P0455 Check engine light, blinking gas light - Mercedes Benz SLK Forum
  • 1 Post By slk320chick
  • 1 Post By UncleE1
#1 Old 12-28-2013
dan2c1's Avatar
Vehicle: SLK 230 1998
Quoted: 14 Post(s)
The scanner gave me the P0455 code
it started with a blinking gasoline light and then The Check engine light was on,
a friend scanned the car and he told me it's probably just a hose and he deleted the code but i couldn't find the hose, i honestly didn't look where to look and i just forgot about it.
A couple of days ago the same thing happened and the gasoline light started to blink and then the check engine code appeared.
Any suggestions on how to fix this ?
dan2c1 is offline
#2 Old 12-28-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
It could be any one of these-please try the search feature at the top of the forum: And it also may be something as simple as a bad gas cap. I would start there.
https://www.slkworld.com/slk-r170-gen...632-p0455.html
https://www.slkworld.com/slk-r170-gen...uel-light.html
http://www.benzworld.org/forums/r170...full-tank.html
dan2c1 likes this.
slk320chick is offline
The Following User Says Thank You to slk320chick For This Useful Post:
#3 Old 12-30-2013
dan2c1's Avatar
Quoted: 14 Post(s)
The code went away.
It seeems like cleaning this valve took care of the issue
http://www.benzworld.org/forums/atta...urge-valve.pdf
dan2c1 is offline
#4 Old 12-31-2013
Vehicle: 2000 slk230
Other Toys: toyota paseo,toyota 4x4,75 triumph spitfire
This code has been bugging me since ive been out of warranty, it comes, goes, fixes and unfixes itself. Im thinking of doing a complete analysis of the system as there are about 5 different fixes that do or dont work for everybody, i have the necessary diagnostics tools and a good deal of experience. My question is, is this only the 230 or are other engine systems affected. Ive tried all the cures but in 13 yrs the problem keeps coming back.
swoop is offline
#5 Old 12-11-2016
UncleE1's Avatar
Vehicle: 1999 SLK 230
Quoted: 16 Post(s)
Red face
Bringing and old post back to life.
Originally Posted by dan2c1 View Post
The code went away.
Once again, this site saves the day...hopefully.
I followed these instructions and listened for the 'little drummer" and barely heard a click. I cleaned as instructed and now I hear the drumming. The engine died few times after cleaning, but that may be from excess MAF cleaner in the lines working its way out, I hope. The flashing fuel light is gone, but the check engine light remains.
Do I have to use an ODB reader to clear the check engine light?
Thanks,
UncleE1 is offline
#6 Old 12-13-2016
UncleE1's Avatar
Quoted: 16 Post(s)
I flushed out the PV and flipped the gasket on my gas cap. The flashing fuel light has not re-appeared, but the check engine light is still on. Should this go out by itself or do i need to use an ODB reader to clear a code?
UncleE1 is offline
#7 Old 01-09-2017
UncleE1's Avatar
Quoted: 16 Post(s)
I'll answer my own question. I had to use an OBD reader to clear the code and make the CEL go away. Now, to see if it comes back on.
UncleE1 is offline
Check Engine Light on... Control Module Performance?!! PLEASE HELP!! ebenk SLK R171 General Discussion 12 04-25-2013 12:49 AM
Check Engine light lit, then gone away (SLK 32AMG) jonathan SLK R170 General Discussion 0 03-06-2013 08:15 AM
Check engine light on! rdc08 SLK R170 General Discussion 16 02-29-2012 07:30 PM
