Jacking up the car - Mercedes Benz SLK Forum
 10Likes
#1 Old 12-31-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Jacking up the car
What would be the safest and most inexpensive way to jack up the 170 to remove all 4 tires at the same time?
slk320chick is offline
#2 Old 12-31-2013
The safest way would be a garage.
Der Flieger likes this.
#3 Old 12-31-2013
Mensra's Avatar
Quoted: 397 Post(s)
You can use four inexpensive jackstands and a regular floor jack.
Mensra is offline
#4 Old 12-31-2013
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 95 Post(s)
Agreed! What are doing Chickie?
fastdawg1 is offline
#5 Old 12-31-2013
Minion
Quoted: 148 Post(s)
Thinking of an alternative to new rims, but being able to change the existing oem's to match my black esthetic. Just thinking and wishing ahead for spring.
#6 Old 12-31-2013
fastdawg
fastdawg1's Avatar
Quoted: 95 Post(s)
I figured something was up, just can't stop can you! Glossy Red to match your car, do it!
#7 Old 01-01-2014
If this is something that one does rarely, it may come out more cost-effective to have a tire/tyre shop with the proper lifts to do the work. The new rim and tire combination may ned to be spin balanced anyways.
If you will be doing this every 3-4 months, then the cost of the 4 jack stand and a good quality low-profile floor jack may be in order.
#8 Old 01-01-2014
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Quickest way is leave it in Liverpool (UK ) overnight - when you come back, the car will be up on bricks, with all the wheels removed - probably the battery & radio too
curro101, CSMLET, PMB and 3 others like this.
Woolly is offline
#9 Old 01-01-2014
fastdawg
fastdawg1's Avatar
Quoted: 95 Post(s)
Chickie would just lay down and die if that happened as much as she's got invested in Bella!
#10 Old 01-01-2014
Mensra's Avatar
Quoted: 397 Post(s)
No that's not true. Chickie would go and hunt them down and rip their throats out!
Mensra is offline
#11 Old 01-01-2014
Minion
Quoted: 148 Post(s)
Replace "and if anyone, anyone tries to hurt one of my new friends"
with: "...tried to hurt my bella..."
#12 Old 01-02-2014
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
I have a lift we can put it on. You can also jack it up by the jacking points, they should be mention in the owners manual. However if you look at the car, there should be 4 jacking pads directly under the caps on your rocker panels.
Bradley61496 is offline
#13 Old 01-02-2014
simplyslk's Avatar
Other Toys: '13 GLK350
Quoted: 239 Post(s)
I go to the indy that does work on all our cars. When they lift the car to do the wheels/tires we all inspect underneath for anything out of sorts!
Marykay
simplyslk is offline
#14 Old 01-03-2014
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Just be careful where you place the jackstands. Not everything is as strong as it looks under there.
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
The Following User Says Thank You to tcrankwa For This Useful Post:
#15 Old 01-05-2014
Vehicle: 2012 250 petrol black/red
Quoted: 309 Post(s)
Sometimes the slower way is safer if you're going go down the DIY route.
My Merc. will be the third car for which I have treated myself to a second set of wheels/tyres for reasons of securing a softer ride on the smaller diameter wheels and just for a change of look.
I change each wheel one at a time. Using the supplied jack I take some of the weight off the wheel, ease off the securing bolts then raise completely off the ground. Then place an axle stand under the suspension knuckle where it meets the chassis and then VERY slightly lower the jack so that the weight of the car is about equally spread between axle stand and jack. Without placing my head under the wheel arch each wheel is changed. You get into a rhythm and it doesn't take long, providing you are not interrupted which means you might forget to secure a wheel bolt properly.
oldmercman is offline
#16 Old 01-05-2014
Minion
Quoted: 148 Post(s)
I am now working a deal to get some work done in March before the April Midwest meetup. I think this is the best route.
Thanks everyone
#17 Old 01-05-2014
Vehicle: 06 SLK55 Caspian Blue
Other Toys: 07 R500 4Matic Alabaster White, 08 Infiniti G35x
Yup, that's what I do. Make sure you're on a perfectly level surface. Use one jack point at a time to lift one side of the car just high enough to place a jack stand so the opposite wheel on that side is off the ground just enough to remove the tire. Repeat 3 times. Chock the wheel diagonally opposite the wheel you're lifting with the jack each time until you get 3 wheels lifted (i.e. no wheel left to chock). I have a 6,000 lb hydraulic floor jack that makes it quick and easy.
In fact I'm going to do this myself this winter. The SLK is tucked in for the winter and it needs new tires in the spring. So......what better time to pull the wheels off and take them to a shop for reconditioning and either powder coating or painting them? I'll get the done and then mount a new set of Michelin Pilot Super Sports and the car will ready to go in April. The goal with the wheels is to change the color to hide brake dust a little better.
CT_SLK is offline
#18 Old 01-05-2014
We have the Bronx for this.
CT_SLK is offline
#19 Old 01-05-2014
Minion
Quoted: 148 Post(s)
In March i'll have the odds and ends done that I need on the inside, and this gives me a lot of time to get powdercoat quotes on the wheels. It will be a lot cheaper than new rims [hate the oem silver I have now].
#20 Old 01-05-2014
Minion
Quoted: 148 Post(s)
Correction.. powder coating is NOT cheaper than new rims. It's about the same cost. Looks like a new solution is in order. Stay tuned.. dun dun duuuuuhhhhh .
The Ultimate Home Car Wash for the Ultimate Car Stinger Caring for your SLK 37 07-21-2015 01:05 AM
My 80's poster car alroumi Off Topic 9 10-11-2013 11:41 AM
My car spinned 360 degree in rain..so freak out mrl0n3ly714 SLK R171 General Discussion 44 06-04-2010 11:07 AM
