Interior light will not switch off but roof works fine? - Mercedes Benz SLK Forum
#1 Old 11-27-2013
Vehicle: Mercedes W245 B170 and R170 SLK 320
Arrow Interior light will not switch off but roof works fine?
Hello!
I have recently got an slk and the interior light and boot light do not work properly.
Of I turn the interior light on it will not turn off when I get out our of I stay the engine.
The left side light also does not work. I've done a search and found a thread on here that points to an issue that's very similar however the roof will not operate.
My roof works fine so any ideas what it could be causing the issue? It's a right pain having no interior light!
Thanks!!
ElegantSpoon is offline
#2 Old 11-29-2013
Any thoughts?
#3 Old 11-29-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Have a look at your PSE pump and its connectors , they suffer from getting wet/damp and giving these sort of problems ..
curro101 is offline
#4 Old 11-29-2013
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Just want to make sure that you are aware that the switch above the mirror has three selections. OFF, ON, ON with doors open. Also there is a delay once the doors are closed in the lights going off. Many new owners are not aware of this. You might I am just making sure you are.
Gbarringer100 is offline
#5 Old 11-29-2013
Curro where will I find that?
Gbarringer I'm sure mine doesn't. It just has I and o with no middle and then a button in front of that.
#6 Old 11-29-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
Sitting in driver's seat.
There is a push switch in the middle of the dome, nearest to the back of the car which is an on / off.
Below that switch, nearer the windscreen / front of car is a three-position switch which slides left and right. Try different positions of that switch. From memory, the middle position is the one you want.
ajberrow is offline
#7 Old 11-29-2013
curro101's Avatar
Quoted: 528 Post(s)
The PSE pump is in the boot , right hand side behind the panelling right at the bottom , hopefully in a polystyrene box ! It should be in your manual .
Do a search on the internet regarding inverting the PSE pump to avoid possible future problems ..
This should help you out ..
http://www.benzworld.org/forums/r170...fit-check.html
curro101 is offline
#8 Old 11-29-2013
Thanks for the replies
I'll have a look in the boot and see what I find.
Reference the light I'm certain I have a left right on off switch and in front of that there is a simple push in switch.
None have a third position, but hopefully I'm wrong and I've missed something. Haha I'll take a picture and try when I get in the car next
#9 Old 11-29-2013
OK just went out to have a look and I do not have a 3 position switch. I have a on off switch and a dome switch.
I popped the cover off and swapped the left bulb to right and it worked so there must be something at fault causing the left light not to work at all and the right to stay on all the time.
Any more advice, would the item in the not cause this?
I've tried attaching the PIC but it won't let me on my tablet!
#10 Old 11-29-2013
ajberrow's Avatar
There's a pic of the interior of a SLK 320 dome light in this eBay advert. Maybe compare that with yours to see if there's a break or other fault in the circuitry
http://www.ebay.co.uk/itm/00-01-02-M...item19de1171f3
ajberrow is offline
#11 Old 11-29-2013
Quoted: 99 Post(s)
On the side switch stop in the middle, as the switch does not have strong click for each location. The light that does not burn the connection where the bulb fits in are very touchy, might need to work on them. Had this problem with one of the lights on a 170 I had a few years back.
#12 Old 11-29-2013
That's what mine is like apart from the sos and that other grill. So you can see that there is no middle position switch it won't stay in the middle it clicks from side to side.
Is that different to everyone else's?
I will get it out on the weekend and see if there's anything obvious broken.
Thanks again for the help.
#13 Old 11-29-2013
RedMerc's Avatar
Vehicle: Magma Red R170 200 kompressor
Other Toys: Honda CRX DelSol Vxi
I have an SLK200 with the same interior switch arrangement one on/off push switch and left to right slider with no middle stop (detente). I believe my light has two bulbs inside but the left one has stopped working! I need to find out how to open and replace it.
RedMerc is offline
#14 Old 11-30-2013
Well neither of my bulbs work now!
Nice to see someone else with the same setup as me. There is 100% not a middle position on that switch arrangement.
My guess is maybe it's the box that's mentioned in the boot. I will investigate tomorrow and report back!
#15 Old 11-30-2013
Did you check the switch contacts? sometimes they get corroded.
#16 Old 12-01-2013
OK well I think I have found the issue! The interior lights timer is 5 mins!!!
When putting the interior lights back in and dicking around in the car I noticed the lights turned off!
I've checked the owners manual and it states in there that the lights stay on for 5 mins!
What a useless design! So it turns out they do work correctly it just takes far too long to turn off so they become unusable!
#17 Old 12-01-2013
Quoted: 99 Post(s)
You was correct the switch is either on or off and not middle location. Please note my post two days ago stated there was a delay after closing the door the light stays on.
#18 Old 12-01-2013
There's a delay! 5 flipping mins!
That is a terrible design on Mercedes part!
#19 Old 12-01-2013
Quoted: 99 Post(s)
You might find it will be less than five minutes if you remove the key and close the doors.
#20 Old 12-01-2013
No it's still 5 minds regardless of what you do! Drive off, lock the car, makes no difference!
Vario Roof not always opening closing. WinterWarrior SLK R170 General Discussion 6 04-01-2012 07:24 PM
Replacing roof control switch 1958neil SLK R171 General Discussion 3 08-16-2011 09:14 AM
Hot Weather roof problems nickbeckett SLK R170 General Discussion 7 07-11-2009 06:38 PM
Need some help with roof. cyberdrakon SLK R171 General Discussion 5 06-29-2007 12:54 PM
