hesitation egr valve cleaning? code p0400 - Mercedes Benz SLK Forum
#1 Old 01-10-2014
Vehicle: 2001 SLK 320
New to this site........need help!!! I have a SLK320 2001, 169k miles. Just bought it and it drove great. had to fix the convertible top...rebuilt leaky pistons, works great now......ok back to my problem. I started feeling a hesitation when I would step on the gas from a stop, got worse, then check engine light came on. checked codes P0400. been researching code. found a vacuum line loose at the front of the engine...reconnected and it turned off the light. however, this morning i went to drive it and the hesitaion is back. It seems to come back when it is colder out. I live in Hawaii so colder is not really cold. about 65 degrees this morning, but last night at about 75 degrees it was fine. I took apart the EGR valve to pull out the tube and clean it, however, i could not get the tube out of the ?manifold? i know its got some bends but could not hold my mouth the right way to get it out. any suggestions on how to remove it or any other ideas on fixing the hesitation i'm getting? already cleaned the MAF, replaced air filters. Thanks - Jon
Hookercook is offline
#2 Old 01-10-2014
oh yeah....the only other problem with the car is the door locks and the interior light doesnt work when you open the door. not sure how to fix that either. thanks
#3 Old 01-10-2014
Quoted: 6543 Post(s)
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already.
Want to post a picture? Start a new thread or make a post, click ‘edit’, click on the ‘paper clip’ or ‘advanced’ and/or ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’! If Iphone pics, you need to rename any additional pics as Iphone names its pics all the same,image.jpg.
Post your vin in the Vehicle Datacard Request section to get a datacard (options on your car) free. https://www.slkworld.com/vehicle-data-card/
#4 Old 01-10-2014
Quoted: 11 Post(s)
do petrol engines have egr valves I thought it was only diesel engines ????
beerbelly is offline
#5 Old 01-10-2014
Yes. As far as I can tell. I have the egr valve that I found pictures of on this forum.
#6 Old 01-10-2014
Primer on EGR valve: http://autos.yahoo.com/maintain/repa...ques080_1.html
#7 Old 01-10-2014
Also found in petrol engines at least in North America for emissions/air quality reasons.
#8 Old 01-10-2014
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Check your PSE while you're looking for gremlins:
https://www.slkworld.com/slk-r170-gen...h-dry-pse.html
slk320chick is offline
#9 Old 01-11-2014
Quoted: 11 Post(s)
well when egr valves play up on our diesel trucks you can either take it off and clean them out with petrol or blank them off with a steel plate or just remove the vac pipe and plug it with a small bolt ect all will eliminate the problem if the egr is at fault as its usualy just exhaust soot making them stick
Need EGR valve help copperslk SLK R170 General Discussion 5 09-03-2017 09:49 AM
Bought a new check valve and shut off valve Bradley61496 SLK R170 class DIY 11 02-26-2014 10:42 PM
DIY : R170 : '98 Benz SLK 230 How to exchange engine cover gasket and valve gaskets w PIC dr.Benz SLK R170 class DIY 13 08-06-2013 01:40 PM
Problem with my spare remote kpalmer SLK R171 General Discussion 11 03-15-2010 08:06 AM
