Help needed with roof pump replacement - Mercedes Benz SLK Forum
  • 1 Post By Rustyjt
#1 Old 11-22-2013
simplyslk's Avatar
Other Toys: '13 GLK350
Quoted: 238 Post(s)
My son Preston is starting his weekend project (finally) on his R170 230 and his main question is:
When you replace the hydraulic roof pump do you need to bleed the lines and how do you do it?
Thank you so much for any help you can give him!
Marykay
simplyslk is offline
#2 Old 11-22-2013
gringott's Avatar
Vehicle: 1998 SLK230 R170 Stock
Other Toys: 350Z TT
When I replaced my roof actuator [spewed fluid everywhere, basically had to refill the pump] I read it was "self bleeding". I had empty lines at least to that part, and it worked.
gringott is offline
The Following User Says Thank You to gringott For This Useful Post:
#3 Old 11-22-2013
Vehicle: 2001 SLK 3.2 V-6
Other Toys: 2012 Infiniti EX35
Quoted: 11 Post(s)
Send a message via Skype™ to Simprof
Gringott is correct no bleeding is required..
Simprof is offline
The Following User Says Thank You to Simprof For This Useful Post:
#4 Old 11-22-2013
simplyslk's Avatar
Quoted: 238 Post(s)
Thanks! It's all done!
Marykay
#5 Old 11-23-2013
Vehicle: 2005 SLK 350
Other Toys: Mitsubishi Challenger, Suzuki GSX 750
Too late to help this time but found this, which is interesting viewing anyway
JiminFL likes this.
Rustyjt is offline
The Following User Says Thank You to Rustyjt For This Useful Post:
#6 Old 01-22-2014
Vehicle: 1998 SLK230 Blue
Other Toys: 1963 W111 Fintail, Boat, Models
Hi Guys, Have yet another roof problem on my 1998 R170 in the last twelve months. Last time the locking cable came off a trunk ram but this time my pump just spews out all the oil in just a few seconds. I'm not sure exactly where it's from but it's somewhere around the pump itself not the tank nor the lines to it. I have purchased a used replacement pump. I know it's tedious and can be an awkward job but I'm sure I'll manage. Is this the only option for me or can leaky pumps actually be repaired? Cheers from (very) sunny AUS
fly1705 is offline
#7 Old 01-22-2014
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Usually, the only reason that pumps (or any hydraulic ) components fail is because seals or O rings have failed. If your pump is toast, I would try taking it apart (if you're not confident, get a local hydraulic workshop to do it for you ), and changing them.
Having said that, are you sure it's the pump - can you see where the fluid is escaping? It could be one of the lines or cylinders/rams where the problem lies.
Woolly is offline
Vario Roof Pump Access BarryEdward SLK R171 General Discussion 22 06-13-2016 12:11 PM
Roof Hydraulic pump questions djcdo SLK R170 General Discussion 22 04-29-2016 05:21 PM
What IS the correct way to check roof pump fluid level? PaulRUK3 SLK R170 General Discussion 2 10-04-2013 10:15 AM
Roof help needed curro101 SLK R170 General Discussion 12 09-17-2013 06:55 PM
