Safe from rust. - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By JiminFL
  • 1 Post By markja
  • 2 Post By beerbelly
#1 Old 01-05-2014
Vehicle: SLK 230 year 2000
Other Toys: Motor Cruiser moored in France
Send a message via Skype™ to Dave T
Safe from rust.
I have had my car treated professionally to remove all visible signs of rust and it looks and drives superbly. I am realistic enough to admit that things, especially on an ageing mercedes don't last forever.
I would welcome advice as to which year's SLKs are less likely to suffer from rust issues with an eye to changing the car for a newer model at some time.
Many thanks
Dave T is offline
#2 Old 01-05-2014
JiminFL's Avatar
If you want to be safe from rust, you'll have to move to Arizona, although Florida is pretty good also.
BarrySLK280 likes this.
JiminFL is offline
#3 Old 01-05-2014
Vehicle: slk 170, 1997. blue. 230. and loverly!!!!
Other Toys: sports bike and canoe
Quoted: 38 Post(s)
rust
do i detect a certain amount of smugness from Jim?
from another damp Brit!
markja is offline
#4 Old 01-05-2014
JiminFL's Avatar
Oh Yeah!! I used to live in New Hampshire, well into the rust belt of the USA. I am so glad I'm in FL now where cars last until they wear out--or get crashed--
JiminFL is offline
#5 Old 01-06-2014
If you can afford it put the car up for the winter and avoid the rust issue.
#6 Old 01-06-2014
Vehicle: slk320 copper with designo interior year 2000
Other Toys: none=can't have too much excitement
my R170 also suffers from the usual rust.I think its just a case of right car wrong country! and its not going to get any better here in Enland any time soon.you will lmost have to accept ,if like me your slk is your daily driver then rust will be an issue.The r171 seems a bit better but leaving it in the garage is really the only answer as livefreeordie says
keith j is offline
#7 Old 01-06-2014
BarrySLK280's Avatar
Vehicle: 2009 MB SLK 280 Auto
Other Toys: Ford Fiesta 1.5Tdci Econetic Titanium
Quoted: 13 Post(s)
Smile
To the best of my knowledge, the newer the car the better the technology in all areas, including rust/weather protection. In which case a 171 or 172 would be your best bet. My 4.5 year old 171 is currently showing no signs of rust although is kept as my 'toy' and lives in the garage.
Having said above, my friend's 2012 Jaguar XK convertible with only 10k miles is already starting to show 3 separate patches of bubbling. His car is similarly kept in a garage and used for 'good times' only. Jaguar are sorting it out for him under warranty. Maybe it has more to do with 'the luck of the draw' !
BarrySLK280 is offline
#8 Old 01-06-2014
Quoted: 11 Post(s)
your best bet for a Mercedes with little rust in the uk is buy nothing newer than 1986 the w123 series saloons ect were among the last properly built Mercedes. sadly buying newer isn't going to guarantee less problems I refinish car paintwork for a living and have worked on a few rusty 171,s I think the florida move with a 172 will give you the longest rust free ride
beerbelly is offline
#9 Old 01-06-2014
Dolau's Avatar
Vehicle: SLK 200 kompressor 2003
Other Toys: Yamaha FZ6S2
I have a 2001 C class that used to live by the sea.... it has many areas of canker that I need to deal with when the weather improves and just checking out second hand doors on Ebay as an alternative to rust curring and filler and new spray paint
My R170 isnt too bad just a little coming around the wheel arches and one little bubble on the front wing above the bumper line which is going to be a pain for such a small amount of rust
Dolau is offline
#10 Old 01-06-2014
Deafy's Avatar
Which are the trouble spots to keep one's eye on?
Deafy is offline
#11 Old 01-06-2014
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Cookiecrew's Jun 2004 R171 had fairly bad rust on the back OS wheel arch.
Woolly is offline
#12 Old 01-06-2014
Deafy's Avatar
Salt getting behind the liner and sitting there?
Deafy is offline
#13 Old 01-07-2014
Quoted: 11 Post(s)
yep arches rears its usually started with stone chips that start to corrode or accident damage (but that's not Mercedes fault tho a galvanised shell wouldn't be too much to ask Porsche/Audi ect) front wing to bumper join will always be a bad area while Mercedes continue to use that mild steel connecting plate i fitted new ones on my 170 when I fitted new wings and give everything a good dose of waxoyle when I assembled it. there's not much chance of stopping it here in the damp uk if you plan on using the car .the slk,s aren't as bad as a/c/e class ect tho
#14 Old 01-07-2014
Quoted: 11 Post(s)
a very good idea is to remove the liner from each arch clean behind the panel then a good coat of waxoyle before refitting the liner
keith j and keith1275 like this.
#15 Old 01-09-2014
Dolau's Avatar
I was thinking of curing the rust around the wheel arches and painting with stone chip and then adding chrome wheel arch trims rather than the hassle of trying to match in metallic paint to any standard
Dolau is offline
Very sad, rust under arches :( Captainrave SLK R170 General Discussion 24 04-01-2019 04:33 PM
Build a Long rust removal Bath for under Ł10 WhitwellMike SLK R170 class DIY 6 02-29-2016 07:18 AM
170 rust !! Paul Dilks SLK R170 General Discussion 3 08-22-2013 10:28 AM
Touch up paint help Johnnguyenskyline06 General Discussion 23 05-15-2013 03:35 PM
For those of us in the USA concerned about our favorite shows getting renewed! jbanks15 Off Topic 5 05-11-2013 04:15 PM
