Top of trunk 'antenna' - Mercedes Benz SLK Forum
 5Likes
#1 Old 01-06-2014
Vehicle: 2003 SLK320 Magma Red
Other Toys: 2001 Vulcan 1500
I'm guessing that the little nacelle on top of the trunk is an antenna for the Merc version of On-Star. Since that system is 10+ years old (and probably TDMA) it's more than likely useless.
What I'd like to do is remove it and replace it with a different antenna - that way I don't have to drill any holes.
Has anyone seen any instruction/video about doing such a thing?
TIA
spclk is offline
#2 Old 01-06-2014
Quoted: 6547 Post(s)
you do a search mi amigo? i know it was addressed.
no video or diy other than talking about replacing it
#3 Old 01-06-2014
I did search (using google) and came up with some information but very little 'firm' info.
I was hoping for somebody who had done this and not created a post for it. I may do so if it works out. Even though the percentage of people interested is probably < 1%
spclk is offline
#4 Old 01-07-2014
JiminFL's Avatar
What kind of antenna are you looking to install? Is there not a radio antenna on the driver side rear fender? Or are you thinking about a satellite radio antenna?
There is info about installing a satellite antenna here http://www.billsden.org/mercedes/slk/docs/ Go down to procedures and then Satellite radios and MY 2005 (11/2005). I don't know if that is what you're looking for or not.
JiminFL is offline
#5 Old 01-07-2014
Thanks.
There was information about how to drill the deck lid for installation (templates/procedures/etc), and it looks like the hole is either 14mm or 20mm - but pretty good detail about the procedure, which I can use to remove this antenna and install my own.
I'm looking to install a short (19") 2m/70cm Amateur Radio antenna.
spclk is offline
#6 Old 01-07-2014
aka John
Chats: 1143
Quoted: 30 Post(s)
spclk- it's actually a GPS antenna, and yeah, you can pretty safely toss it unless you also happen to have the MapPilot in your car as well. I want to say it's a 12mm hole, but I don't have the reference literature in front of me.
UK-C200 is offline
#7 Old 01-07-2014
S L K Tech Enthusiast
SoCalBeachRunner's Avatar
Vehicle: Tellurium/Ash 06 SLK350 w Controller knob, Smartphone integration, backup cam; 05 SLK350 AMG package
Other Toys: Hackables: iOS/Android/Linux devices, Arduino, Macs, Cars, Life!
Quoted: 67 Post(s)
Send a message via Skype™ to SoCalBeachRunner
Housing for shark fin antenna
If you just want to cover the hole with something that looks ok you can buy the empty housing for a satellite antenna for a few dollars:
http://www.ebay.com/itm/281117126190
Only problem is it wants to attach to your paint with double stick tape, so you'll want to come up with a small plate and bolt to save your finish.
I concealed a regular $10 (on eBay) Sirius antenna inside this because it has 3 times the gain of the tiny OEM factory version. The radio no longer drops out under overpasses where I live - hallelujah! No way I was going to drive around in an SLK with a magnetic antenna exposed.
The existing antenna takes less than 10 minutes to remove (at least on the R171) and this used the existing hole that I guess the factory had made since it was a perfect installation. Paint to match. Fixed a VERY annoying problem for less than $30 total. If anybody is interested I'll post more details but this may be enough to give you some ideas.
El_Murcielago likes this.
SoCalBeachRunner is offline
#8 Old 01-08-2014
Quoted: 67 Post(s)
Pardon my ignorance - what's TDMA stand for?
#9 Old 01-08-2014
Mensra's Avatar
Quoted: 397 Post(s)
Time Domain Multiple Access. Basically it's a predecessor to today's GSM cell phone-multiple devices using the same frequency-technology.
Mensra is offline
The Following 2 Users Say Thank You to Mensra For This Useful Post:
#10 Old 01-09-2014
http://en.wikipedia.org/wiki/Time_di...ultiple_access
The previous version of cell phone coverage in the US. Since replaced by:
GSM
CDMA
LTE
spclk is offline
The Following User Says Thank You to spclk For This Useful Post:
#11 Old 01-10-2014
Quoted: 67 Post(s)
Thanks. I checked urbandictionary.com and 2 acronym sites but it didn't turn up. Given the context I was expecting slang for something like "Too Damn Many Add-ons"
UK-C200 and El_Murcielago like this.
#12 Old 01-14-2014
I was at a hamfest this weekend and saw that they have NMO mount antennas (and bases) that are designed to mount through a hole in the deck lid. I'm going to take my nacelle off and see what size hole is there - the 2 mounts that I've seen require either a 3/8" or 3/4" hole (~10mm / ~19mm).
The 3/8" seems pretty good : Wilson 901103
I don't want to use the 3/4" as the hole will have to be enlarged too much: Wilson 901102
The only thing I don't like is that they come with SME female and while that matches my HT, it won't match my mobile (that needs a PL 239 on the antenna side). No biggie, I probably have to take the end off anyway when I fish the cable into the car.
spclk is offline
#13 Old 05-12-2016
Vehicle: 2001 R170 320 Designo purchased 12/15/2015 with 43,xxx miles
Other Toys: Gold Rush Easy Racer recumbent bike
Here is a link that explains how to do it. Source is BenzWorld.org.
I've have not tried it yet. I'm having my stereo installation shop in the Los Angles area review the procedure and provide an installation cost estimate.
How to convert 2001-2004 GPS Antenna for Satellite Radio Use - Mercedes-Benz Forum
RJJSLK is offline
#14 Old 04-12-2017
Vehicle: 2003 SLK 320 (VIN: WDBKK65FX3F280089)
Other Toys: 72 Corvette Conv. (purchased in 72) & Cadillac STS
Looking for replacement GPS antenna cap for 03 SLK320
Does anyone know where I can purchase a replacement GPS antenna cap for my 03 SLK320? Mine was broken during a horrific hail storm and I have not been able to locate a new one. The Mercedes part # is 1298270231 (needs to be black) - Thanks, Rob
Rob7412 is offline
#15 Old 04-12-2017
let me check epc
you post your vin?
#16 Old 04-12-2017
Rob! you also owe us an intro thread
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#17 Old 04-12-2017
see the attached for part number
if i get your vin i can get better and your datacard
#18 Old 04-12-2017
Genuine Mercedes Benz OEM Parts Search | MB Parts Center
#19 Old 04-12-2017
9040 is black btw
#20 Old 04-12-2017
Apparently the part # that I was given didn't include the color code. I added my VIN to my vehicle info - it is: WDBKK65FX3F280089 - I appreciate your assistance
Rob7412 is offline
Some tips and tricks for convertible top cylinder rebuilds Arachnyd SLK R170 class DIY 58 08-25-2018 08:37 AM
Adjusting top in trunk dkindl New Members Introduce Yourself Here 17 05-21-2013 11:05 AM
Top won't go up--What to do. ribslk SLK R171 General Discussion 3 03-26-2012 01:45 AM
