Xenon, HID or Halogen - Mercedes Benz SLK Forum
 5Likes
#1 Old 11-19-2013
RoboRob's Avatar
Vehicle: 2002 SLK320 6 speed
Quoted: 17 Post(s)
I'd love to upgrade my headlights but am now confused as to what my car has and (upon determining that) what option I am left with to install.
1. How do I determine what type of headlight system my car has by visual inspection.
2. Depending on the type of headlights I have, are there simple plug and play options out there (I'm mechanically able but not comfortable cutting wires).
3. Are HID's the same as Halogen, just different terminology.
4. If I have Xenon would replacing with HID be a step backwords, and if possible is it easy from an electrical/dependable point of view?
I've noticed one main source SPYDER. Any others out there? Lots of EBay sales but no-one says who they are made by.
What ya all think? Thanks.
RoboRob is offline
#2 Old 11-19-2013
Quoted: 6498 Post(s)
I would rule out hids as your car is old.
post your vin or check your datacard to see if it says halogens
hids are NOT the same as halogens
others that have upgraded their halogens on their r170 s will respond I am sure
#3 Old 11-19-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
You have a facelift 170. Spyder upgrades would be simple plug and play. Chances are you have xenons now, but your datacard should say what you have. I don't know what the technical type of the spyders are called, but there are 7 different bulbs in them.
I don't know anything about hid's, sorry. The boys will chime up shortly. Just remember, there is a reason the spyders are so popular. I think this forum with a little searching probably exhausts every single headlight upgrade imaginable.
Good luck
slk320chick is offline
#4 Old 11-19-2013
our sponsor carid.com
http://www.carid.com/2002-mercedes-s...s-accessories/
#5 Old 11-19-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
HIDs are kits that use standard H7 etc with Xenon type bulb colours . HID kits can be used in a variety of colour tones marked in Kelvins , 6000k , 7000k etc. The tones range from yellowish ( halogen colour ) to white -6000k to purplish 12,000k .
If you have original xenon and your light isn't bright/ white enough you may have dirty lenses or corroded reflectors .
If you have halogens you could upgrade to a compatible HID kit to get a brighter/ whiter light , I would suggest a 6000k A/C 35w kit , so as not to blind on coming drivers and not have the flickering lamp problems the older D/C kits had .
If you put an HID kit in it's plug and to the fact that the bulb is the same model/ type you already have , H7 etc , and your actual connectors , connect the Ballast from the kit and the Ballast to the new HID bulbs !
curro101 is offline
#6 Old 11-19-2013
curro101's Avatar
Quoted: 528 Post(s)
Personally , for new headlights my favourites for the r170 are these , which in my opinion give a mordern look , whilst respecting the original lines !
http://www.ebay.de/itm/DEPO-SCHEINWE...item1e757d80da
curro101 is offline
#7 Old 11-19-2013
simplyslk's Avatar
Other Toys: '13 GLK350
Quoted: 238 Post(s)
I replaced my oem with Spyder...it completely updated the look and was easy to install!
http://www.carid.com/2002-mercedes-s...ss-headlights/
The have either chrome or black.
Now remember once you start with the headlights you've got the fog lights, then the side marker lights (pay close attention to what's legal in your area), then the third brake light and the license plate lights to replace!
Marykay
simplyslk is offline
#8 Old 11-20-2013
leapyfish's Avatar
BTW, Mercedes xenon headlights are $800+ for each side.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#9 Old 11-20-2013
RoboRob's Avatar
Quoted: 17 Post(s)
Thanks for all the replies.
Is there anyway of visually inspecting to see/read what type I have?
RoboRob is offline
#10 Old 11-20-2013
curro101's Avatar
Quoted: 528 Post(s)
If the bulb is like this , it's halgogen H7 and will normally be written on the metal flange :
If the bulb is H7 HID it'll look like this :
And will have a ballast similar to this :
Or this :
If it's Xenon it'll look like this :
With a ballast like this :
Bezgreshen and JiminFL like this.
curro101 is offline
#11 Old 11-20-2013
JiminFL's Avatar
Wow. You can't get it clearer than that. Thank you for this post.
curro101 likes this.
JiminFL is offline
#12 Old 11-21-2013
RoboRob's Avatar
Quoted: 17 Post(s)
Thanks, now I can go and find out.
RoboRob is offline
#13 Old 11-21-2013
Vehicle: Mercedes W245 B170 and R170 SLK 320
Any pictures of these fitted?
ElegantSpoon is offline
#14 Old 11-21-2013
curro101's Avatar
Quoted: 528 Post(s)
Not personally , sorry ...
curro101 is offline
#15 Old 11-22-2013
Anyone else? Not sure on the projector style lights they look too after market for me but those others look standard but potentially a little more modern.
#16 Old 11-22-2013
nimbusgb's Avatar
Quoted: 252 Post(s)
HID = High intensity discharge. Bulbs work by sustaining an arc between two tungsten electrodes and creating a plasma that gives off very intense light.
Generally not 'dippaple' so you will have a high beam set of lenses and a low beam set.
Very efficient. Bulbs are driven by a high voltage ballast. CAN BE LETHAL IF FIDDLED WITH THE POWER ON! Also contain small but potentially dangerous quantities of mercury vapour.
Generally HID bulbs although in similar fittings to traditional bulbs should not be used in fittings designed for other types as the light discharge pattern is different and results in glare.
HID's are most likely to be in headlamps with projector type lenses ( big hemispheric lenses )
Some 170's had optional HID lights, the slk 32 had them as standard in the uk i think.
Ignoring technicalities and legalities the difference in light is very, very marked! Its a bit like going from a couple of candles to a torch
Halogen lights are traditional bulbs with direct light emitting filaments.
The spyder lights get good reviews. There are Chinese knock offs that have badly aimed high beams ( point at the treetops )
gringott likes this.
nimbusgb is offline
#17 Old 11-23-2013
RoboRob's Avatar
Quoted: 17 Post(s)
OK, so I have XENON headlights.
Are they better that the HID's or H7's?
Should I find a "spyder" type XENON headlight (like this link)
http://www.ebay.com/itm/360790124504...84.m1438.l2649
to fit my current set-up (cost's more but would be (hopefully) plug and play for me or..
should I go with a advertized "spyder" (like this link)..
http://www.autolightpros.com/1998-20...K98-1PC-HL-BK/
Is it a real pain switching from my factory XENON to something else?
Rob
RoboRob is offline
#18 Old 11-23-2013
Minion
Quoted: 148 Post(s)
Regular spyders will take about an hour to install. You have a facelift model so it's plug and play already.
#19 Old 11-23-2013
Mensra's Avatar
Quoted: 385 Post(s)
You do mean "plug and pray" don't you?
Mensra is online now
#20 Old 11-24-2013
RoboRob's Avatar
Quoted: 17 Post(s)
Or this :
OK, so my data card says I have Xenon (and visually the bulb looks like Xenon ) but I don't see a ballast like in the picture above. Wire just goes from the bulb and snakes to the firewall area with no ballast seen? Where would I find this ballast in the engine bay?
RoboRob is offline
Am I stuck with factory HID (xenon)? GaryMedia General Modifications R170 12 12-22-2014 02:04 PM
Recommended Xenon HID Kit silver009 SLK R171 General Discussion 19 02-03-2014 01:08 PM
Xenon & Halogen Headlights - All The Same Wiring? mb911 General Modifications R171 7 11-27-2012 04:06 PM
