Some serious water in footwell & Boot! - Mercedes Benz SLK Forum
#1 Old 01-14-2014
cockneyrick's Avatar
Vehicle: SLK 230 03MY
Quoted: 34 Post(s)
Question Some serious water in footwell & Boot!
Bugger, just when i thought this car is great!
Anyway, its been a real problem with the car constantly steamed up inside, & thought give it a month to proper dry out with being stood it will be ok.
However the problem just seemed to be getting worse, so i rummaged round & found the passenger (LH) footwell is absolutely soaking! So i took the carpet (fitted one) out & underneath was worse. So i have put my household dehumidifier in there for 2 days now & its removed a lot of the condensation, but being pretty cold here, it cant draw out the damp from carpet.
So, this must be the "drain hole" issue. Now can anybody give me a How to on sorting this, & pics say a thousand words. Oh & the drivers side is dry, but the boot lid seems to get a lot of condensation too, which falls out of the latch when i open her!
cockneyrick is offline
#2 Old 01-14-2014
raymond.harper's Avatar
Vehicle: SLK 230 2001
Quoted: 21 Post(s)
raymond.harper is offline
#3 Old 01-14-2014
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Please follow the 170 drain link in my signature and good luck!
slk320chick is offline
#4 Old 01-14-2014
Quoted: 34 Post(s)
Thanks people, if it ever stops raining here, i'll attempt it. Mind you, its bloody freezing too
#5 Old 01-14-2014
Minion
Quoted: 148 Post(s)
We in the Midwest [USA] feel your pain brother
#6 Old 01-14-2014
Quoted: 34 Post(s)
Hahaha, I bet you do x
#7 Old 01-15-2014
Quoted: 11 Post(s)
remove the n/s wheel arch liner and clean out the bulkhead drain gland
beerbelly is offline
#8 Old 01-15-2014
leapyfish's Avatar
Here's another link http://www.benzworld.org/forums/r170...ml#post2212665
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#9 Old 01-19-2014
Quoted: 34 Post(s)
Right, had an attempt at unblocking drain holes today & this is what i found/did.
Firstly i couldn't get the panel off thats under the wiper arms as they were well seized on. So i proceeded without removal as best i could.
I started at the rear where the drains are easily accessible. The LH one was clearly blocked so i used a 1m length of plastic coated steel cable, with a bit of heatshrink over the rough end. I threaded it through the hole & a load of dirty water spilled onto my foot! RH rear was clear but i did it anyway. Then i poured jugs of water down the hole & all is good!
Next, onto the front. The LH was the issue as the passenger footwell is soaking, so as before i used the cable to poke through the tube. Water again passed through with no issues so i looked closer at the design. Very poor in my opinion & certainly not MB standard!
The heater blower access lies just to the right of the drain hole over a plastic ridge. Plenty to stop the water getting in that way? But the wiper panel is held in place at the leading edge by 7 screws across the whole length. But there is no pressure to the rear, windscreen side. All that there is, is a rubber seal that sits against the windscreen to stop rain/water/washer etc ingress & this is not good. So although i haven't done it yet, i will remove the panel & put some black **** (mastic) along the edge & place the seal/panel back in place. Hopefully that will cure it once & for all.
The Following User Says Thank You to cockneyrick For This Useful Post:
Water leaking into passenger footwell Lord Deadfish SLK R171 General Discussion 17 04-08-2016 12:03 PM
Roof folds, and drips water inside rear screen Tolak SLK R170 General Discussion 7 08-19-2013 12:39 PM
water leak in wells Mole10r SLK R171 General Discussion 2 05-24-2013 04:48 PM
Relative low-cost to soften water for car wash etyu Caring for your SLK 12 06-05-2012 04:45 AM
Need Help - Trunk full of water mcat SLK R171 General Discussion 31 07-20-2006 08:11 PM
