License Plate Bulb Replacement - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By etyu
  • 2 Post By wineprovider
#1 Old 12-29-2013
wineprovider's Avatar
Vehicle: 2007 SLK 200 AUTO
Can someone please help me to replace a licence plate bulb.
I`ve been told to do it from the inside but I don`t want to damage anything.
Some pics or a video may help as well.
Seasons greetings to one and all.
Martyn
wineprovider is offline
#2 Old 12-29-2013
Quoted: 6572 Post(s)
Until a r170 owner responds, owner's manual does not cover it?
#3 Old 12-29-2013
thanks
Thanks Jeff................I`ll just have to wait untill someone responds.
Seasons greetings. & regards,
Martyn
#4 Old 12-29-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Hi there!
You do not have to replace them from the inside. Its 2 screws on each plastic cover to the left and right of the license plate. At least thats the way it is in the US. This would also be a good time to look into no fault LED replacements.
slk320chick is offline
The Following User Says Thank You to slk320chick For This Useful Post:
#5 Old 12-30-2013
What is this stud
I`ve managed to release the obstinate bolts on the right and left hand side of this unit but there is this silver stud in the middle which I don`t know how I can release.
Please can I have some more help to complete the bulb change.
My thanks to slk320chick for the help and the pics.
Her is my pic to help to understand what I`m asking.
Regards to all,
Martyn
Sorry the pic has disapeared. I`m chasing it up.
There is a silver stud in the middle of the light nacelle holding the whole assembley in (or seems to be)
#6 Old 12-30-2013
Minion
Quoted: 148 Post(s)
Yes lets see what you mean? There are silver prongs holding each side of my bulbs in place, then the bulb just comes out itself by pulling slightly.
#7 Old 12-30-2013
Not that
I haven`t got that far yet.
On the outside exactly in the middle of the 2 screws there is a silver stud that appears to be holding the cover in place and I can`t see how to remove it.
#8 Old 12-30-2013
Minion
Quoted: 148 Post(s)
UK 170 folks help the man please.. your rears are completely different than ours
#9 Old 12-30-2013
Mensra's Avatar
Quoted: 398 Post(s)
(Looking down at my rear) looks the same here!
Mensra is online now
#10 Old 12-30-2013
Mensra
Mensra..............if you judge it to be the same perhaps you could help with the removal of the light cover after unscrewing the bolts.
Thanks for the input.
Regards,
Martyn
#11 Old 12-30-2013
IIRC it is also different for UK-spec. R171 as far as the rear license plate illuminators are concerned, it requires an approach from the inside of the trunk/boot lid and involves removal of the inner plastic trim of the trunk/boot lid.
#12 Old 12-30-2013
"Saying you have a dirty mind is like saying a Bugatti Veryon is fast! A severe understatement."
Just quoting someone from this post: https://www.slkworld.com/slk-r171-gen...ml#post1076801
Mensra likes this.
#13 Old 12-30-2013
Thanks etyu
This is what I thought from previous research.
I`ve looked on the inside and was baffled by the peculier clips holding the cover on. Any idea how to get the inside cover off without damage to it.
#14 Old 12-30-2013
Try the links found in LiveFree's signature: https://www.slkworld.com/new-members-...ml#post1083153
Got any good photos of the clips-of-interest? Commonly with MB they are compression type plastic anchors. In the R171, one uses a small flat head screwdriver to lift the central "pin", this releases the compression and the rest can be lifted straight out.
Try a search of the install of the R171 3rd brake light to get an idea.
#15 Old 12-30-2013
Thanks for your advice.
It`s very dark now so I`ll post a pic or 2 in the morning.
#16 Old 12-30-2013
3rd brake light install pdf to get idea of 'pins' Eddy is referring to on page 4
The Following 2 Users Say Thank You to jbanks15 For This Useful Post:
#17 Old 12-31-2013
Done............with problems
I`ve managed to remove the internal studs see pic.
Quite easy really but the fitting of the bulb was finicky and I think I fused it when fitting because they are both out now.
I`m gonna leave it for a while as I got a little frustrated.
At 67 years old I don`t find it to much fun sat in the boot in the freezing cold.
I`ll get back later.
The removal of the internal plate is done by removing the centre pin then the outside retainer I used the shown special tool to perform this stage of the process thereby not doing any damage.
All I gotts do now is find where the appropriate fuse is.
Happy New year to all.
#18 Old 01-02-2014
All done .....I must have fused the bulbs/lamps when I was messing about.
A bit concerned as the problem only arose because one of the bulbs/lamps was out. Both are working now so my concern is what caused the faulty connection. Maybe the future will reveal all.
My thanks to Jeff~~~~Gbarringer100~~~~~and leapyfish~~~~~Eddy~~~~~slk320chick
Happy New Year to all
etyu and jbanks15 like this.
Headlight not working - bulb and fuse replacement didn't help robinbc General Discussion 5 03-18-2017 04:59 PM
Left License Plate Bulb Malfunction Message? rubenh SLK R171 General Discussion 47 05-11-2016 05:53 PM
Changing front license plate holder mhslk SLK R171 General Discussion 1 04-23-2013 06:55 PM
brake Bulb Replacement (Even if welded stuck) foreign freak SLK R170 class DIY 2 11-05-2011 02:11 PM
