.
Anther way to do this is hook a volt meter to the battery and run the engine at a fast idle. If the alternator is OK, you should measure about 14 Volts. I like the first way, because it simulates the alternator's job.
The main drain on the battery is starting the car, so the main job of the alternator is to bring the voltage up very quickly. This is very important, since you may start the car several times in a day. The rest of the electrical need of the car generally aren't that great, so the alternator has a light load.
DSSG is offline
#7 Old 04-15-2015
Other Toys: Traded them all!!
Quoted: 124 Post(s)
Regardless of how much the battery voltage drops on starting, once running my understanding is you should be seeing 14V+.
Something is screwy here.
Alex 3 is offline
#8 Old 04-15-2015
DSSG's Avatar
Quoted: 198 Post(s)
The voltage regulator controls the DC current output from the alternator. Its job is to make sure the voltage of the battery is maintained at a certain level probably around 12+ volts. If the battery voltage drops, the regulator lets the alternator pump the battery up and stops the current flow when the battery is pumped.
You see the voltage regulator is the electronic counterpart of Hans & Fritz!
DSSG is offline
#9 Old 02-02-2016
Vehicle: '98 SLK 230
Other Toys: 2 '91 Geo metro roadsters,944,CRX
My wife's '98 230 is doing the same thing. Drain at the battery while running. Seems like the charge light would come on but it doesn't. If the alt is bad, shouldn't the light come on?
J. W. H is offline
Battery / Alternator low voltage problems nmslk SLK R171 General Discussion 24 05-08-2016 01:06 PM
Alternator life span conleyjb SLK R170 General Discussion 6 03-13-2013 10:08 PM
99 SLK 230 Charging Problem Nanner General Discussion 1 07-30-2010 04:11 PM
Need help with alternator issue Jakub SLK R171 General Discussion 17 07-13-2009 07:25 PM
