Drive SLK once every other month - Mercedes Benz SLK Forum
 13Likes
  • 1 Post By Durkatlon
  • 1 Post By Der Flieger
  • 2 Post By fastdawg1
  • 2 Post By Mensra
  • 1 Post By Gbarringer100
  • 1 Post By gonzosc1
  • 1 Post By etyu
  • 3 Post By Gulliver
  • 1 Post By nimbusgb
#1 Old 01-09-2014
Vehicle: White 2002 SLK 230
Other Toys: 1973 Piper Cherokee Six 300
I am planning to stop every day use of the Car and leave it in a vacation home where we will drive it probably once a month or so.
What preventive maintenance and special care should I have done to make sure it works when we get there.
Wouldn't like to spend half of the weekend getaway fixing the car.
Rentero is offline
#2 Old 01-09-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 273 Post(s)
Well, a trickle-charger will be a must. Other than that I'm not sure what you can do.
Rentero likes this.
Durkatlon is offline
#3 Old 01-09-2014
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Is the place on the coast? If it's very humid, maybe look at a desiccant. Stored under cover?
Rentero likes this.
FUN 4 2
Der Flieger is offline
The Following User Says Thank You to Der Flieger For This Useful Post:
#4 Old 01-09-2014
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 95 Post(s)
Ship it to one of us, we'll keep that old battery charged and engine blown out!
rhartson and Rentero like this.
fastdawg1 is offline
The Following User Says Thank You to fastdawg1 For This Useful Post:
#5 Old 01-09-2014
Mensra's Avatar
Quoted: 397 Post(s)
You might want to overpressure the tires a little bit. That way you will not get flat spots. Don't forget your techron (with a nod to Jeff)!
jbanks15 and Rentero like this.
Mensra is online now
The Following User Says Thank You to Mensra For This Useful Post:
#6 Old 01-09-2014
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
Get a battery tender and do a search on how to install for quick hook up. Will it be parked in a garage or out side. Possible a cover if outside. Maybe a neighbor to keep an eye on it or someone to check by.
Rentero likes this.
Gbarringer100 is offline
#7 Old 01-09-2014
Vehicle: 2000 SLK 230
Other Toys: 09 Kawisaki Concours 14
leave fuel tank full!
Rentero likes this.
gonzosc1 is offline
The Following User Says Thank You to gonzosc1 For This Useful Post:
#8 Old 01-09-2014
May think also of adding a fuel stabilizer.
Rentero likes this.
#9 Old 01-10-2014
Gulliver's Avatar
Vehicle: '99 R170 SLK230 Kompressor
Other Toys: S55 AMG, lots of old GM muscle
My 2 cents- a "once a month" drive (at least) would be highly recommended. A "once every other month" drive I would avoid at all costs. Never mind whether the battery will stay charged, cars have lots of rubber parts that will dry out and start leaking if not brought up to operating temperature, used and driven regularly. The engine seals need the warm oil splashed on them, wheel bearings need the lube to move through, the fluids need to get to operating temp to remove moisture that has collected, the tires need the flex as do any other rubber parts to prevent flat or dead spots. I would cycle the top each time it's driven, switch between a/c and heat, anything you can do to give each component some good use. They need the exercise, for any car to sit unused for an extended period is never good for it.
etyu, PMB and Rentero like this.
Gulliver is offline
The Following 2 Users Say Thank You to Gulliver For This Useful Post:
#10 Old 01-13-2014
It will be in San Antonio, Texas in a parking garage below the building. good protection vs sun, water and extreme temperature
Rentero is offline
#11 Old 01-13-2014
nimbusgb's Avatar
Quoted: 253 Post(s)
If it is run then it must be a good run, get fully up to temperature to the point that the exhaust is hot for its entire length, the oil is completely warm etc.
There is nothing worse for a car than just running the engine for a few minutes every week or so. You create the worst corrosive conditions, acids, water moisture and warmth.
Valet before laying up, mice or rats in a car can be terminal! Consider rat bait outside if there is any risk at all! I laid up a car in Greece for 5 months and the blighters ate engine compartment sound insulation, windscreen washer hoses and electrical wiring.
Rentero likes this.
nimbusgb is offline
The Following User Says Thank You to nimbusgb For This Useful Post:
Tags
low use
2012 SLK AMG - Drive Impressions Motzkoman AMGs 9 01-26-2012 05:23 AM
If we need a Password in the future to drive our Slk Berliner Heckflosse Off Topic 0 07-05-2011 01:39 AM
June 19, 2010 Northern California SLK Enthusiasts Meet & Drive Motzkoman U.S. California 6 06-13-2010 10:14 PM
February 20, 2010 Northern California SLK Enthusiasts Meet & Drive Motzkoman U.S. California 5 02-19-2010 01:20 AM
8/15/09 SLK Meet & Drive Motzkoman U.S. California 0 08-04-2009 01:37 AM
