Clearing Drain Holes - Mercedes Benz SLK Forum
  • 1 Post By JiminFL
  • 1 Post By leapyfish
#1 Old 12-30-2013
Vehicle: R170 SLK 200K
I have started to suffer from alot of condensation in the boot (Trunk) and after reading some threads decided that I must have some drain holes blocked.
I have been looking for a suitable tool to clear them with and have come across this http://www.amazon.co.uk/Draper-68872-Pipe-Sink-Cleaner/dp/B0001KA0MW before I go and buy it will this clear them out without causing any damage?
Carbon-Rain is offline
#2 Old 12-30-2013
JiminFL's Avatar
I have been looking for a suitable tool to clear them with and have come across this http://www.amazon.co.uk/Draper-68872.../dp/B0001KA0MW before I go and buy it will this clear them out without causing any damage?
I don't think it will work. The shaft may be 6 mm (1/4") but that bulb on the end is going to be way too big to fit into the tubing in the car. It's gotta be 12mm (7/16") What I've done is to use the blowgun and blow out the crap that's in the line.
I also wouldn't try to push the small end down the drain lest it punctures the wall and starts another leak. I have used a 1/16" welding rod and bent the end back over so it is a smooth ball to dig around deep in the drain. Be careful doing that... again, punctures.
JiminFL is offline
The Following User Says Thank You to JiminFL For This Useful Post:
#3 Old 12-31-2013
CraigHew's Avatar
Vehicle: 200k SLK, 2009
Other Toys: BMW 5 Series. Westfield Mega S2000
I'd use an air-line first or if not available try some (fairly) hot water. that normally gets things moving.
CraigHew is offline
#4 Old 12-31-2013
Vehicle: 2002 SLK230
I have used the plastic coated net curtain wire and also the simple cheaper version of the drain rod without the bulb. Both worked for me.
BlueMachine2.3 is offline
#5 Old 12-31-2013
leapyfish's Avatar
You can also try nylon trimmer line for weed wakers, & snake the drain with it.
JiminFL likes this.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
Drain Holes slkfan SLK R171 Class DIY 38 07-09-2019 03:59 PM
Drain points - locations and tips on cleaning Raindog SLK R170 class DIY 89 06-02-2019 07:43 PM
SLK drain holes PatMcD New Members Introduce Yourself Here 22 06-23-2013 02:02 PM
Clearing the filler cap drain JonB SLK R171 General Discussion 0 04-20-2012 01:11 PM
Drain points - locations and tips on cleaning Raindog SLK R170 class DIY 0 06-01-2011 06:41 PM
