Dark or burnt oil/oil filter question - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By gdb069
  • 1 Post By Deafy
  • 1 Post By DIYGirl
  • 1 Post By Deafy
#1 Old 11-26-2013
Vehicle: 2001 SLK 320
Weather turned nasty on me before I could change the oil myself, so I took it to a local group to change it for me. I asked how the oil looked (wanted to make sure it was not milky). The guy said it was a little burnt but not the worst he had seen.
I know that it has been mentioned many times that you can't really tell what is going on by just looking at the oil, but should an oil that has been in for less than 3000 miles (but has been in for a year) be significantly dark or burnt looking? Would the techron concentrate significantly darken the oil?
Also, the oil filter cap has been broken from the plastic that holds the filter in place. Have a new one on order but heading out on a 1000 mile trip. Since the cap is not holding the filter in place, can it slip down further into the oil housing or is it designed in such a way that everything fits snugly in place and not likely to shift out of place?
Thanks for the feedback
DIYGirl is offline
#2 Old 11-26-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
The filter will stay in the chamber, but I'm not at all sure the oil will flow as it should for filtering purposes. I don't think the filter can block the input or outflow orifices.
FUN 4 2
Der Flieger is offline
#3 Old 11-26-2013
Vehicle: 2005 SLK350 MT
Quoted: 19 Post(s)
What is a local group? If a "quick" oil change place they almost always say it looks a little burnt. What the heck does that mean. Oil can be a variety of colors (Purple anyone?). What oil was it? 3000 miles seems a bit too frequent. What is your recommended oil change interval?
I am not a 170 expert but if your oil cap is the same as 171 or S series then the oil filter cap can separate and be reinstalled from the shaft. I have accidentally done it on an "S" and scared hell out of me. I don't have photos (too nervous) but was able to snap the cap back on to the shaft. Itr took a lot of pressure but did it by hand.
G.
Der Flieger likes this.
gdb069 is offline
#4 Old 11-26-2013
Quoted: 1136 Post(s)
Well my old 170 usually done every year 3000 miles and i used to change with castrol magnatec oil .
And i can tell you it was always a golden brown finish .
Never black like a nice dark brown but clear if that makes sense !!
Delucas is offline
#5 Old 11-26-2013
Thanks guys. Filter problem solved. The my mercedesparts folks hooked me up with a replacement. I thought I was going to have to order one and wait until I got back from the trip.
3000 is a short drive time but it was in for a year and it had techron concentrate in it so it had to come out.
DIYGirl is offline
#6 Old 11-26-2013
Quoted: 123 Post(s)
techron in the oil?
FUN 4 2
#7 Old 11-27-2013
Techron goes in the gas. It is recommended by many in the group here to change your oil after the techron has had a full tank to run thru and do what it can do to clean the fuel system.
DIYGirl is offline
#8 Old 11-27-2013
Quoted: 123 Post(s)
not clear to me how that affects your oil...
gas additives will clean valves and injectors etc...
FUN 4 2
#9 Old 11-27-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Some will leak past the rings and end up in the oil - that's why oil goes black - products of combustion.
Woolly is offline
#10 Old 11-27-2013
Quoted: 123 Post(s)
yes, some combustion does get past the rings, but are we saying the techron has a noticeable affect on the oil?
FUN 4 2
#11 Old 11-27-2013
Deafy's Avatar
Seems the oil industry will do or say anything to maintain their supply of used engine oil to recycle...
Woolly likes this.
Deafy is offline
#12 Old 11-27-2013
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Don't you ever sleep?
Woolly is offline
#13 Old 11-27-2013
Deafy's Avatar
Not much. G/f in Chicago doesn't help.
Deafy is offline
#14 Old 11-28-2013
According to some info on other forums, the additives in the techron will impact the viscosity of the oil and break down the additives in the oil. Supposedly that information has been confirmed by Chevron. Chevron recommends using the concentrate two weeks before an oil change.
etyu likes this.
DIYGirl is offline
#15 Old 11-28-2013
Deafy's Avatar
Have you got a link or that?
Since the same product is part of the additive package on their premium fuels, it would follow that you'd need to change your oil after every fill-up.
You really would then be on Big Oil's Christmas card list.
http://www.techron.com/
I suspect the 'myth' developed as a result of maintaining a routine, ie when you are about ready to change your oil, do a fuel system clean at the same time.
etyu likes this.
Deafy is offline
#16 Old 12-24-2013
Quoted: 19 Post(s)
I hate rumors so I checked with Chevron both fuel and oil divisions and found Chevron does not recommend changing oil directly after Techron treatment but does recommend no more than 5 Concentrate treatments between oil changes in case of excessive blow by. In the case of using Chevron fuel with Techron they recommend adhering to the vehicle manufacturers oil change interval. I think that if you are requiring 3-4 concentrate uses per year you have additional engine problems.
Gordon
gdb069 is offline
#17 Old 12-24-2013
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
I've never heard of engine oil smelling "burnt". Transmission fluid yes.
What's more important is the sediment in the oil.
Are you using dino or synthetic?
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
Air Filter 350 slk - Stupid Question csquire4 SLK R171 General Discussion 12 09-30-2013 04:55 PM
Kleemann Supercharger and Air filter question Tiremarx723 Performance MODS for the R171 1 01-21-2013 04:49 PM
SLK280 Fuel Filter question - Internal or External ? cx872 SLK R171 General Discussion 4 11-06-2012 08:35 AM
Oil Filter Question MrAbody SLK R171 General Discussion 3 07-08-2012 12:16 PM
