Changed all mounts motor/tranny in my driveway - Mercedes Benz SLK Forum
 5Likes
  • 4 Post By legendary620
  • 1 Post By legendary620
#1 Old 01-16-2014
Vehicle: 1999 SLK 230 automatic
Other Toys: Old Honda's CB 350/CB 750
My baby was still vibrating severely at red lights so I ended up ordering a mount kit from ebay. All 3 mounts for around $115. Cant beat that! Jacked up the car and changed the 2 motor mounts out. So SMOOTH now.
Today I had her in at the shop getting a safety and looked under the hoist. The Tranny mount was almost falling off!!! So home I went again to put her on jackstands. I had a loud rumble coming from under the transmission area. I thought I had an exhaust leak or something. After changing the transmission mount it's gone and almost feels like a new car! If you have any vibration woes think mounts first and be advised its very difficult to tell just by looking at them to diagnose if they are shot or not.
AZ SLK, rhartson, 24996 and 1 others like this.
legendary620 is offline
The Following 3 Users Say Thank You to legendary620 For This Useful Post:
#2 Old 01-16-2014
Vehicle: slk320 2002
wish you take pictures to help others. Mine is 115k miles now and would love to see a diy for it
thanks
kalali is offline
#3 Old 01-16-2014
I just watched this youtube video.
https://www.youtube.com/watch?v=6bxPK1VcKOo
It's a different model but very similar procedure. I used a few socket extensions with a swivel thingy to get to the top bolts. Don't need "wobble extensions" like in video. Also there's no rubber mount cover thing and both mounts look pretty much exactly the same. Not sure why people say they're different.
Disconnect the top rad hose, little rad hose next to it and the MAF sensor pipe. Those should be the only things that have tension on them while jacking up motor. I was doing both sides so I put jack in the middle and undid both mounts and it allowed me to jack up the engine higher. Shouldn't need to go too high though.
You then put a jack under the oil pan with a piece of lumber to distribute the load. Its pretty tough so don't worry too much.
The one thing I WISH I HAD KNOWN before I started is:
It looks really tight and next to impossible to get out but really the only part you need to remove is the steering damper!!!! I removed tie rod ends and crap before I realized that the mounts will squeeze out with just removing the damper. ALSO turn the wheels all the way to the right to give you the clearance you need. Other than that you should be good to go buddy. It's a pain in the butt but I'd do it again if needed.
Not as bad as people go on about I don't think. Worst was rolling around on the ground and trying to line up mount holes. Put the top bolts in first, then bottom bolts. Keep them loose until you get everything lined up and then tighten them up. Tranny mount is WAAAAY easier. Just watch the video and if you need me to snap some pics or answer questions for you I can.
ps. Also need to remove a little heat shield covering passenger mount. Only two little nuts.
JaysonM likes this.
#4 Old 01-20-2014
I also used this video as a guide! The tricky part is to turn your wheels all the way to the right when removing driver's side mount! This guy does really nice videos and Mercedes's are almost the same so it's easy to figure out what to do
#5 Old 01-29-2014
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
When you do this job, make sure you use quality parts. There is a lot of Chinese junk out there, Uro being one of the worst. You're always safe using MB parts or the same manufacturer that Mercedes uses if you know that.
Len
1999 E300D 215,000 miles
sokoloff is offline
#6 Old 01-29-2014
I think its probably luck of the draw. MB mounts were going to rape me. I bought ALL 3 mounts for $125 on ebay and they seem to work very well. But yeah you don't want them to fail anytime soon. It's a PITA.
#7 Old 01-29-2014
Vehicle: 06 SLK55 Caspian Blue
Other Toys: 07 R500 4Matic Alabaster White, 08 Infiniti G35x
Mounts are a good investment in any car nearing the 10 year mark. Like bushings, ball joints, and hoses, any part that includes rubber as part of the design has a finite lifespan. If that rubber is exposed to the elements, anticipate failure, inspect often, and replace before any damage is done to other parts.
CT_SLK is offline
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 56 08-28-2019 05:35 AM
DIY Replacing Motor Mounts on r171 Smarin530 SLK R171 Class DIY 29 04-13-2019 10:36 AM
Engine mounts broken silver009 SLK R171 General Discussion 9 04-23-2013 11:26 AM
AMG package front bumper scratches on the driveway to garage shnjb SLK R171 General Discussion 22 09-27-2010 10:19 AM
Break Pads not changed in Service C GregoryGR SLK R171 General Discussion 6 11-29-2007 08:23 PM
